BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Ambient temperature sensor
      03-15-2024, 07:43 PM   #1
mossie5
Ireland
Drives: 2017 320d
Can anyone tell me if it's possible to get an ambient temperature sensor to connect the 3 wires in attached picture as the only sensor I can source is one that will connect two wires?
      03-16-2024, 01:09 AM   #2
fe7565
fe7565's Avatar
Drives: 2012 BMW 328i N26
What do you have? 2017 320D? The wring diagram shows 2 wires for the ambient air sensor. Why do you have three wires?
Help each other: if you manage to fix your issue (especially with help from this forum), don't be a d*ck and disappear. Follow-up by posting the solution so you can help others.
      03-16-2024, 02:57 AM   #3
mossie5
Ireland
Drives: 2017 320d
Hi there, I bought the car as cat s with a few problems to fix, someone has made a botched job with the wiring, just wondering how to fix this? Yes it's 2017 320d
      03-16-2024, 05:13 AM   #4
fe7565
fe7565's Avatar
Should trace the three wires and see where they go. Then you identify which is which.
      03-16-2024, 05:18 AM   #5
mossie5
Ireland
Drives: 2017 320d
I have checked at least 15 BMWs in a breakers yard and they are all 2 pin sensors
      03-16-2024, 07:06 AM   #6
fe7565
fe7565's Avatar
Based on the wiring info, they are all two wires. So what I’m saying is you need to trace those three wires in your car and identify which two are the correct ones. The third one you could trace to see where it goes so at least you know what it is.
According to the wiring diagram, it’s a green white and a brown white. But your car is right at the 2017 change of model year so you would need to know what month your car was manufactured. Previously might have been different colors. I’m assuming your car is not an M model.
