03-12-2024, 10:08 PM | #1 |
Crystal330ii
Rep 46
F30 M sport steering wheel conversion advice
Found a great deal on a used M Sport steering wheel for my 2017 330i. The wheel is off of a 2014 435 m sport, and still has the airbag, buttons, trim, etc. Also comes with heating. Seems like an amazing deal for 800 canadian dollars, but just wondering if there 's anything I need to watch out for? From what I understand the wheel will be plug and play, but just looking to get a second opinion before I pull the trigger.
Thanks |
03-13-2024, 08:46 AM | #2 | |
Rep 1,119
Drives: 2015 BMW 435i Xdrive MSport
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
03-14-2024, 02:14 PM | #3 | |
Rep 1,117
$800 CAD = $590 USD First, BMW calls for steering wheel to be replaced if air bag goes off. That’s where you find most M Sport Steering wheels. From accident cars. 2nd, Airbag is probably counterfeit and illegally rebuilt or single stage. You’d be very lucky to find a legit used airbag alone at that price. If it sounds to good to be true… |
Crystal330i9.00 |
03-14-2024, 10:05 PM | #4 | |
Crystal330ii
Rep 46
03-14-2024, 10:12 PM | #5 | |
Rep 1,117
Not even close And Canada BMW prices are generally higher than USA. I would also point out that some EU Round M Airbags are under recall. This MIGHT BE a recalled airbag that wasn’t destroyed and simply relabeled. Considering the way the label looks, it wouldn’t surprise me. Background: In June 2017 Takata Corporation, an airbag manufacturer, filed for bankruptcy in the United States and Japan due to lawsuits and large product recalls for unsafe airbags (with faulty airbag inflators) which the company sold to major automotive manufacturers.[14][15] KSS acquired the remaining Takata assets for about $1.6 billion.[16][17] Renamed to Joyson Safety Systems Following the antitrust clearance and bankruptcy court approvals in various countries, on April 11, 2018, KSS announced the completion of its acquisition of Takata, and changed its name to Joyson Safety Systems.[4] |
03-14-2024, 10:26 PM | #6 | |
Crystal330ii
Rep 46
03-14-2024, 11:42 PM | #7 | |
Rep 1,117
As for the labels, as JSS is a newer Company, the pic I posted was of a Takata USA Round M F Series 2 Stage Airbag. I haven’t needed an airbag since 2017 so I cannot tell you what the JSS labels look like. What date code do you see on the side label or on the connector wire label? The JSS labels might look like that - and probably do. Though I’m a little shocked they look so sloppy as if they are slapped on. Bottom line. With all the rebuilt and counterfeit airbags, not to mention recalled Airbags that were not destroyed and being illegally sold, Steering Wheel Airbags are the only item that I will not buy from anyone but a BMW Dealer. There is just too much chance any other way. But you do you. |
Crystal330i9.00 |
03-16-2024, 05:15 PM | #9 |
Crystal330ii
Rep 46
After a bunch of research and communication with the seller, I think I should be okay buying the wheel + airbag used from marketplace. Seller owns a junkyard, has great reviews on marketplace, and provided photos of airbag part number as well as the vehicle vin number. Vin number was checked against https://www.nhtsa.gov/recalls (wba3r5c57ek188421) showing no active recall for the airbag on the car the steering wheel was removed from, and https://www.bmwusa.com/safety-and-em...ta-airbag.html shows that no BMW 4 series was even part of the airbag recall. Part number of the airbag is attached. Airbag is also dual stage with the 3 connectors.
Matches with other OEM airbags from a quick google search. Just wanted to leave this post here in case other people are looking to do this conversion. As YASBBYM3 has stated, there are a ton of illegal, counterfeit, and fake airbags in circulation, so purchasing any used airbag contains some element of risk. At this point, however, I think the price versus the amount of risk I am taking for this specific scenario is well worth it (1600 canadian for the airbag itself at the dealer). |
