03-17-2024, 01:14 PM | #1 |
Rep 3
N55 THrowing up injector codes
I just recently purchased a 435i with the n55 and on my way home the car broke down and i got a check engine with 7 codes
p3148-cylinder 1 high pressure injector high side shorted to coil p3151-cylinder 2 high pressure injector high side shorted to coil p3154-cylinder 3 high pressure injector high side shorted to coil p3157-cylinder 4 high pressure injector high side shorted to coil p3160-cylinder 5 high pressure injector high side shorted to coil p3163-cylinder 6 high pressure injector high side shorted to coil p10d9-fuel pressure rail sensor stuck after reading the codes i replaced the fuel rail sensor and the only codes that came back were the codes for cylinders 1,2,5, and 6 any Ideas as to what it might be. |
