01-09-2019, 10:18 AM | #1 |
Rep 170
Rear window defroster not working
Tried using my rear window defroster last night and it wasn't working. Has anyone else experienced this? If so, any remedies you could suggest? Possibly a fuse?? Really don't want to waste a full day of my car being tied up at the dealership just to get this fixed but it is a bit a nuisance. Thanks.
01-09-2019, 10:42 AM | #2 | |
Rep 15,858
I've had this before, in my E91, worked fine once other electrical loads were switched off. |
01-09-2019, 11:52 AM | #3 | |
Curmudgeon and Pedant
690
Rep 3,489
Check for scratches on the INSIDE of the window. Big one that spans many of the lines could be the problem - again test continuity across scratches. Problem is with single or more array problems is that it requires a new window! Come on, now, Get it fixed, I don't want you backing into me! |
11-30-2020, 01:50 PM | #5 |
Rep 833
Drives: BMW F36, E36, E93
Get yourself a diagnosis kit. I will tell you
Such Fun
If you finde any spelling mistakes in my posts you may keep them, no return required |
07-22-2023, 06:38 AM | #6 |
Rep 106
Bringing up from dead.... i have f31, 2014. i lost coding options for ihka. Diagnostics said short circuit to passenger side temp wheel short circuit. Few months i was ignoring it because everything works, and sometimes diagnostics said rear window defroster not working due to low power output. But it works..... i found out today broken something that goes under plastic cover. On left hinge.... is that heater broken mass or what?
07-22-2023, 12:48 PM | #7 |
Rep 106
Update: i removed roof spoiler, and found out tatcthat thin thing is a bridge for 0 ground mass, from rear windshield to trunk over hinge. Just used thin metal (i found that thin in my garage) and made new one and connected on a hinge. It is not related to glass heating or hvac.....🤣🤦‍♂️ but my problem still persist, window heating works normally, but error is still here as low power output, and i cannot use coding in bimmerlink. Not that i have something to code on ihka, but it is annoying that i have problem and dont know how to solve it.
Derekrpd81.50 |
