03-20-2017, 04:41 PM | #1 |
Rep 106
Door Lock not opening with two Pulls
Hey
So this has started to happen occasionally. I will try to get out of the car and the door pin won't go up. Let me know if anyone knows what could be causing this? Thanks
2014 BMW 428i xDrive M-Sport
03-20-2017, 05:37 PM | #2 |
Rep 87
Door lock actuators. If your car is under warranty, the dealership will cover replacement.
'22 M240i Portimao/Cognac
(Sold) '14 335i Estoril/BK • M Sport • Prem/Tech Pkg • M Perf INTR • VMR V710FF • Shifteck DP (Sold) '95 M3 Avus/Dove • PSS9 • Vorschlag Camber Plates • 3.46 Torsen Diff • etc. |
03-20-2017, 05:55 PM | #3 |
Rep 103
This is very annoying, it happened to my drivers side door few months ago, took it in they said they replaced door acutator and last night it happened again not happy at all
03-20-2017, 06:18 PM | #4 |
Rep 4,446
Drives: '23 X1 28i xDrive
There's definitely other threads on this where people have gotten this fixed under warranty.
03-20-2017, 06:39 PM | #5 |
Big Beaver Smile
2101
Rep 3,791
+1 to what everyone else said.
I just had this covered under warranty in my 5 series. Of course when I brought it in, it worked for the first time in weeks. They changed the actuator and it's been fine since. A few days later I noticed the memory panel and seat massager on the door wasn't lit and didn't work. Another trip there and they plugged the wire they forgot back in
______________________________________________
Current- '21 430 , '19 911, 07 M6 ,'17 Jeep Wrangler, "23 Bronco OBXluxsquatch |
03-20-2017, 11:48 PM | #6 |
Just Copacetic!
177
Rep 616
There's a long thread on this issue:
http://f30.bimmerpost.com/forums/sho...=Lock+actuator I have a 2016 428i GC and there's a SIB on the lock cable also, not sure if this would include your 428i http://www.bimmerfest.com/forums/sho...d.php?t=954529 |
03-21-2017, 05:32 AM | #7 |
Motiphd
122
Rep 232
It looks like this is becoming more and more common across the model range. The first I heard of this was in a guys X5M that had an electrical fire start and the door pin would not raise. Is the door pin mechanism when you pull the handle 100% manual? If so, how does this happen?
2016 535i xDrive M-Sport | 2016 328 xDrive w/Lighting (hers)
2012 VW Jetta GLI 6MT APR Stage 2 (retired) | 2012 VW Tiguan SEL 4Motion (hers/retired) 2012 Acura TL SH-AWD Advance (retired) | 2012 Acura RDX Tech (hers/retired) 2010 Acura MDX SH-AWD Advance (hers/retired) |
03-21-2017, 08:42 AM | #9 |
Rep 1,668
this issue sounds more common that it should.
Enjoying an E89 Z4, F30 320i and Fiat Abarth //
E85 Z4 (sold), E82 128i (sold), Fiat Pop 500 (sold) |
03-21-2017, 11:43 AM | #10 |
Rep 1,615
I also thought when you pull the handle, it somehow manually releases the lock since there is no "electronic" sound. An actuator does this? I know this is the case when we use the center unlock/lock button and comfort access but the handle too? If so, it's awfully quiet.
03-21-2017, 02:36 PM | #11 |
Rep 536
Drives: 2013 335xi Alpine White
I'm having this exact problem "fixed" by my dealership. I use that term loosely because it's been there now 3 times for the same thing. Unfortunately, the dealership is stubborn and won't do the right thing...so I keep bringing it back, and now I'm driving a rental car around at their expense...all because they won't replace the $22 bowden cable that is the root cause of this issue.
TSB 51 26 15, dated Sep 1, 2015 describes the problem when the bowden cable malfunctions in cold weather. Rerouting of the cable is recommended. I think others have mentioned that their dealerships just replaced the cables and all was good. |
03-22-2017, 11:16 AM | #12 | |
Motiphd
122
Rep 232
03-22-2017, 11:24 AM | #13 | |
Rep 536
Good thing is I now have the Service Foreman's contact info and he and I get along well. |
03-22-2017, 11:27 AM | #14 |
Rep 5,993
Does this mean you can't open the door if the battery dies? Seems odd that this wouldn't be a mechanical door handle that triggers the lock pin as it clearly seems to be.
03-22-2017, 11:31 AM | #15 | |
Rep 5,993
03-22-2017, 11:32 AM | #16 |
Rep 370
Drives: 2013 AW 335i
It's happened to me a few times as well. I had to press the unlock button near the center of the car for it to actually unlock.
And when it did unlock it made a kind of slower unlock sound... Took it to the dealers and they said a cable was getting caught or something. Afterwards it still happened once. But it recently it hasn't happened at all so I decided not to take it into dealers for now
2013 Alpine White 335i -M Sport/// Akrapovic Catback Exhaust/// KW Street Comfort Coilovers/// BMS intake/// JB4/// ER front mount intercooler/// ER Charge pipe/// ER catless downpipe/// 18" Apex Arc-8 in Anthracite/// Michelin Pilot Super Sports
03-24-2017, 12:51 AM | #18 |
Rep 349
This started happening to my 2014 228i.
If you are able to get out after the double-pull, be careful as the window will not go down. Happened twice to me where the window slams on the frame when closing the door. You can also code for all doors to unlock when you shut off the engine. |
11-29-2020, 07:27 PM | #21 | |
Rep 743
I still don't understand how rerouting a bowden cable has anything to with the cold weather. |
11-29-2020, 09:49 PM | #22 |
Rep 153
Drives: 2014 428xi Sport Line
Just happened yesterday. Only the passenger door for me.
I am out of warranty although I am going to tackle as DIY. Also going to replace the drivers side interior door pull as it’s sticky even now with cooler temps on hand in North Texas. |
