11-30-2020, 05:42 AM | #1 |
Rep 39
Wagner VS MTC VS eBay special???
Hi I'm ready to make a purchase on a new I/C for my F32 435d.
I just want to know if spending the extra on a Wagner EVO 2 (£700) is really worth it? over a MTC one as they cost less than half at £300, and looking on eBay there's some Chyna specials around £250 which is even cheaper. I know old saying you pay for what you get, cheap and nasty etc, but if anyone could shed some extra light that would be great and appreciated, or if anyone has any experiences with either of the intercoolers? Cheers! |
11-30-2020, 11:12 AM | #2 | |
Rep 2,069
They're a complete waste of money if you're thinking you're going to get any more power from one. Even if you're mapped. You're not. This discussion has been done to death over the years. If you're replacing a broken one, MTC do make good stuff. I've bought from them before.
/// BM3 + M-Power ///
11-30-2020, 11:32 AM | #3 | |
Rep 39
11-30-2020, 11:38 AM | #4 | ||
Rep 2,069
No benefit in this country at all. Someone with some technical knowledge will be able to explain. Possibly Tengocity ? His old F31 335d was heavily modified.
11-30-2020, 11:50 AM | #5 | |
Rep 39
11-30-2020, 01:32 PM | #6 |
Rep 8,493
Why do you feel that you want to change the IC ? As a purely stand alone mod it won't make a significant difference unless your car is remapped and you're working it hard on a hot day (track session etc).
Before doing anything I'd install an OBD data logger (OBD Fusion is one option) and record/plot the IAT and AT for several sustained full throttle pulls through all of the gears. You'll need a very long stretch of quiet road and your eyes peeled for the boys in blue. Or a track. My car is remapped and has the IC from a 35d which was part of the MPPK kit which I had fitted for a short while. There's typically a 3-5°C temperature difference between the IAT and AT and although this can increase slightly if I'm working the card hard I've not seen runaway temps which might indicate heat soak. If you really want to change the IC then I'd recommend you do your homework. There's a lot to consider in terms of tube & fin, bar & plate, size, airflow routing, pressure loss & lag, manufacturer & price. If I was in the market I'd most likely go with ATM or Evolution Raceworks.
12-02-2020, 02:14 PM | #7 |
Old Fart
361
Rep 693
If you're really set on changing then have a look at Darkside, they do a Wagner clone for a lot less.....
https://www.darksidedevelopments.co....x-f3x-f87.html
The doctors said it's OK to listen to the voices..... just don't do what they tell me
12-02-2020, 03:40 PM | #8 | |
Rep 8,493
20 minutes more like. For £250 the IC itself looks OK from the outside, and being bar & plate it'll be robust, but without further details about the internals (i.e. airflow routing) it's hard to know how effective it'd be.
12-02-2020, 05:44 PM | #9 | |
Rep 595
12-03-2020, 02:17 PM | #10 | |
Old Fart
361
Rep 693
Snowflakes: I'm from Yorkshire so I can take the p*ss out of the accent if I want
12-03-2020, 02:22 PM | #11 | |
Rep 8,493
Can be tricky, but useful nevertheless, to know what gains are attributable purely to the IC.
12-03-2020, 03:07 PM | #12 |
Rep 595
Yeah I havnt got a direct comparison as the two maps were done nearly a year apart. Albeit by the same place but with different temperatures etc, its not to easy to compare. The first map pulled 397bhp then the next map was applied and achieved 422 with the cooler. the pre dyno run on that occasion pulled 409bhp
