11-04-2021, 05:54 PM | #89 |
Rep 125
Latest logs with MAF unplugged and a good 300+ miles since flashed. FP is stable. Some timing corrections and weird lean AFR events that may be related to pre-ignition, since I see timing corrections but no knock registered. I see throttle closures but i believe that is because the boost target was reached or perhaps to address lean AFR's?
With the FP stable, I am considering adding some E85 after I run the new MAF to see if that helps the timing corrections. https://www.bootmod3.net/log?id=6184...729b695b0719cd https://www.bootmod3.net/log?id=6184...729b69de5fab72 I should have my new MAF tomorrow. I plan to install and plug it in without resetting adaptations or flashing new. Once I have miles on that configuration I'll post up new logs which hopefully will confirm that the FP problem was caused by the original MAF. |
11-10-2021, 03:23 PM | #90 |
Rep 206
I'm really curious to hear if this resolves your issue as I'm having the same problem and getting the same codes. We have similar setups, same car (mfg date of 8/13) but I'm running MHD. Recently installed a Fabspeed catted down pipe and started getting a fuel system crash only during track sessions but within 10 minutes of driving 10/10. Has happened on stage 1 and 2, 91 octane gas. I've had some overheating issues as well, but this problem didn't appear until the downpipe was installed. Maybe just a coincidence, but I'm suspicious of that upgrade.
It doesn't look like you ever swapped out the fuel control module. Just curious if you've considered that as I've been told mine may be overheating and/or failing. I've also been told it's the HPFP that is overheating and/or failing. |
11-10-2021, 05:20 PM | #91 | |
Rep 7,597
11-11-2021, 03:07 PM | #92 | |
Rep 206
Here's the log right before and after it happened: https://datazap.me/u/rphz/fuel-crash...data=4-9-19-20 Curious what you think and TIA. |
11-11-2021, 03:34 PM | #93 | |
Rep 7,597
His is the opposite - the car goes suddenly rich (way beyond normal) and the car can't supply sufficient fuel to keep up. His issue is with abnormal fuel trims driving the rich condition that leads to fuel pressure crash. In your case you just lose fuel pressure, but it doesnt look like it has anything to do with fuel trims, AFR target, etc. The reason for his crash is clear, but yours is not, and does not seem to be the same reason. |
11-11-2021, 10:04 PM | #94 |
Rep 125
The situation on my car is a case of fuel trims and adaptations causing FP crashes.
I'd look at your LPFP and EKP. If the pump is wearing out it will draw more amps at WOT on the track the EKP can overheat. |
12-01-2021, 05:30 PM | #96 |
Rep 125
I have been meaning to post an update.
PTF had sent me another tune a while back that is basically a weak stage 1 tune that doesn’t crash the fuel system but is even less performance than the JB4 I removed for the BM3 platform. I was expecting more than 13 psi boost for my $600. In an effort to cover all the possible causes, I removed all intake plumbing from the air cleaner to the turbo hot side charge pipe, looking for intake leaks. I found nothing and reinstalled everything and smoke tested the entire intake tract with zero leaks found. As it stands with the issue unresolved, I’m running the OTS ACN stage 2 tune with the MAF unplugged and that seems to be the best compromise. The logs still show some odd lean swings, which the system tries to address, but not to the point of completely crashing the fuel pressure. I’m not expecting anything more from PTF’s to try to “tune” this problem out. Once again, the car runs fine with the stock tune. I reviewed my old JB4 logs and they don’t show any of the lean events or severe fuel pressure drops I get with the BM3. If I was committed to this car long-term, I’d probably try MHD, but I’m done throwing money at this problem. |
12-01-2021, 06:03 PM | #97 | |
Rep 7,597
EDIT: also did you ever install a new MAF? |
12-01-2021, 06:09 PM | #98 |
Rep 125
New MAF installed, made zero difference.
https://www.bootmod3.net/log?id=6198...90c62d319cf171 https://www.bootmod3.net/log?id=6198...0b436c0e83015c |
12-01-2021, 06:35 PM | #99 | |
Rep 7,597
Interestingly you still do have some HPFP dips, but it doesnt seem to be for the same reason as before. The LTFT are basically zero (1 in the logs) and only small STFTs, and no rich condition as before that was causing the dips. The the dips dont seem to be significant enough to affect AFRs or fuel trims. |
12-01-2021, 08:18 PM | #100 |
Rep 125
I've added HPFP Angle Final and HPFP Regulator Output to the dashboard for future logs. A bit slammed with another project, so I'll add some new logs to this thread when I get a break.
The crazy LTFT's seem to be tied to MAF output, so I'm running unplugged which seems to have a slight negative impact on fuel mileage but does allow a stg 2 tune with decent power. The fact that I don't see any of this with the stock tune or the JB4 again points to the tune or platform. |
12-01-2021, 08:32 PM | #101 |
Rep 643
Ptf/halim has been unresponsive with me as well for a week as we try to figure out my particular issue of dme going to open loop when I shift under wot. 6mt here with wmi. I was on test map 3 which sounds similar to yours with boost around 13 psi. I'll continue to ping him at least until he positively gives up.
He's been having me do logs with MAF disconnected. Makes no difference in my case.
M235i rwd 6mt
12-01-2021, 08:54 PM | #102 | |
Rep 7,597
12-01-2021, 08:57 PM | #103 | |
Rep 7,597
12-02-2021, 06:51 AM | #104 | ||
Rep 643
This effects me because I am using wmi as a fuel supplement, so when in open loop, hpfp is unable to give enough fuel and crashes. All the meantime the wmi is flowing and afr is rich.
M235i rwd 6mt
Tags |
bootmod3, n55 fuel pressure crashing |
