11-15-2018, 10:40 AM | #1 |
Rep 3
Mann's oil filter on BMW 428i
Anyone knows the difference between HU816X and HU816Z kit?
which one to use on 2014 BMW 428i xdrive? Some online shop says HU816X can be used on 428i however Mann's online catalog says differently. However, they do share the same dimension and so. Very confused, anyone has any insights? |
11-15-2018, 10:58 AM | #2 | |
Rep 5,457
https://catalog.mann-filter.com/NA/e...20A%20(T228932) |
11-15-2018, 11:02 AM | #3 |
Rep 5,457
Is there a reason your hesitant to just buy this?
https://www.ebay.com/itm/Oil-Filter-...DPbo:rk:1:pf:0 |
11-15-2018, 11:23 AM | #4 |
Rep 16,088
The X includes a new washer to be used with the metal drain plug on a metal oil pan. The Z includes a new plastic drain plug to be used with a plastic oil pan. My N20 xDrive has a metal pan, so I use the 816X. I believe yours does as well.
11-15-2018, 12:40 PM | #6 |
Rep 5,457
Billfitz EM_F30
Not doubting either of you... I have a RWD... But why does Mann's official catalouge recommend the wrong part for his car (according to you guys). Isnt that a bit scary? Something must be off, no? |
11-15-2018, 12:51 PM | #7 |
Rep 158
they're both the same filter, the only difference is in the drain plug. If he has a metal drain plug he needs to get HU816X if he has a plastic drain plug he needs to get HU816Z. it's weird that Mann catalog recommends HU816Z because he probably has a metal drain plug
11-15-2018, 12:59 PM | #8 | |
Rep 5,457
11-15-2018, 01:32 PM | #9 | |
Rep 3
11-15-2018, 01:35 PM | #10 |
Rep 3
Tags |
428i coupe, filter, mann |
