10-18-2021, 11:13 AM | #1 |
Rep 32
remote coder required!
Hi
I have just retrofitted an NBT evo 5, with 8.8" screen, atm module and touch controller with module, and also a HK sound system, i have come from a basic no nav system so fitted a loom for the atm and most cable for amp, along with various antennas ect for the NBT once fitted i was met with a blank screen, like there is no power, checked all connections and there fine, so assume its component locked, Got a set of fsc codes that come with an installer that also removes component lock, which ran successfully and installed the FSC codes but still nothing works and screen is still black, so upon inspection with esys (using 100% of my little esys knowledge!) i found that there is no CAFD file in HU_NBT2, spoke to the guy i got the fsc codes from and he was very helpful and gave me instructions on how to inject cafd file but its way over my head, and im worried i may do something irreversible! Sooo, is there anybody out there who is willing to do a remote coding session to get my system up and running? i am aware there is also some coding to do to get my HK system up and running, and probably other things im not aware of, not as easy as i first thought this retro fitting business!! cheers |
10-18-2021, 12:45 PM | #2 |
Rep 32
Just a quick update on this,
I followed the seller’s instructions and injected the cafd into the nbt successfully, but I still have a blank screen 🙁 |
10-19-2021, 03:11 AM | #3 |
Rep 525
Post picture of your CID and EVO label to avoid that you have wrong hardware.
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
10-19-2021, 03:52 AM | #4 |
Rep 32
Any way of getting this without taking it to bits again?
I have this info; NBT2 Serial#: 0008163147 NBT2 software version: NBTevo P18362l NET2 RAM: 4GB |
10-19-2021, 04:18 AM | #5 |
Rep 2,302
