08-14-2018, 09:51 PM | #1 |
Rep 2,601
Drives: G81 M3 Touring, GR Supra GTS
Mission Performance B58 Dyno results
I actually have a M140i but this seemed like the most appropriate sub forum.
I have been running the Mission Performance tune for the last two weeks. I’ve been happy with the drivability, drives like stock but just with more everywhere and much more up top when I’ve had the chance to wind it out. Finally got a chance to get the car on the dyno this morning and the results were better than I expected. The car has the stock intake with a K&N filter and stock downpipe. Running Australian 98ron fuel which is similar to US 93. It's worth mentioning up front that Australian dynos usually read a fair bit lower than US spec Dynojet numbers. We did three power runs with tune loaded and all were very consistent around 390whp, best was 391.8whp. Flashed it back to stock while still strapped down and did three runs, once again all very consistent with the best being 307.4whp. So 84 wheel horsepower gain from just the tune!!! B58 is a beast, even the dyno operator was surprised with the result. The Mission Performance tune also runs safer AFRs than the stock tune which stay around 14-15:1 the whole way. We couldn’t find somewhere to tap into to get a boost reading, but going off my P3 ODB gauge it looks like peak boost went from 12 to 18psi. I’ve ordered a BCS high flow catted downpipe to help it breathe a bit better. So will go back once that is on and I’m expecting over 400whp. For comparison two 1Ms were on the same dyno a couple of days ago and with intake, DPs, intercooler and MHD stage 2 tunes they both were around 350whp. Overall I wouldn't hesitate to recommend Mission Performance. Process was simple (you just need a laptop, an internet connection and an enet cable) and communication was easy. |
awilki0101518.50 440mppk_qc1.00 F30_SixSpeed1170.50 Vinnie Stix73.50 mookie45770.00 kern4174445.00 Beek707.00 B58togo807.00 B58 parts474.00 |
08-14-2018, 10:15 PM | #2 |
Rep 969
damn impressive!
08-14-2018, 10:49 PM | #4 | |
Rep 2,601
No more turbo lag than stock. It will turn the tyres from a roll if you floor it nearly anywhere in second gear (mine is a manual). I have 255/35/18 AD08R tyres on 18x9 Advan GTs. |
eluded3006.50 |
08-15-2018, 12:35 AM | #6 |
Rep 2,601
Stage 2.
08-15-2018, 12:46 AM | #7 |
Rep 196
Impressive. Would be great if we could get 90-100 whp from tune+intake+dp on 93 octane.
18 psi is great for 93 octane, my jb4 is struggling with anything above 15-16 psi on 93. |
08-15-2018, 03:40 AM | #10 |
Rep 1,348
390whp stock turbo is impressive and all car has is a k&n filter. Most fbo N55 335s are hard pressed to do that. Said most not all.
Still with just a filter mod again ,impressive!!
2k15 335i Msport xdrive 6spd
Wagner Comp2 FMIC,FTP CP,stock exhaust. Fabspeed Sport catted DP, KW V2 coil overs,FBO BM3 Stg 2 |
08-15-2018, 03:53 AM | #11 |
Rep 2,601
08-15-2018, 08:00 AM | #12 |
Rep 474
So the only mod that might have an effect is the air filter, (besides the tune)?
Any chance running Stage 2 with the stock downpipe is going to cause a problem?
Looking for 335/n54
08-15-2018, 12:43 PM | #14 |
Rep 196
Looking at the stock number this dyno reads a bit lower then US dynojet numbers. Stock B58 numbers are normally in the 330 whp. So I expect this to be over 400 whp on a dynojet.
08-15-2018, 02:54 PM | #16 |
Rep 888
What he is referring to is most 340i's (non-MPPSK) dyno at around 330whp stock (dynojet) here in the states. It seems to be pretty typical for the newer B58 and S55 variant BMW engines to dyno at or above their crank rated hp values to the wheels.
08-15-2018, 03:01 PM | #17 |
Rep 196
BMS dyno'd their standard 340i on 330 whp, the m140i and m240i should be a bit stronger. The dyno they use is a bit the standard here on the forum and makes it easy to compare it to different cars/tunes. So if the delta is 80 hp it would push it in the 400 whp range. Which can be explained if it pushes 18 psi.
Ofcourse every dyno read different. But it is known that bmw underrates the power on their(turbo) cars last years. Hope we will see a US dyno sheet soon with stage 2 figures. |
08-15-2018, 03:42 PM | #18 | |
Rep 1,368
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ Pure 800 cast/ DS2/ E40 Doug Newton tuned/ ER catless DP/ Remus axle back/ BMS intake/ FTP CP/ M Performance LSD
08-15-2018, 04:30 PM | #19 |
Rep 1,800
Bingo. Let's worry more about the percentage gain from whatever you was running to what you are.
I know I gained 20% over mppsk for my vehicle from the before / after run and I'm 28% up from someone running a relatively stock car - panel filter + exhaust. Let's say 30% up on stock. This ties in with the 10% gain over stock for mppsk. Unless you've got multiple cars on the same Dyno on the same day it's really hard to work stuff out. |
08-15-2018, 08:12 PM | #20 | |
Rep 2,601
There are no additional pops and bangs. |
08-15-2018, 08:15 PM | #21 | |
Rep 2,601
Dyno dynamics is the most common type of dyno here and I've had comments from Australians that 300whp seems high for a stock number. But it's still a ~30% gain. |
08-15-2018, 10:07 PM | #22 |
Rep 1,368
My buddy and I put my ER catless DP on today, and I am SO READY to pull the trigger on this Stage 2 flash. Throttle response is now instantaneous, and damn, those overrun crackles and pops.....
