BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Oil in coolant tank, oil cap clean
      06-21-2021, 02:40 PM   #1
Logicoeur
Logicoeur's Avatar
990
Drives: F30 335i xDrive
Currently diagnosing oil in my coolant tank . "Low coolant" has come on 3x the last two days. No visible coolant or sludge on the oil cap. Did the OFHG and flush a few years ago, and no visible leakage anywhere at the front of the engine or near the cooler.
Recent maintainence was just the oil pan gasket (couple months ago) at an indy. Could this residue in the tank be an artifact from that work?
I can't find the specific procedure for working on the oil pan gasket, so I've attempted to work backwards from "oil sump removal" and "replacing connecting rod bearings" in maintence docs. Doesn't look like "draining coolant" is required to remove the oil pan. Also can't find any diagrams for the coolant passages in the block.
Am I looking at the OFHG again, or something worse ?
      06-21-2021, 05:19 PM   #2
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Worst case is blown head gasket. There's a kit which attaches to the cooling system. It contains a dye that reacts with hydrocarbons.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      06-21-2021, 06:05 PM   #3
thejeremyman9
thejeremyman9's Avatar
4358
Drives: 2015 BMW 335i
How sure are you its actually oil in the coolant tank?
      06-22-2021, 06:46 AM   #4
Logicoeur
Logicoeur's Avatar
990
Pretty sure. The tank is pretty new as you can see. Radiator fan went out almost two years ago and a lower hose burst. Coolant was flushed that time and tank purchased new, liquid was blue. Prior to that OFHG around 55k. Car is at 85K now on an oe OFHG.
I'll dip a napkin in and see if I can a extract some of the liquid.
      06-28-2021, 09:25 AM   #5
Logicoeur
Logicoeur's Avatar
990
Definitely oil.
      06-28-2021, 09:40 AM   #6
auburnf30x
auburnf30x's Avatar
435
Drives: 2017 BMW 330i xDrive
Yup, in the first post the second picture (of the cap) shows that milky residue that is unmistakable for coolant/oil mixture. Presence of that on the cap indicates a fairly significant contamination, unfortunately.
2017 330i xDrive Imperial Blue Exterior / Venetian Beige Leather with Oyster Accent Interior / Anthracite Wood Trim
F32Fleet3566.00
      06-29-2021, 03:06 PM   #7
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Originally Posted by Logicoeur View Post
Definitely oil.
Yep. Hopefully the OFHG is pinched and letting oil into the coolant.
Let us know
      07-01-2021, 08:07 PM   #8
435GranC
435GranC's Avatar
Drives: 2016 435i GranCoupe
Oil cooler or trans cooler issue maybe
      08-09-2021, 11:26 PM   #9
silvermullet
Drives: BMW 335i X-Drive
Question Oil cooler thermostat gasket
hey all,
diagnosing the same problem here. oil in coolant tank. no coolant in oil. no indication that its a head gasket.
previous owner said they did oil cooler gasket while doing the OFHG, but after I opened it up, it appeared that the gasket was changed however the old gasket material wasnt cleaned up properly around the coolant chamber... and it appears that there are marks indicating where the oil was pushed into the coolant chamber due to failure in the seal.
can anyone confirm my logic here?
also, any tips on how to get the mating surface cleaner? it feels pretty smooth. just used a toothbrush, cloth and brake cleaner.
thanks in advance!
      08-24-2021, 04:04 PM   #10
minh94086
Drives: 328i Sportline
I think it's the OFHG, i just replaced mine yesterday and when i bleed the cooling system there was oil in my reservoir. Now i have to take it apart again and also flush my cooling system. I think the gasket didn't seat correctly.
      08-24-2021, 05:09 PM   #11
Logicoeur
Logicoeur's Avatar
990
Just to update this I got the OFHG done again with a flush. Still expect some oil to appear after the flush as there are just too many places for it to hide.
Now the kicker, I was going through my docs for all the work that has been to the car over the years. Found the papers from the first time I had to do the OFHG. The shop notes they flushed the system bit it will definitely need another flush soon. I believe now that all the oil I found recently was just the remainder from the original work. It wa never flushed again in between as I never recalled to check again . So it seems like I payed for the OFHG to be done again when all I need was another good flush smh. Lesson learned.
      08-24-2021, 06:26 PM   #12
thejeremyman9
4358
So is oil in the coolant unavoidable with OFHG and therefore coolant flush required? I don't recall seeing that ever really mentioned in DIYs or anything.
      08-24-2021, 07:42 PM   #13
Logicoeur
Logicoeur's Avatar
990
It seems to be entirely dependant on how the gasket fails since oil and coolant passages are separated by the same gasket.
      09-16-2021, 08:34 PM   #14
silvermullet
how is your car now?
im still having oil get into the coolant tank. had the OFHG work done again, but still oil and shop said pressure building in the coolant tank.
i think im screwed. will probably trade the car in.
we just picked up the car a month ago... there was no oil in the coolant then and car drives fine. think we got f*cked over.
      09-17-2021, 07:58 AM   #15
123Britt
Drives: 15 M235i AT
Ofhg - oem only
I would really make sure both Gaskets are BMW OEM.
Made in Japan.
      09-17-2021, 08:06 AM   #16
Logicoeur
Logicoeur's Avatar
990
It's fine now. Could prob use another coolant flush to get an remnants out. The second ofhg work was unnecessary. It just needed a flush
      09-18-2021, 10:19 AM   #17
MTWO
Drives: M2
Nice
