07-13-2018, 01:11 PM | #1 |
Rep 48
bc racing coils
I'm looking to buy a set of bc racing coil overs for my 340 and am looking to see what other people think of them. All thoughts on them are welcome.
07-15-2018, 01:47 PM | #2 |
Rep 1,934
There are so many threads reviewing these
kern4174446.50 |
07-24-2018, 01:17 PM | #3 | |
Rep 320
I am running the max spring rates before they make you go with the extreme low kit or swift springs. so its really stiff but i like that...most ppl would probably find it a little harsh. it really depends on your application. it is a very good product IMO but i encourage you to do some homework on your spring rate selection. this is something that should be calculated. Also remember that the shocks are fully rebuildable and they use bilstein internals...you would be getting great bang for the buck. there's is one tidbit however. the end link attachment for the collar on the right front side is oriented the same way as the collar for the left front side...this is not the case on the factory shock setup. I haven't noticed a difference in handling as a result of this but it is something to note. I have pics if you would like to see what i mean.. |
