BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Is it possible to clear check engine codes with Esys / an ENET cable?
      03-05-2015, 02:50 PM   #111
petau
Thanks as always shawnsheridan!
      03-14-2015, 02:30 PM   #112
YMB-M3-J2
YMB-M3-J2's Avatar
Drives: YMB M3
PM sent.
shawn can you PM me the link as well?
      03-14-2015, 02:32 PM   #113
shawnsheridan
shawnsheridan's Avatar
PM sent.
      03-14-2015, 08:54 PM   #114
YMB-M3-J2
YMB-M3-J2's Avatar
Drives: YMB M3
Where do I find the German version of tool32? I can only find the English one.
      03-14-2015, 09:09 PM   #115
shawnsheridan
Hit Ctrl-T, and uncheck the "English Version" box.
      03-14-2015, 10:22 PM   #116
YMB-M3-J2
YMB-M3-J2's Avatar
Drives: YMB M3
Thanks Shawn.
      03-15-2015, 05:46 AM   #117
rustyminded
rustyminded's Avatar
248
Drives: BMW 328i
Is it possible to read errors not just delete, cuz I noticed whenever I go to dealer with car coded they tell me I have errors in seatbelt, A/C, cluster and all those are coded !
F30 328i - 8 auto.. JB4-EWG harness, OCC, Injen Intake, AFE Scoop, AFE dp, AA axle-back - H&R springs, H&R Rear SB, Front Strut, F&R BMS spacers..
      03-15-2015, 07:42 AM   #118
shawnsheridan
You need ISTA/D (Rheingold) for any meaningful reading and interpreting Error Codes.
      03-18-2015, 12:48 PM   #119
hellrotm
Drives: F80
Originally Posted by 9114s View Post
Hello could you send me the last tool32?
I would like to clear the airbag fault.
thanks Chris
PM sent.
Could you send a copy to me as well? I need to clear a check engine light.
Thanks in advance!
      03-18-2015, 01:01 PM   #120
squidlyboy
squidlyboy's Avatar
Drives: 2014 Alpine White 328i M-Sport
Originally Posted by Lucardos View Post
I only have one problem that i don't get away. After coding my rear PDC stopped working. every time i put it in reverse i get error "no parking assistance, have the problem checked by service"
Can I do al VO code for all CAFD again, this time with no engine running, without causing problems.
could it be that during my previous VO coding something else was set wrong?
Just curious if you ever solved your problem by VO coding again from scratch?
      03-18-2015, 03:51 PM   #121
shawnsheridan
Thanks in advance!
PM sent.
      04-05-2015, 05:37 PM   #122
Liquidpaper
Liquidpaper's Avatar
Drives: '15 M235i
2015 BMW M235i  [0.00]
Can I get the most recent tool too? Will it let me view/clear CEL codes? Thanks.
      04-05-2015, 07:17 PM   #123
shawnsheridan
You can do both, but reading them is meaningless as it is just cryptic codes.
PM sent.
      04-19-2015, 08:24 PM   #124
brh189
Drives: f30
Hello Lucardos after coding did you incounter these errors Drivetrain and fuel pomp if so how did you fix this
      04-19-2015, 10:25 PM   #125
shawnsheridan
Before worrying about clearing errors, verify if your DME module(s) have CAFD with Green Dot on them. I am guessing yours is missing.
      04-22-2015, 08:16 AM   #126
guztaka
Drives: E46
Hi shawn.
I want clear check engine light could you send me copy please?
thanks
      04-22-2015, 11:53 AM   #127
shawnsheridan
Originally Posted by guztaka View Post
Hi shawn.
thanks
A copy of what? E-Sys? Tool32?
      04-23-2015, 05:34 AM   #128
guztaka
Drives: E46
I already have e-sys version 26 with ENET cable.
Is it enough for clearing check engine light??
Do I need to get TOOL32?
      04-23-2015, 12:01 PM   #129
shawnsheridan
You can try clearing it with E-Sys:
  • Click "External Applications" in the left menu.
  • Click "External Application"
  • Double-click "Transmitter"
  • Scroll to the bottom and double-click "... Clear all DTCs ..."
      04-24-2015, 04:23 AM   #130
guztaka
Drives: E46
Wao
Thank you.
Two questions
Can I clear another check light with this external application ? (e.g. ABS check light) and what is TOOL32 used for??
      04-24-2015, 04:56 AM   #131
shawnsheridan
It clears all error codes. If ABS light does not clear, then some other issue exists like ACSM needs to be locked first.
Tool32 is ECU diagnostic software hat is part of EDIABAS.
      04-24-2015, 06:34 AM   #132
guztaka
Drives: E46
Shawn
Thank you.
Where can I get TOOL32?
Because I have esys 26 but couldn't find EDIABAS program folder.
I'm sorry for many questions.
