BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > NBT retrofit flash help!
      03-16-2024, 12:49 PM   #1
jozza66
Drives: F31 335dx
I've just installed an ID6 NBT Evo, with touch screen and ZBE4 into my 2016 F31. The car was previously running ID4 evo with a 3G ATM.
The new NBT unit is in and working, last step is to flash the NBT, ZBE & ATM to the same i-step as the rest of the car. I'm getting an error when flashing - I think linked to the fact the software on the retrofitted modules isn't the same version as esys is expecting. How can I determine the i-setp of the retrofitted ecus? (stupidly didn't get this info!).
Question 1 - is the i-step mismatch the issue here? How do I get what level the NBT & ZBE are at?
Question 2 - Have I screwed up reading the FA, looks like the car still thinks there's a ZBE3 there?!
TAL logs below - any pointers gratefully received!
TAL execution started.
ExecutionID=2024/03/16-17:18:54.386
[] prepareTALExecution started [PROGRESS]
[] prepareTALExecution finished [PROGRESS]
[] prepareVehicleForFlash started [PROGRESS]
[] prepareVehicleForFlash finished [PROGRESS]
[] SVK-Ist does not match expected SGBMIDs for ecu ECUId:HU_NBT2_0x63. Excpected (relevant process classes only): [hwel_000022e4-001_002_003], Actual (relevant process classes only): [hwel_00002fc3-001_004_001], Missing SGBMID(s): [hwel_000022e4-001_002_003], Surplus SGBMID(s): [hwel_00002fc3-001_004_001] [THROWABLE]
[HU_NBT2 - 63] There was an error during TAL execution, please check the log files. [WARN]
[HU_NBT2 - 63] - [Exception - HU_NBT2 - 63] SVK-Ist does not match expected SGBMIDs for ecu ECUId:HU_NBT2_0x63. Excpected (relevant process classes only): [hwel_000022e4-001_002_003], Actual (relevant process classes only): [hwel_00002fc3-001_004_001], Missing SGBMID(s): [hwel_000022e4-001_002_003], Surplus SGBMID(s): [hwel_00002fc3-001_004_001]
[HU_NBT2 - 63] installECUBL started [PROGRESS]
[HU_NBT2 - 63] installECUBL finished [PROGRESS]
[HU_NBT2 - 63] finalizeECUBLUpdate started [PROGRESS]
[HU_NBT2 - 63] finalizeECUBLUpdate finished [PROGRESS]
[] SVK-Ist does not match expected SGBMIDs for ecu ECUId:ZBE3_0x67. Excpected (relevant process classes only): [hwap_00000209-255_255_255, hwel_000011b1-003_002_000], Actual (relevant process classes only): [hwap_00003739-255_255_255, hwel_0000230f-002_001_001], Missing SGBMID(s): [hwap_00000209-255_255_255, hwel_000011b1-003_002_000], Surplus SGBMID(s): [hwap_00003739-255_255_255, hwel_0000230f-002_001_001] [THROWABLE]
[ZBE3 - 67] There was an error during TAL execution, please check the log files. [WARN]
[ZBE3 - 67] - [Exception - ZBE3 - 67] SVK-Ist does not match expected SGBMIDs for ecu ECUId:ZBE3_0x67. Excpected (relevant process classes only): [hwap_00000209-255_255_255, hwel_000011b1-003_002_000], Actual (relevant process classes only): [hwap_00003739-255_255_255, hwel_0000230f-002_001_001], Missing SGBMID(s): [hwap_00000209-255_255_255, hwel_000011b1-003_002_000], Surplus SGBMID(s): [hwap_00003739-255_255_255, hwel_0000230f-002_001_001]
[ZBE3 - 67] installECUBL started [PROGRESS]
[ZBE3 - 67] installECUBL finished [PROGRESS]
[ZBE3 - 67] finalizeECUBLUpdate started [PROGRESS]
[ZBE3 - 67] finalizeECUBLUpdate finished [PROGRESS]
[] SVK-Ist does not match expected SGBMIDs for ecu ECUId:ATM_0x61. Excpected (relevant process classes only): [hwel_00001f63-203_003_003], Actual (relevant process classes only): [hwel_000026ab-232_006_006], Missing SGBMID(s): [hwel_00001f63-203_003_003], Surplus SGBMID(s): [hwel_000026ab-232_006_006] [THROWABLE]
[ATM - 61] There was an error during TAL execution, please check the log files. [WARN]
[ATM - 61] - [Exception - ATM - 61] SVK-Ist does not match expected SGBMIDs for ecu ECUId:ATM_0x61. Excpected (relevant process classes only): [hwel_00001f63-203_003_003], Actual (relevant process classes only): [hwel_000026ab-232_006_006], Missing SGBMID(s): [hwel_00001f63-203_003_003], Surplus SGBMID(s): [hwel_000026ab-232_006_006]
[ATM - 61] installECUBL started [PROGRESS]
[ATM - 61] installECUBL finished [PROGRESS]
[ATM - 61] finalizeECUBLUpdate started [PROGRESS]
[ATM - 61] finalizeECUBLUpdate finished [PROGRESS]
[] finalizeVehicleFlash started [PROGRESS]
[] finalizeVehicleFlash finished [PROGRESS]
[] prepareVehicleForCoding started [PROGRESS]
[] prepareVehicleForCoding finished [PROGRESS]
[] finalizeVehicleCoding started [PROGRESS]
[] finalizeVehicleCoding finished [PROGRESS]
[] finalizeTALExecution started [PROGRESS]
[] finalizeTALExecution finished [PROGRESS]
TAL execution finished [TAL_EXECUTION_FINISHED]
TAL-Execution finished with status: "FinishedWithError". [C207]
TAL execution finished. Duration: "3min 34s". [C206]
Read SVT after TAL execution started.
Read SVT after TAL execution finished.
Past Previous: E92 335i, CIC retrofit, JB+, Perf Exhaust
Last Car: MB ML350CDI, X800D-ML Retrofit, AMG Steering wheel, Brabus tuning box
Current car: F31 335d - NBT EVO ID6 retrofit, 3AG retrofit, Coded EBT, Deleted RFTs!!
      03-16-2024, 01:04 PM   #2
jozza66
Drives: F31 335dx
Some quick research suggests this might be the issue - shawnsheridan - does this seem likely?
"This "SVK-Ist does not match expected SGBMIDs for ecu..." means you have chosen an improper I-Step Shipment when you made your SVT Target (SVT_soll). Either the ECU is factory original, and you just chose the wrong I-Step Shipment, or the the ECU is non factory original, so it came with a different I-Step Shipment then your car's actual I-Step Shipment, and you have no way of knowing what the right I-Step Shipment is for it.
So, redo flash, but this time after you calculate SVT Target (SVT_soll), check the box that says "HW-IDs from SVTactual" and then Save it.
If it still does not work, the only thing you can do is try different I-Step Shipment dates until hopefully one works. This is simply Trial and Error. When you have the correct I-Step shipment, the HWEL in SVT Target will be Black (not Red or Blue)."
      03-17-2024, 10:26 AM   #3
Siki78
Siki78's Avatar
136
Drives: F30,G30
You will need change time criteria to 0718 and istep shipment would be than F20-18-07-500. Run tal calculation and see if hwel is black. If it is not black then correct your fa with missing SA option. Don’t push button HW-IDs from SVTactual if you doesn't know what you are doing.
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
      03-17-2024, 01:01 PM   #4
jozza66
Drives: F31 335dx
Thanks, resolved this morning after changing the I-step to the correct levels for the ZBE4 & NBT - ATM also re-flashed and all working.
