01-08-2020, 05:57 PM | #310 | |
Rep 40,774
01-09-2020, 06:34 PM | #312 |
Rep 40,774
PM sent.
01-10-2020, 12:34 AM | #313 | |
Rep 1,179
Drives: 2014 X5 50i M Sport, M3(sold)
LED retrofit
I'm trying to retrofit and code Adaptive LEDs on a G01 X3 using E–sys 3.27.1 (since running on a VM), do you know if this will work? If so is it the same VO option (0552 from what I've read) and procedure as FXX series? |
01-10-2020, 05:47 AM | #314 |
Rep 40,774
Launcher cannot run in VM, but if you are VO Coding 552 Adaptive LED headlight option, you do not need Launcher and can use E-Sys Direct, so you should be able to do this.
skoold2003791.00 |
01-10-2020, 09:31 AM | #316 |
Rep 40,774
PM sent.
01-10-2020, 12:18 PM | #317 | |
Rep 1,179
01-10-2020, 04:36 PM | #318 |
Rep 40,774
It should be same. Remove existing Light Option Code, (e.g. 522 Xenon Light & 524 Adaptive Headlights) add 552 Adaptive LED headlight, then VO Code BDC_BODY and both FLE Light Modules.
skoold2003791.00 |
01-10-2020, 05:20 PM | #319 | |
Rep 1,179
01-10-2020, 05:38 PM | #320 |
Rep 40,774
Injecting CAFD (Detect CAF for SWE) and Flashing ECU's with >= v.4.17.20 PSdZData requires using newer E-Sys 3.30.0 or higher. PM sent.
skoold2003791.00 |
01-10-2020, 09:22 PM | #321 | |
Rep 1,179
01-11-2020, 06:56 AM | #323 | |
Rep 40,774
skoold2003791.00 |
01-11-2020, 07:14 AM | #324 |
Rep 40,774
PM sent.
01-11-2020, 01:53 PM | #325 |
Rep 1,179
01-11-2020, 02:05 PM | #326 | |
Rep 40,774
https://mega.nz/#!p9JQhAwZ!JJ9ptw8Ti...JcnSUvG81nYMsw
skoold2003791.00 |
01-11-2020, 03:12 PM | #327 | |
Rep 4
01-11-2020, 03:36 PM | #328 |
Rep 40,774
PM sent.
