09-30-2022, 10:03 AM | #23 |
Rep 1,369
Just unboxed it and the outlet for the charge pipe is crushed in. It was packed right against the edge of the box. Pics to follow shortly. Mike, let me know how to proceed. Thanks.
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
09-30-2022, 08:01 PM | #24 |
Rep 1,369
Shout out to Mike @ x-ph as he has reached out to Pure and sent them pics of the damage. X-ph is a great vendor; support them!
10-01-2022, 10:35 AM | #25 |
Rep 1,457
Share a photo? Just curious to see what happened..it's a bit hard to process the charge pipe section getting crushed just from shipping. Mike is the best glad you purchased directly from him and Pure has great warranty and exchanges for any damages so I wouldn't be worried about it.
2024 X3 M40i
2014 BMW M5 |
10-01-2022, 12:16 PM | #26 |
Rep 1,369
Something heavy came into contact with it.
10-01-2022, 04:04 PM | #28 |
Rep 1,457
I wonder if the OEM turbo that's converted into the Pure would bend like that. They seem to be sturdy for sure someone dropped that box off the 3rd floor of a building.
10-01-2022, 09:56 PM | #29 |
Rep 1,369
Yeah, I had my mechanic lined up for this week for the install, but shit happens. Not the end of the world.
10-02-2022, 12:04 AM | #30 |
Rep 1,457
Once you slap that turbo on you'll forget everything else
2024 X3 M40i
2014 BMW M5 |
10-02-2022, 06:17 PM | #31 |
Rep 1,369
Hoping to get into the 6's, 60-130. I'm on revision 5 on this Jordan tune (not running well at all) and managed a 7.72 a couple nights ago. I'll probably knock out a few more revisions and call it done, then dyno tune the new setup next Spring. Does anyone know if Marin, Shoup or Botti work with Bootmod3?
10-02-2022, 06:30 PM | #32 | |
Rep 1,454
Marin = MG Flasher. Not sure about Botti. I think Doug Newton or Sameh might use BM3. My personal tuner was Racebox on BM3.
2022 CT4-V Blackwing 6-speed
B58togo808.50 |
10-02-2022, 08:42 PM | #33 | |
Rep 75
10-03-2022, 01:33 PM | #34 | |
Novice
303
Rep 695
10-03-2022, 05:48 PM | #35 | |
Rep 1,369
Yes, I believe so.
I'm on Dorch Stage 1, catless DP and E40,with a cheap VTT GC, so considering we don't know the DA variance between us, I'd say we're pretty close. Again, only on revision 5, so there's still room on the table. Just received revision 6, so we'll see how that goes. I appreciate the info on the tuning!
Antwan340i18.00 |
10-03-2022, 06:13 PM | #36 | ||
Rep 75
10-03-2022, 07:14 PM | #37 |
Rep 1,457
I seen log files from both CJ and PJ and they run lean as fuck and that ain't good for the pistons. Someone recently switched to Odin (I think) and they were very satisfied in the end.
2024 X3 M40i
2014 BMW M5 |
Antwan340i18.00 |
10-03-2022, 07:44 PM | #38 |
Rep 75
it seems hit and miss. I see some guys saying they love their tune from Paul and Cary, and some saying it's not running good
10-03-2022, 08:39 PM | #39 | |
Novice
303
Rep 695
I'm tuned by Doug and my logs look great. He's responsive and he knows his shit. Very humble guy and you get to directly speak with him. I'm sure Sameh is the same way as well. These are my logs with doug newton on E30 w/ TU pump. Once we get on DS2 im sure we'll be flying!! https://www.bootmod3.net/log?id=6306...729b57a4e400e1 https://www.bootmod3.net/log?id=6306...90c624de5241cd https://www.bootmod3.net/log?id=6303...0b432dfabc91f2 |
10-04-2022, 11:22 AM | #40 | ||
Rep 75
blacksapphire440i303.00 |
10-04-2022, 12:09 PM | #41 |
Rep 1,369
Got my return label and the turbo is going back today, so that’s good news.
10-05-2022, 02:18 PM | #42 |
Rep 99
+1 for F80 Paul, super responsive and he takes his time with your tunes. Lots of revisions and fast replies. He's done a 94+meth tune and I'm currently doing revisions on E50+meth.
2016 340i xDrive | Pure 800 | Dorch S2 | XHP S3 | bm3 | F80 Paul 94 + Meth Custom Tune | CTS Intake | VRSF Catless DP | BMS Elite CP | Snow Perf VC50 + Dual CM7 CPI | BC Racing BR Coilovers | Apec ARC-8 + Hankook Ventus RS4 |
10-05-2022, 02:33 PM | #43 |
Novice
303
Rep 695
I'd wanna see some of your logs especially if hes running a Meth + E tune on your motor. F80Paul tends to lean out on AFRs (as shown in my logs)
10-05-2022, 06:43 PM | #44 |
Rep 1,369
Just flashed/logged revision 7 from Cary for my E40/Vargas GC tune and the car is finally running smoothly; 7.75 60-130 @ 63 degrees. Hoping to get it wrapped up next week and will then install the Pure 800 cast/DS2 and will likely dyno tune next spring. Not sure who I'll have tune yet? Hoping for upper 6's, 60-130. If I have to bump the blend to E50, then so be it.
