BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > Final Results - DAW,DS2,E45 Blend
      08-04-2023, 03:14 PM   #23
blacksapphire440i
Novice
blacksapphire440i's Avatar
303
Drives: 2018 440i Gran Coupe
Originally Posted by M2C View Post
Whow, what a torque curve. 750nm until past 6,000 rpm. If my calculations are correct, this means 700hp to the crank at around 6,500 rpm. And absolutely clean. Almost no timing corrections. And even not too much timing ("just" 14,5 degrees, while others need 16-18 degrees, what could be a risk for the pistons). Must fell like a rocket!
Please do me a favour and do a 100-200 km/h measurement, if possible. I would say sub 6 seconds.
Putting a ton of pressure on the pistons too can also be risky too. These cast pistons are sh*t
      08-04-2023, 03:15 PM   #24
blacksapphire440i
Novice
303
Originally Posted by WrxToBeamerGuy View Post
Did you put it in dyno mode on the dash?
Yes diagnostic mode -> "Secret" menu -> Roller mode active -> pulls done in 5th gear
      08-05-2023, 10:50 PM   #25
talontdone
talontdone's Avatar
Drives: 2017 BMW 340Xi
Haha yes it’s a rocket! WrxToBeamerGuy has the car dialed in amazingly well. We both decided we would prefer boost to timing so to speak and so I’m probably running a tad more boost than most and a bit less timing advance. I’ll definitely get some draggy runs in here shortly, but yes the car absolutely boogies!
17 BMW 340iX / DAW UF/ DS2 HPFP
M2C40.00
      08-05-2023, 10:52 PM   #26
talontdone
talontdone's Avatar
Originally Posted by blacksapphire440i View Post
I'm gonna have to get my car dynoed again on an SAE dyno and having the dyno be put on AWD mode. My car in roller mode did not like being on the dyno whatsoever and I was dealing with the 2048 torque limiter the entire time
I think you and I probably make very similar power based off your logs I’d say 600whp+ for sure … you’re running more timing, but less boost. I bet she’s a rocket!
      08-05-2023, 10:54 PM   #27
talontdone
talontdone's Avatar
Originally Posted by B58togo View Post
Not sure on the weight of the car, but I’d guess 5.7-5.8 100-200 & 6.7 60-130.
2017 340iX and I weigh 220 so probably close to 4100 lbs
      08-07-2023, 03:49 AM   #28
M2C
Drives: BMW M140i xDrive
Ok, I thought it's RWD. In case of xDrive and due to the higher weight, I would guess around 6.2-6.3 seconds for 100-200 km/h. But let's see, when you test it next time :-)
      08-07-2023, 10:44 AM   #29
Oem.plus
Oem.plus's Avatar
Drives: 2017 m240i
Very nice numbers especially considering the DA. I recall your post of you wanting to get a bit more power and you were stuck between staying DI or running PI. Running PI would benefit you in the long run if you decide to build the motor and trans. But if you plan to keep it simple Xtreme DI or Spool performance DI plus the exhaust cam would be able to get you up to the 750whp+ range. I'd estimate TQ to be around 650 to keep the transmission happy.
We do need more data to confirm my theory but a good starting point would be other engines such as the LS motors which utilizes the LT4 pump (which is the same pump as the stage 2 pumps).
The link posted below is an example on how the corvette's upgrade their fuel system utilizing upgraded pump with an exhaust cam. I also attached information of what exactly this kit for their engines.
https://www.lingenfelter.com/PROD.ht...4#.WoxZrJM-fq1
"This kit includes a set of eight flow matched 27 grams/second direct injection fuel injectors, a 12.0 mm bore high flow direction injection fuel pump and a LPE GT35 camshaft featuring a 7.85 mm fuel pump lobe. This results in a pump displacement of 2.6 cc per camshaft revolution with flow testing showing volumetric efficiency exceeding 90%. This results in a high pressure fuel supply system that is able to support over 1200 lbs-ft of torque and 1435 HP at 6800 rpm (assuming 0.52 BSFC) with injector pulse widths of roughly 5.5 ms."
      08-07-2023, 04:50 PM   #30
talontdone
talontdone's Avatar
great information - thank you for sharing! I’ve decided I’m going to go with upgraded injectors from SPOOL. Stay tuned for the next chapter…
      08-08-2023, 12:07 AM   #31
blacksapphire440i
Novice
303
I would look into upgrading your HPFP while you're at it too. You will be able to squeeze out a tiny bit of power before you max out the HPFP. Like wait for the FX350. Spool FX200 gets out flown by the XDI/Spool injectors
M2C40.00
      09-05-2023, 03:43 AM   #32
Tech1930
Drives: BMW 340i, X1
I don't think 350 is coming out for gen 1, is it?
      09-05-2023, 04:13 AM   #33
B58togo
Drives: M240i
Keep us posted. I think I'm going to go this route as well. Are you doing the 50% or the 75% flow increase? Looks like about a $300 difference.
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
      09-05-2023, 01:11 PM   #34
McBobby Jr
McBobby Jr's Avatar
212
Drives: '18 240i xDrive
There was some confusion going around regarding the FX-350 for it being for Gen1, but it was only intended being built for Gen2. I thought the FX-350 would be for Gen1, but nope the FX-200 is what actually came out. Regardless, the difference in flow between the two HPFPs is minimal and the last 3 numbers represents bar pressure not flow. Perhaps in the future, HPFP R&D will be more sophisticated and limits will continue rising but it will be difficult as our platforms HPFP is quite maxed (on stock cam) and we only have 1 HPFP unlike the S55/S58.
current
'18 F22 240i xDrive - FBO
'16 F82 M4 ZCP - FBO
previous
'08 E90 335i Montego Blue
      09-05-2023, 05:17 PM   #35
WrxToBeamerGuy
WrxToBeamerGuy's Avatar
492
Drives: BMW 340i xDrive
CAM with a fuel lobe modification is the only way to increase flow beyond DS2.5 unfortunately.
      09-05-2023, 08:51 PM   #36
McBobby Jr
McBobby Jr's Avatar
212
Yup, it is what it is.
current
previous
      09-08-2023, 10:36 PM   #37
talontdone
talontdone's Avatar
I’ve actually decided to go with the XDI injectors, which I believe are +75% should arrive in about two weeks. Will pair these with the Dorch exhaust cam lift for a bit more fueling help across the board. Should be fun! Stay tuned.
      01-02-2024, 01:17 PM   #38
B58togo
Drives: M240i
Any updates on these injectors?
