12-28-2023, 09:11 PM | #1 |
Rep 6
I was trying to run stage 2 E30 on my b58 440i. When I push it to WOT the car seems to be misfiring by popping like crazy and not running smoothly. Can someone look at these logs to see what may be causing it?
I currently have a CTS turbo catted DP, BMS intake, and stock HPFP. Put approximately 5.3 gallons of e85 in tank, and rest 93 oct. I reached out to bm3 support and they told me my HPFP is crashing and needs to be upgraded. Any help would be greatly appreciated. https://www.bootmod3.net/log?id=6580...4f9d1d7849aee6 |
12-28-2023, 09:13 PM | #2 | |
Rep 950
Miceli190.00 |
12-28-2023, 09:22 PM | #3 |
Rep 6
I do see the massive dip. I have a b58TU pump coming in tomorrow. Any tips on how to correctly make an e30 blend? I think I put way too much e85 in for the stock system to handle.
12-28-2023, 10:12 PM | #4 | |
Rep 166
Miceli190.00 |
12-28-2023, 10:23 PM | #5 | |
Rep 950
https://www.morepowertuning.com/emix however with the tu pump what you put in should be fine, you're probably at e40 now. The best way to know is to buy an ethanol content analyzer kit for the gen1 b58 because it takes any guess work out of it! Pump gas may not always be e85 it could be much less. |
e30 4 life!115.50 Miceli190.00 |
12-30-2023, 07:59 PM | #6 |
Rep 6
Hey all. Posting an update in hopes of more help.
Car is not backfiring anymore after upgraded fuel pump to b58TU, however I am still noticing drops in pressure of my hpfp on bm3 stage 2+ 93. I lowered the boost to 17psi and still seeing drops but car is running OK. Here are the logs. Can someone confirm if this is normal or not? https://www.bootmod3.net/log?id=6590...d58e551565c475 https://www.bootmod3.net/log?id=6590...684d49af1770ef https://www.bootmod3.net/log?id=6590...a8ea58b161f6e1 |
01-04-2024, 05:29 PM | #7 | |
Rep 202
You can aim for ~E35 for ideal clean logs. Log and post Cheers |
01-04-2024, 08:17 PM | #8 | |
Rep 950
