BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > F30 pre lci halogen to lci full led headlight retrofit
      08-09-2020, 04:52 AM   #45
Jhnblckwood
Drives: F30 2014 320i xdrive
Originally Posted by turbovf View Post
what do you mean by "FA"?
I suggest u do more reading about coding before attempting this
      08-24-2020, 01:10 PM   #46
chambo622
Drives: F31 328i M Sport EBII
Hey folks. Attempted this install this weekend and hit a couple snags. Hoping those who have done this before can chime in:
Front fuse box - my car doesn't have the connector marked Z7*10B in the instructions, but I see where that would go, looks to be part number 61139228356 based on real OEM. So if I get that and plug in, I should be good?
FEM module: my car already has wires coming out of pins 20 and 21 on A173*2B and pins 49 and 50 on A173*8B. The instructions say, if pins already are there, "connect with mini-connectors." What does that mean?
My car is a 2016 with Halogens, btw.
      11-06-2020, 10:15 AM   #47
scoopy
Drives: f30 320d
where is the pdf file or instruction on how to do this? thank you
      11-17-2020, 01:55 AM   #48
JEFFERYLIEW
Drives: bmw f30
hi all. i just done my pre lci headlight to lci headlight.
now i have a problwm that have headlight vertical aim control failed.
and when i turn on the key, the light sometime will never come up.
anyone know how to solve it? thanks
      01-13-2021, 04:59 PM   #49
Mehrshaad
Drives: 2014 BMW 328i
Hi
I cant access newtis.info it says bmw closed it,
Can anyone send what was on newtis.info?
Because im retrofitting to Lci Non-Adaptive headlights
      04-10-2022, 12:22 PM   #50
Dima_1997
Drives: Bmw 320D
full LED headlights
retrofit halogen to full LED headlights is the same as for the F34?
      04-10-2022, 12:27 PM   #51
Jhnblckwood
Originally Posted by deneyer View Post
are you serious? if you take f30 you get the same as f34
According to this jerkoff I guess it’s the same. Just double check the wiring diagrams.
      04-10-2022, 12:32 PM   #52
Dima_1997
Drives: Bmw 320D
i don t have ....
can someoane sent me the wiring diagrams pls ?
      04-10-2022, 12:34 PM   #53
Jhnblckwood
Ista will have it. U might need it for the install to initialize leds or trouble shoot. I hope u have esys as well. All links can be found on this forum. Good luck!!
      09-26-2022, 04:10 PM   #54
MarcoV
MarcoV's Avatar
Drives: F31 318 LCI 2015-12
Anyone got tips for retrofit LCI Hallogeen to LCI led adaptieve?
What do I need besides the lights?
Coding?
Wiring?
Anything else?
      08-09-2023, 10:21 AM   #55
nitrowasabi
nitrowasabi's Avatar
Drives: F30 330e
2016 BMW 330e  [10.00]
F80 link on the OP is broken. Does someone have the pdf file?
      08-09-2023, 11:11 AM   #56
cjn
Drives: 2021 F40 M135iX
Just a thought for anyone who is only really wanting to replace 4 non-adaptive halogens with LEDs. All the expense and complication of buying LCI lights and wiring the FEM is a bit of overkill. On my 2014 F30 I just bought a set of aftermarket LED bulbs that were a very good match for the halogens' output pattern. Then I just had to code out the hot and cold monitoring with ESys. The difference was night and day (!). The beam pattern was excellent, with no complaints from other drivers.
I got my H7 LEDs here:
https://www.autobulbsdirect.co.uk/h7...adlight-bulbs/
The Twenty20 Compact bulbs were newly released when I made the change, but some of the later, more expensive bulbs may be brighter/more accurate.
      08-10-2023, 07:44 AM   #57
nitrowasabi
Drives: F30 330e
Unfortunately that's not an option in the UK. MOT Inspection manual section 4.1.4 specifies:
“Existing halogen headlamp units should not be converted to be used with high intensity discharge (HID) or light emitting diode (LED) bulbs. If such a conversion has been done, you must fail the headlamp.”
      08-10-2023, 08:26 AM   #58
cjn
True, but mine went through 3 MOTs without any issues.
      09-01-2023, 09:57 AM   #59
Ovas
Ovas's Avatar
Drives: Bmw 440i
Hello i have bmw f36 lci. I take off led adaptive and want to code lci led headlights.
What whats code shouda be? Now is 552. I have to decode high beam assistant?
Can someone explain how to do?
