08-24-2020, 01:10 PM | #46 |
Rep 175
Hey folks. Attempted this install this weekend and hit a couple snags. Hoping those who have done this before can chime in:
Front fuse box - my car doesn't have the connector marked Z7*10B in the instructions, but I see where that would go, looks to be part number 61139228356 based on real OEM. So if I get that and plug in, I should be good? FEM module: my car already has wires coming out of pins 20 and 21 on A173*2B and pins 49 and 50 on A173*8B. The instructions say, if pins already are there, "connect with mini-connectors." What does that mean? My car is a 2016 with Halogens, btw. |
11-17-2020, 01:55 AM | #48 |
Rep 2
hi all. i just done my pre lci headlight to lci headlight.
now i have a problwm that have headlight vertical aim control failed. and when i turn on the key, the light sometime will never come up. anyone know how to solve it? thanks |
04-10-2022, 12:27 PM | #51 |
Rep 765
04-10-2022, 12:32 PM | #52 |
Rep 12
04-10-2022, 12:34 PM | #53 |
Rep 765
08-09-2023, 10:21 AM | #55 |
Rep 47
F80 link on the OP is broken. Does someone have the pdf file?
08-09-2023, 11:11 AM | #56 |
Rep 332
Just a thought for anyone who is only really wanting to replace 4 non-adaptive halogens with LEDs. All the expense and complication of buying LCI lights and wiring the FEM is a bit of overkill. On my 2014 F30 I just bought a set of aftermarket LED bulbs that were a very good match for the halogens' output pattern. Then I just had to code out the hot and cold monitoring with ESys. The difference was night and day (!). The beam pattern was excellent, with no complaints from other drivers.
I got my H7 LEDs here: https://www.autobulbsdirect.co.uk/h7...adlight-bulbs/ The Twenty20 Compact bulbs were newly released when I made the change, but some of the later, more expensive bulbs may be brighter/more accurate. |
08-10-2023, 07:44 AM | #57 | ||
Rep 47
08-10-2023, 08:26 AM | #58 |
Rep 332
nitrowasabi31.50 |
09-01-2023, 09:57 AM | #59 |
Rep 7
Hello i have bmw f36 lci. I take off led adaptive and want to code lci led headlights.
What whats code shouda be? Now is 552. I have to decode high beam assistant? Can someone explain how to do? |
