04-16-2016, 05:04 PM | #45 | ||
Euro.Techniks-EAST
291
Rep 1,467
Now heres the airbag i got, "dual stage" you can see it clearly but the yellow connector has less pins going into it. doesnt match my stock one, it does plug in but i get the airbag error on my dash. toom it to my friend whos a mechanic at BMW he took my car inside and tried to clear the error code with their machines and it did not clear. heres his coworkers f30 msport factory msport steering wheel airbag connector, also dual stage US spec. different pins going into the yellow plug, not like the one i received. but the seller claims hes done plenty of these and never had an issue that i need to find a better professional to do this job. who is better than an actual BMW tech? The seller told me hed give me partial refund so i can fix this issue here, or send it back but i dont think he knows what hes talking about. something is obviously wrong.
05-24-2016, 04:38 PM | #46 |
Rep 588
Drives: F30 320d & G29 M40i First Edtn
^ Sorry to hear of your issues. The most obvious and perhaps cynical answer is that is it a non genuine airbag and he's scamming you?
Best option perhaps is partial refund if the rest of the wheel is fine and then buy a new airbag elsewhere? ---- Seperate question - as this seems the best place to double check; EU Spec F30's are ALL single stage yeah? I need to do this retrofit and don't want to get the wrong bloody one! I'm in the UK so any EU sale, single stage, should be OK? |
06-01-2016, 06:34 AM | #47 |
Rep 504
Alpin3_F30 : seller is absolutely right. If you have no idea what are you doing - go to the experts - they will do. If bmw "technics" cannot code your bmw maybe its time for them to change their job - e.g. to go farming instead of "fixing" bmw's. You have 2 stage airbag with valve, thats why 6 wires. Euro single stage airbag has 2 wires, but you can easily code even it to your US spec bmw (2 minutes job), so please stop telling that someone tried to fool you and find bmw specialists. not farmers.
P.S. its not enough to code airbag module, you must code FEM also, because it will show errors (in the FEM module) about incorrect multi function steering wheel electronics (its not airbag related), but bmw experts probably havent told you about this, right? |
06-27-2016, 03:12 PM | #48 | |
Rep 191
2012 335 2016 435 2019 440 GC |
06-28-2016, 12:01 AM | #50 |
Rep 191
what module/functions in esys? i've searched but can't seem to find where? all my steering wheel buttons work, only the airbag warning is present on the dash
06-28-2016, 02:24 AM | #51 |
Rep 504
06-28-2016, 10:17 AM | #52 | |
Rep 191
and will this disable the side and other airbags for drivers? tks
06-28-2016, 10:36 AM | #53 |
Rep 504
06-28-2016, 01:01 PM | #54 |
Rep 191
fyi for everyone
i have just successfully installed and coded my m sport wheel from ebay (with european single stage airbag - id is daris77) install was plug and play, coding in esys was straight forward. ACSM module 3000 funktion - airbag_fahrer_stufe_2 -> set to nicht_aktiv (drivers airbag stage 2) also need to do the same for: adaptive_airbag_fahrer_vent code fdl use tool32 to reset the airbag warning and you are good to go! for all the ppl that said it couldn't be done, that's false, as i just confirmed it's possible
11-10-2016, 06:07 PM | #56 | |
Rep 176
What do you have to do to fix? I think I have this same airbag |
11-10-2016, 09:37 PM | #57 |
Rep 40,737
PM sent.
04-19-2017, 09:56 AM | #59 |
Rep 40,737
PM sent.
05-07-2017, 04:48 PM | #61 |
Rep 2
Hi, I am new to this forum and looking to understand how to reset my airbag fault, 2 of the airbags havd deployed after a very minor accident. I have replaced them. From reading this thread it looks like I need to request a copy of Tool32. Will this run on Win10 with an ENET lead? Any other advice would be appriciated.
05-08-2017, 12:11 AM | #62 | |
Rep 3,225
05-08-2017, 06:56 AM | #63 | |
Rep 40,737
07-17-2017, 10:07 AM | #65 |
Rep 1
Hi everyone, sorry but is the first time in this forum.
I have to reset the airbag fault, because i change my steering wheel, but i use the car without airbag for few days. I tryed with esys, external app but doesn't work. Maybe i need tool32? Can i use the ethernet obd2 cable? Is possible to erase the fault code from hidden menu? Thank you every one |
10-23-2017, 02:56 PM | #66 | |
Rep 4
How did you code out the errors you saw with the airbag using E-Sys? Could you please tell me what commands you used? I bought an m-sport steering wheel with dual stage airbag and am getting 'Driver restraint malfunction' error thanks |
