BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > VRSF downpipe without CEL light coming on
      01-23-2018, 08:22 AM   #23
LIVY435IGC
Drives: 2015 435i Gran Coupe
Originally Posted by wassy4 View Post
On all of the time unless you wanna deal with the CEL
Awesome. Thank you!
      01-23-2018, 11:04 AM   #24
LIVY435IGC
I cant thank you enough!
Do you think this one would work?
https://www.amazon.com/Degree-Angled.../dp/B00B1U6I54
      01-23-2018, 11:06 AM   #25
wassy4
Drives: 2016 340i
This is actually the one I have. You can get it but don't use the angled piece. Use the straight ones, start with 1 and if that doesn't work then stack them.
Current - 2018 M2 | VRSF Chargepipe | VRSF Catless Downpipe | Dinan Catback | Turner Motorsports Intake
Previous - 2016 340i M-Sport | AWE Tuning Touring Edition Exhaust w/ Non-Resonated Performance Mid Pipe | Agency Power Intake | Active Autowerke Activ-8 | VRSF Catless Downpipe
      01-23-2018, 01:00 PM   #26
LIVY435IGC
Great, I will give this a try.
So, when testing to see if the CEL will come back, how did you go about clearing and waiting for the system to reboot?
Last time, I tried (i had leak at the vclamp and thought that was the issue), i pulled the neg for 30 minutes to clear the light. The light came back after about 250 miles. Thanks again.
      01-23-2018, 01:02 PM   #27
wassy4
Drives: 2016 340i
Just clear it with an OBD2 reader beforehand if you can.
      01-29-2018, 08:08 PM   #28
zinner
zinner's Avatar
Drives: `17 X5 35d/`15 335i/`18 M550IX
Fabspeed makes a O2 spacer with a mini cat built into it. My AMG buddy has one and it keeps the CEL away and even sets emissions readiness. For what it's worth any tech can smell / hear a catless car a mile away.
      03-17-2018, 08:46 PM   #29
ocN55
ocN55's Avatar
Drives: '15 M235i 6MT/ '16 M3
O2 spacer will work but it might take a couple different ones to get it right. Just get one of the straight ones. Don't make the mistake I did and get a really long angled one, it takes the O2 sensor too far out of the exhaust flow.
why is it bad if the sensor is too far from the exhaust flow? Isn't it better the farther it is (to reduce how much O2 is being sensed)?
FBO M235i r
F80 M3
      03-17-2018, 09:07 PM   #30
paimon.soror
paimon.soror's Avatar
Drives: 2016 F36 435x MSport
There is a specific sweet spot. The car typically evaluates the o2 voltage response compared to that of the upstream sensor. If you move it too far out of the stream it will fall out of the expected threshold... then you get the 'o2 slow to respond' code.
Throw a catless, or even some high flow catted in the mix, and it will detect a higher downstream voltage against its threshold compared to the upstream, thus throwing the cat efficiency code.
2010 Mazda RX8 - Sold (11/17)
2016 BMW 435xi GC - Current
      03-31-2018, 09:18 PM   #31
LIVY435IGC
So i finally had a chance to get off the 02 sensor. What a pain. Now my issue, how did any of you put on the straight spacer and then the 02 sensor. It barely fits with just the 02 sensor. I think i have no choice but to try the 90 angle one. Is that one too long ? Any issues with that?
      03-31-2018, 10:43 PM   #32
LIVY435IGC
So tried angle spacer. Same error. Scanned the ecu and got
MID 02 TIB 02
Lean to rich sensor threshold : not ok
MID 21 TIV 81C:
Catalyst monitor bank 1: not ok
Any ideas?
      03-31-2018, 11:08 PM   #33
LIVY435IGC
MID 02 TIB 02
MID 21 TIV 81C:
Any ideas?
      04-01-2018, 12:34 AM   #34
Jerich0
Love to Drive
197
Drives: X4 & M4
MID 02 TIB 02
MID 21 TIV 81C:
Any ideas?
You were specifically told NOT to use an angled one.
      04-01-2018, 06:37 AM   #35
LIVY435IGC
I know this. There is no space to use a straight spacer.
I have a N55 which maybe the reason
      04-01-2018, 08:51 PM   #36
LIVY435IGC
So I was hoping someone could clear this up for me. So yesterday when i put the angled spacer, i saw that the cel was still on and the o2 sensor was not ok via the torque app. I assumed that the two errors on the scan mid 21 tid 81 & mid 02 tid 02 was still present that it did not fix the issue. I was so tired that i never tried to clear the ecu. Now with some sleep aand more reading i may have missed a step and not cleared the error. Should i go back and try again and this time clear the ecu. Sorry about the rant. I should have stopped when i felt tired and rested more before tacking this
      04-01-2018, 09:07 PM   #37
paimon.soror
question, when you installed the angled sensor, what direction did you face it ? down, or up ....
Asking because i want to make sure while you are troubleshooting, that you dont have the angle facing downwards because you will risk damaging the o2 sensor as condensation builds up in the spacer.
      04-01-2018, 09:54 PM   #38
LIVY435IGC
Thanks. Definitely up. Drove it for 15 minutes and then pulled it off next morning
Any ideas or suggestions?
      04-01-2018, 10:07 PM   #39
Jerich0
Love to Drive
197
Drives: X4 & M4
Try 42DD O2 spacer, that one has to work... that of course if yours currently doesnt work after clearing the codes.
      04-02-2018, 07:59 AM   #40
LIVY435IGC
Lol. Ill try my old one first and then try the one you suggested.
Does anyone know if the torque app clears the light right away or does it take a few drive cycles.
      04-02-2018, 08:04 AM   #41
Jerich0
Love to Drive
197
Drives: X4 & M4
All should clear the light immediately unless you have a bigger problem and the lights come back just after clearing it...
      04-02-2018, 03:47 PM   #42
ocN55
ocN55's Avatar
The problem is that he is N55. You cannot trick those motors the same way you can with the B58. Former N55 owner here..
FBO M235i r
F80 M3
      04-02-2018, 04:00 PM   #43
LIVY435IGC
Thank you! This isnt going to work then?
As a former N55 owner, any ideas?
      04-02-2018, 07:29 PM   #44
ocN55
ocN55's Avatar
Unfortunately, you got no options besides tuning with flash or JB4.
FBO M235i r
F80 M3
