10-05-2017, 11:56 PM | #1 |
Rep 91
VRSF downpipe without CEL light coming on
I currently have a b58 440i coupe MT with full akra exhaust, BMS intake, and DINAN tronic sport tuner. I am planning on installing a VRSF catless downpipe but i want to know if anyone has done it without the CEL light coming on. I know the JB4 can clear this but i want to avoid that if at all possible. Any ideas?
10-06-2017, 06:07 AM | #4 |
Rep 1,782
Get an O2 spacer
13' 335i M Sport. EBII/Coral Red 6MT. RPI GT exhaust, Resonator delete, PS1, GFB DV , BM3 Stage 2, ER CP, VRSF DP, VRSF 5.5in Stepped FMIC, Dinan Shockware. Carbon M Performance rear diffuser. M4 trunk lip. Conti DWS06 225/40/19 and 255/35/19
10-06-2017, 10:43 AM | #6 |
Rep 1,782
It?s actually really funny
01-10-2018, 09:12 PM | #7 |
Rep 33
Would you mind sharing the link to the o2 spacer you're using? My VRSF downpipe should be arriving in the mail next week and I'd like to get a spacer put on with the downpipe
01-13-2018, 08:03 PM | #9 |
Rep 5,457
Drives: F30
Anyone have a link to a spacer known to work? Where exactly in the exhaust path is an O2 spacer necessary to avoid CEL with a catless downpipe?
01-13-2018, 08:43 PM | #10 |
Rep 113
01-13-2018, 08:59 PM | #11 |
Rep 5,457
Drives: F30
So basically... what we are saying is that these are generic and one size fits all type thing?
A 5$ works as good as a $20 one? Honestly not sure, thats why Im asking. |
01-13-2018, 09:04 PM | #12 | |
Rep 965
Drives: 2016 F36 435x MSport
little bit on the 'expensive' side, but you will have adjustment options. Popular on the 911 forums and VW forums. Seems that the middle fitting is the one the general concensus goes with. I have one sitting in my basement right now on an ER downpipe ... just haven't installed it because i dont have a tune. quality piece.
2010 Mazda RX8 - Sold (11/17)
2016 BMW 435xi GC - Current |
sspade2466.00 |
01-14-2018, 12:25 AM | #13 |
Rep 235
Get an O2 spacer. Just get a straight one. I made the mistake of buying an angled one that was too big and took the O2 sensor completely out of the exhaust stream.
Current - 2018 M2 | VRSF Chargepipe | VRSF Catless Downpipe | Dinan Catback | Turner Motorsports Intake
Previous - 2016 340i M-Sport | AWE Tuning Touring Edition Exhaust w/ Non-Resonated Performance Mid Pipe | Agency Power Intake | Active Autowerke Activ-8 | VRSF Catless Downpipe |
01-19-2018, 06:16 PM | #14 |
Masterchief
364
Rep 1,015
I have a n55 with vrsf catless dp and jb4.
There is no possible way to have catless dp and have no codes unless you have an o2 sim I took my car for the 30k inspection at the and cleared the code before I took it to the dealer. For some reason, the tech or the SA never mentioned anything about my mods and codes. Even when they showed me the fat stack of papers from the system diagnostic and nothing regarding my dp and mods or any codes even showed up
AWE Non-Res Touring | TE37 SL PW | Ohlins RT |
01-22-2018, 10:24 AM | #15 |
Rep 152
Drives: 2015 435i Gran Coupe
So can someone clear this up for me?
I have a ER catted dp on my 2015 f36, N55. The CEL has come on and now there is a P0420 code. I have heard that the VRSF DP fix will not work on my car and will not remove the cel and have the car emission ready for a smog test. Would the O2 spacer eliminate the CEL and allow the car to pass inspection? I am not looking forward to taking the dp and putting back the oem annually for the car inspection. Thanks! |
01-22-2018, 10:51 AM | #16 | |
Rep 235
01-22-2018, 11:21 AM | #17 | |
Rep 152
Which one did you end up using. Can you send a link? I was so not looking to doing the swap annually |
01-22-2018, 11:24 AM | #18 | ||
Rep 235
Alternatively, you can go into any auto parts store and look for a spark flog de-fouler/non-fouler which are like $5 bucks. If you buy 2 and stack them it will work as well but you might have to drill one of them out to fit the sensor.
01-22-2018, 11:31 AM | #19 | |
Rep 152
I will give it a try this weekend. Did you have to take your dp to put this on or where you able to just replace with it on the car? My car is xdrive and space is tight.. |
01-22-2018, 11:33 AM | #20 | ||
Rep 235
01-22-2018, 01:12 PM | #21 | |
Rep 152
So with your comment about putting anti sieze. Is this something you do just to pass inspection or do you have the spacer on all the time? |
01-22-2018, 11:58 PM | #22 | ||
Rep 235
