04-03-2018, 07:42 AM | #45 |
Rep 152
Drives: 2015 435i Gran Coupe
I heard those dont work either. Not sure you read my post earlier, but i basically installed spacer but forgot to clear codes (young kids, so time to work on car is usually at night after everyones asleep).. Any point in trying again?
04-03-2018, 10:53 AM | #46 | |
Rep 1,503
I'm not sure about the JB4 anymore, but I know that flashing will be a solution to the issue. EDIT: I think JB4 still works for your case. The n55 version of it is still not CARB legal.
FBO M235i r
F80 M3 |
04-03-2018, 11:08 AM | #47 | |
Rep 152
04-05-2018, 11:44 PM | #48 |
Rep 152
Update
Got under the car again and placed the angled spacer. Tried clearing the cel and no success! |
04-06-2018, 03:29 AM | #49 | |
Rep 1,503
Also, try asking in the N55 subforum, not B58.
FBO M235i r
F80 M3 |
04-06-2018, 10:39 AM | #50 |
Rep 152
Thanks man. I wanted to update so others don't waste their time. I have tried the N55 forum, but apparently 2014 + N55s are more particular with fixing the CEL
ocN55559.50 |
04-06-2018, 01:21 PM | #51 |
Love to Drive
197
Rep 602
04-06-2018, 04:02 PM | #52 |
Rep 152
04-07-2018, 09:28 AM | #53 |
Love to Drive
197
Rep 602
04-07-2018, 12:29 PM | #54 |
Rep 152
04-07-2018, 02:51 PM | #55 | |
Rep 152
So i drove the car with spacer. Was too tired to take it off. I think i drove about 25 miles and no CEL. Thought i was seeing things (more like not seeing things). Thank God! Checked the fault P0420 is cleared. Looks like the angled spacer did the trick.Thanks for all the great advice! |
04-09-2018, 04:07 PM | #56 | |
Rep 152
Pending faults for P013A & P013B. I know this is a result of the angled spacer, but is this bad for the car? Thanks again |
04-09-2018, 08:02 PM | #57 |
Rep 152
10-22-2018, 10:10 PM | #59 |
2015 435i xdrive- 6spd, cp, dp, fmic, bm3 stage 2
25
Rep 41
Any updates on the issue. Im going through the same thing. Thinking about going with the mini-cat to stop the codes
10-26-2018, 12:34 PM | #60 | |
Rep 467
your option may just be a tune. however,...does anyone know if the tunes actually turn OFF the o2 sensor (that's a BIG NO)? or does it just auto clear? if it auto clears...doesn't that still pull timing? |
10-26-2018, 12:52 PM | #61 | |
Cheapskate
4450
Rep 4,993
01-29-2019, 09:05 PM | #64 |
Rep 513
Drives: 2008 335i
Amazon is a rip off for small parts, go aliexpress and get free 15 day delivery.
Just plan a head and delivery time is a non issue. https://www.aliexpress.com/wholesale...ext=O2+CEL+Fix |
01-30-2019, 09:35 AM | #65 |
Rep 1,457
The only spacer that works for me is the 42 draft design. I have the older model spacer and it never threw a cel on my 2016 GTI and current 2018 340i after i switched from the CG catted to vrsf catless.
It seems to be a newly designed so i cant speak for it since i have the original one: http://www.42draftdesigns.com/o2-sensor-spacer/
2024 X3 M40i
2014 BMW M5 |
01-31-2022, 01:16 PM | #66 |
Rep 85
I'm confused a little, I have a 2013 335 xdrive which is n55 and have the p0420 code on. I've had a catless dp and jb4 installed for years and no issue or cel of any kind and then the light came on about 1 month ago. I had a bit of a rattle going on and when I finally was able to get under the car I noticed that the exhaust hanger mount in the mid section right after the flex part had snapped off (car is quite low on H&R springs). My first task is to fix the hanger mount so the exhaust is not moving around anymore. I've read that the 0420 code could also be cause by an exhaust leak, and wondering if possibly with the exhaust being slightly lose like that for a while is what is possibly causing the light to come on if indeed there is a small leak somewhere. I don't really have a good garage or place to work on my car anymore, besides taking it to a muffler shop if there is a leak I would assume having it welded would be the best and only option?
