01-31-2022, 06:09 PM | #67 | |
Rep 4,878
The way it's configured is there is a wideband O2 that is pre-cat to run the fueling for the engine. And then they run a narrow band O2 post cat to check if the emissions are working as expected (since if it's fueling properly, and the cat is scrubbing the exhaust, it should all be in check). |
02-06-2022, 12:04 PM | #69 |
Rep 4,878
03-12-2022, 08:29 PM | #70 |
Rep 104
After reading through this, looks like a spacer is a 50/50 shot of not throwing a CEL?
Best option being buy DS1 or AA downpipe without the hastle? |
04-10-2022, 12:14 PM | #71 |
Rep 125
I'm in the same boat right now. I am considering the VRSF because it's cheap enough and within my budget but I honestly don't want to deal with CEL or spending over $500 USD for a bootmod3 license even though I don't even want to tune/remap. I think I'll give the o2 spacer a shot, but if you can afford it, a catted downpipe is quite hassle-free but much more expensive. ArmyTrix sells some of the best high-flow catted DPs out there, and make sure you get it ceramic coated if you live in a hot area.
04-10-2022, 09:10 PM | #72 | |
Novice
303
Rep 695
04-11-2022, 11:53 AM | #73 | |
Rep 4,923
Scanner / code deleter. https://www.amazon.com/Autel-MaxiSca...ps%2C89&sr=8-3 Downpipe- https://mad-us.com/mad-b58-downpipe-...chassis-supra/
04-12-2022, 10:52 PM | #74 | |
Rep 104
04-13-2022, 07:02 AM | #75 |
Rep 4,878
This also masks any other major CEL's that get thrown. Basically you are saying "put a piece of electrical tape over the check engine light".
BeFitty8_F3259.00 |
04-13-2022, 07:53 AM | #76 |
Melbourne Red F32 B58
59
Rep 99
The biggest lesson I have learned from owning any car, is that sometimes it sucks and hurts the wallet. Doing the correct thing with proper parts is always the way to go.
Sometimes you dont have the money, I get it. But if you do, dont be cheap. Unless its a "beater" and you dont care. Good luck! I need some too with my recent purchase. |
04-13-2022, 07:57 AM | #77 | |
Rep 4,878
BeFitty8_F3259.00 |
04-13-2022, 02:01 PM | #78 |
Novice
303
Rep 695
Yea but that is why you would have a scan tool on standby to check for any other codes. for an example a CEL wouldnt pop up if your injectors were stuck/leaking. Which brings u back to the question of why you want a downpipe and not a tune to compliment it. cant have both worlds at the same time with different objectives. plus o2 spacers potentially cut off data being tracked by the o2 sensors
04-13-2022, 03:34 PM | #79 | |
Rep 4,878
The spacer doesn't change any data/operation. Lower O2 sensor is there just to trigger the CEL if the O2 drop across the cat makes no sense (emissions are not working properly). If you are changing the DP, then you really don't care about that CEL code. Won't disagree with your point about getting the DP without the tune is a bit of a waste though. |
04-13-2022, 03:50 PM | #80 | |
Rep 4,923
Manual code clearing instead auto code clearing like the jb4 used to do.
04-13-2022, 06:49 PM | #81 |
Rep 4,878
Yes, I get that. But if you have a DP that throws code, then 5 minutes into a drive, it will pop back up again. That was the case with my catted VRSF. So "ignoring" really isn't an option since it's masking all the other codes that may be critical to the car.
04-14-2022, 02:03 PM | #82 | |
Novice
303
Rep 695
04-14-2022, 03:55 PM | #83 | |
Rep 4,923
Flash tune makes this entire process much easier if you are out of warranty.
BeFitty8_F3259.00 |
04-14-2022, 06:06 PM | #84 |
Rep 4,878
What he said. One above the cat is used for fuel adjustments. One after the cat is just there to toss the CEL if the DME is seeing too much O2 (unburnt fuel) in the exhaust after the cat. Not needed for operation, just used to ensure the emissions are operating to spec. Once you put in a high flow cat or catless DP, emissions are not in your area of concerns, so it can be tuned out.
BeFitty8_F3259.00 |
