02-20-2020, 01:42 AM | #859 |
Rep 38
02-20-2020, 02:10 AM | #860 |
Rep 384
02-20-2020, 02:26 AM | #861 | |
Rep 108
C'mon man have you seen that K20A engine stripped down? Compare that to N20... look at the timing chain and guides alone? K20 has double row chain and metal body guides compared to single row thin chain and "child toy" plastic guides. N20 is made cheaply and designed poorly. And that does not belong into a $50000 car (when new). And that SUCKS big time! btw. we are still here because we still have the car, but where are the guys whose engine blew up or disintegrated itself by broken chain? |
02-20-2020, 02:45 AM | #862 | |
Rep 500
Drives: BMW 330e F30 M-sport
Thorbjorn
16 BMW F30 330e M-sport Bootmod3 Stage2 / BMS Intake / RM Motors high flow catted downpipe & custom exhaust / BBS CH 19" / H&R Sport springs |
02-20-2020, 03:10 AM | #863 | |
Rep 384
blowm my N20 engine, rebuilt it, sold the car, then buy B48 engine and tune again oh how much i must love BMW |
02-20-2020, 06:36 AM | #867 | |
Rep 2,671
Bingo. I'm still around to learn about these cars but most blown engine owners are not. |
02-20-2020, 08:20 AM | #868 |
Rep 414
Talking to PTF they've said most issues coming from N20/N55 are due to shitty fuel injectors, which if I'm understanding right can lead to cracked pistons. Stands to reason that everyone should be logging early and often to ensure the car's operating properly.
328ix 8AT Sport Line N26 | Navardi Custom Stage 2 93 | xHP Stage 3 | VRSF 5" HD FMIC | ER CP | ER Catted DP CTC | aFe Pro Dry S | MST Turbo Inlet | TMS Upper Air Intake Tube | 2nd Cat X | GFB DV+ |
02-20-2020, 09:34 AM | #870 | |
Rep 414
faulty injectors can't be overlooked or ignored for long. Dirty or worn-out injectors can also cause preignition or detonation [source: Carley]. Detonation is a fairly common problem in which gas remaining at the end of the normal air/fuel burning cycle (which is set off by the spark plug) spontaneously combusts. Detonation is harmless in some cases, but the pressure has potential to break engine components and cause pitting and scuffing around the pistons. Preignition is when the air and fuel combust before the spark plug fires, causing severely increased engine temperature and damaged pistons. This problem is much more likely to pinpoint a leaky injector than detonation is, because it's a relatively rare occurrence in fuel-injected engines.
02-20-2020, 11:07 AM | #871 | |
Rep 3,748
As there is a thread on this forum for a N20 build with strong internals. I bet he will need about $5k minimum to start with that build. I want to build on this engine but the BMW tax is keeping me off. On the side note... I'm staying stage 1... not going further anymore. Just want to enjoy the car without blowing my pocket Last edited by Gen13 F36; 02-20-2020 at 11:18 AM.. |
02-20-2020, 02:56 PM | #872 |
Rep 2,805
Drives: F33 430 and F39 M35i
I have the B46 and was considering a catted downpipe (emissions checks in my area) and moving to stage 2 but decided to just keep it at stage 1 and get a B58 or better next time around. I'll leave stage 1 93 flashed when I give the car to my daughter in a few years.
02-20-2020, 06:56 PM | #873 |
Rep 384
so we had to constantly check the fuel injectors? or maybe replace it?
02-20-2020, 07:12 PM | #874 |
Rep 500
How to check the fuel injectors? Does it show any error code or tell sign? Looks like I'll be more diligent using Techron Concentrate Plus to clean the injector.
02-20-2020, 09:20 PM | #875 | ||
Rep 338
2013 320ix N20 8AT|BM3 stg1|Muff Res Delete|HPB-LED-Amber-DRL's
IG: DadzBmer_N2o |
02-21-2020, 01:50 AM | #876 |
Rep 38
02-21-2020, 08:25 AM | #877 |
Rep 414
PTF is suggesting they can tell if issues from logging so yes it would be ideal to have them check logs maybe monthly or more depending on how often you drive the car. In your case you only had the time for a very short period so maybe the issue was already there and the tune just set it off. No magic bullet to save all engines just need to do what we can to help ensure the tune is running healthy and sending logs is the only way to detect this one it seems.
02-21-2020, 08:30 AM | #878 |
Rep 338
No none yet for my engine, but i'd rather take pre-emptive measures to insure a better chance to survive this for the long miles ahead. I wanna keep her for as long as my wallet can hold up lol, i have only 43k since it was bought CPO'd w/ 32k in 2016.
IG: DadzBmer_N2o |
02-21-2020, 04:33 PM | #879 | |
Rep 420
Try +600whp, but ok.... |
02-21-2020, 04:35 PM | #880 |
Rep 420
bm3, bootmod3 |
