02-08-2020, 11:24 AM | #1 |
Rep 3,538
FaRKle's Tune Comparison Data
I'm making this thread to put the data I've collected with the various tunes I've had out there. I'll update it as I compile the latest data.
Tunes I've had: OE: 1yr, 2mo, 26,148mi JR Stage 2:1yr, 2mo, 21,802mi KermaTDI Stage 1: 3mo, 4,438mi KermaTDI Stage 2: 6mo, 8,074mi (as of this post) Fuel Economy For fuel economy I'm only including "qualified" samples, meaning full tanks, typical driving (no track time), and diesel fuel (no bio or renewable diesel). For smaller populations I provide both with/without a longer road trip tanks since those are weighted more heavily. OE: 35.09mpg, n=56 JR Stage 2: 33.81mpg, n=39 KermaTDI Stage 1: 35.06mpg, n=11, 34.09mpg, n=8 (no road trips) KermaTDI Stage 2: 34.65mpg, n=14 DPF Regens I use torque pro and monitor regens by looking at the commanded boost (typically goes negative during a regen at idle) and DPF EGTs. Unfortunately I didn't have this logging capability when I was still on the OE tune, and it wasn't until I started having CELs pop up with JR Stage 2 that I decided to start logging. I make a mental note of my mileage when a regen happens and then check to see that one is happening at the next expected interval. They've been very consistent. OE: N/A JR Stage 2: ~210mi KermaTDI Stage 1: ~300mi KermaTDI Stage 2: ~300mi More to come...
02-10-2020, 04:32 PM | #3 |
Rep 368
I almost think the drop in fuel economy is related to users being more "heavy footed" after performance tunes. But Kerma's proximity may imply lack of statistical significance. From what I have read, it seems Kerma to be the most trouble free option compared to others. My biggest worry was about someone here reporting faster than normal Adblue usage after Kerma. FaRKle!, can you confirm if this is the case?
02-10-2020, 08:56 PM | #4 | ||
Rep 3,538
It turns out my projections were darn close to reality! Two weeks ago my DEF light came on and I refilled it. The interval was 6,232mi from the last time I refilled it. My interval also included four track days, and a lot more NOX is produced at WOT. When I was on JR's tune I was still under the BMW free maint plan, so my DEF was topped off every oil service (which was generally about every 8,000mi for me), so rate of consumption was less than KermaTDI's tunes. That said... KermaTDI was very open with me about why that is, and while I won't disclose exactly why, what I will say is that they made design decisions which decreased fuel consumption at the expense of increased DEF consumption in order to maintain full emissions compliance.
haagm58809.50 |
02-11-2020, 03:40 PM | #5 |
Rep 77
I’ve been on my Kerma tune for about a month now and it’s been great. What’s Stage 2? I never had issues with DEF before, only topped off at oil changes. I keep it in mind since I had the oil changed right before I got the tune.
02-22-2020, 03:00 PM | #6 |
Rep 40
@FaRKle! +1 on the Stage 2 Kerma. Can you elaborate.
2014 328xd Sport Wagon, Kerma Stage 1 tune, xHP with shift point adaptation, 45MPG
2003 Jetta TDI Wagon, EGR delete, 43MPG no -> went to my daugher 2002 Tacoma TRD overland build 2014 Ram 1500 EcoDiesel, tuned, 24MPG |
02-22-2020, 06:06 PM | #7 | |
Rep 3,538
haagm58809.50 MustGoFaster1.50 |
02-22-2020, 06:36 PM | #8 | |
Rep 77
haagm58809.50 |
02-22-2020, 08:20 PM | #9 | |
Rep 40
02-22-2020, 10:07 PM | #10 |
Rep 3,538
It's not on their site because the installation is more complicated than the q-pro flasher and has to be done remotely by someone. You'll need to call and ask about it.
02-23-2020, 09:37 AM | #11 |
Rep 40
Got it. Thank you.
03-14-2020, 12:25 PM | #12 |
Rep 40
FaRKle! do you happen to know if Torque or other obd2 apps are accurate enough to do 0-60 runs with. Would like to take some data before and after the tune.
The programmer should show up by Tuesday next week and then based on the turnaround from Kerma I could have the new tune ready by Wednesday or Thursday. I just don't want to spend another 500 bucks on a handheld device if an obd2 approach could at least get me comparable data, but that would all depend on the sample rate the obd2 can read.
03-16-2020, 07:29 AM | #13 |
Rep 424
I ended up getting Kerma's tune. When I called though they claimed they just have one tune, not stage one or two. How can I confirm which one I got?
Also - the newfound torque with the tune is nice |
03-16-2020, 10:33 AM | #14 |
Rep 3,538
You got Stage 1. Stage 2 requires an additional flashing session. Stage 1 is a bit smoother than stage 2.
03-16-2020, 11:43 AM | #15 |
Rep 424
03-16-2020, 12:41 PM | #16 | |
Rep 3,538
It seems to me like one of those things that you'd want to limit to people who are very familiar and comfortable with using tools like ESYS and ISTA.
03-16-2020, 12:46 PM | #17 | |
Rep 1,799
The 'stage 1' or 'stage 2' (or whatever you'd want to call it) would make exactly the same power until this transmission flash is done. This is because the transmission computer puts a hard limit on how much the engine computer is allowed to output.
05-14-2021, 05:12 PM | #20 | |
Rep 11
Is there some resources that I could read up on how diesel engine performance is achieved? I unfortunately have a EE/CS background and not a MechE |
05-16-2021, 03:11 PM | #21 | |
Rep 1,799
1. BMW themselves had a few different power levels from the same or similar hardware, with software being the only difference. Marketing, road taxation, etc. is all involved here. 2. Manufacturers have to design engine software to run an engine even when the owner is neglectful and forget to change an air filter, fuel filter, etc. They have to leave a very broad headroom for all these conditions. Tuning pushes this higher, but obviously it's not for the neglectful owner. 3. In general, diesel tuning is achieved by extra fuel (timed correctly) and air to match. Fuel can be increased "easily", and the North American 328d is equipped with a very nice Honeywell Garrett turbo that can stand a pretty good increase without compromises, to an owner that isn't neglectful. Contrary to popular belief, it's not the boost that creates the power.
MustGoFaster1.50 |
05-18-2021, 10:22 AM | #22 | ||
Rep 11
What about the fuel injector? I did read about premature failure of those... would a tune potentially increase the chance of incurring this expensive repair? |
