02-11-2020, 03:51 PM | #1 |
Rep 27
Hi All,
As most of us know, our cars are prone to making all sorts of noises that can trigger our ocd. No one wants to think that something's potentially wrong with their car! After looking all over the internet searching for someone with my same issue, I've decided to just ask bc I cant find an example that's similar to the noise I'm hearing coming from my engine bay! I would greatly appreciate any insight and or validation that my N55 isn't a goner... Here's the break down: I bought my 2012 335i sportline about 3 months ago with 73,000 miles on it. After the initial excitement started to ware off a bit I started to notice a KNOCKING SOUND coming from the engine bay that can be heard from inside. Initially I didnt pay much attention to it since the car has been running smoothly without issues, aside from a drivetrain malfunction I experienced, which was resolved with new plugs as the original ones were going. I've since been looking into the noise, but the more I research the more I freak out about potential problems like looking up the symptoms for a cold on WebMd and realizing you have 2 weeks to live. The noise is not there at all on cold start. It's only present once I've driven for awhile and the engine is at operating temperature and at idle. Once I start moving it goes away. It's NOT the injectors as they make a different clicking noise. Has anyone had this same noise coming from their engine bay and is it normal or is there something else going on? UPDATE: Indy shop noticed torque converter bolts were loose. They tightened them and noise went away. |
02-11-2020, 08:39 PM | #2 |
Rep 282
have you tried without running the engine cover ? maybe it rattles on its mounts ?
always difficult to point out the culprit in such a thread
M140i DP , OPF delete , MHD stg2 93oct , xhp stg3
02-11-2020, 08:44 PM | #3 |
Rep 7,606
You didnt rev the car up at all so we have no way of knowing how this noise varies with RPM, if at all. That is a key test.
You can try to get a mechanic's stethescope and touch it on various parts of the engine to see if you can pinpoint where it is coming from. |
02-12-2020, 11:41 AM | #4 | |
Rep 27
02-12-2020, 11:42 AM | #5 | |
Rep 27
I hadn't really considered the engine mounts but I'll look into it this weekend. The noise is still there with the cover off. |
02-15-2020, 08:05 PM | #6 | |
Rep 27
https://youtu.be/w3934PA4gt4 |
02-15-2020, 08:06 PM | #7 | |
Rep 27
02-19-2020, 10:49 PM | #9 |
Rep 55
Drives: 2015 BMW 335i xDrive
Yeah. It does sound like a bottom end issue. I have not worked on these cars much, but you could disconnect coil packs one at a time while the car is running and see if the noise gets quiet or quits on any particular cylinder. That's how we used to identify missing and or rod knock issues when I was working on cars years ago.
02-20-2020, 01:52 AM | #10 | |
Rep 27
https://bmw.***********.com/threads/...ay-sound.3008/ Anyway, I'm taking it in to an indy shop this Saturday. We'll see if they can find the source. Fingers crossed. |
08-19-2020, 08:21 AM | #12 | |
Rep 86
I know Chevy and BMW ain't related at all but that's the sound of injectors 100%. If no one have found this for real never go back there ahah. I know that's a common problem on N54 engine. |
08-19-2020, 09:16 AM | #14 |
Rep 51
The sound in this video seems like either the Fuel Injectors or the Accessory Belt Tensioner. Look for the belt tensioner in front of the engine and see if it's vibrating. Mine had play and was making a very similar noise. From what I've read they seem to go bad around 100k. It's a pretty easy DIY to replace it. There's a video from KiesMotorsport in YouTube that tells you how to diagnose/replace it.
2014 F32 435i M-Package | Alpine White with Dakota Red interior | ESS Tune | AFE Power Intake, Charge Pipe | M-Performance Exhaust | Bilstein B8 Struts | 19inch Vorsteiner Wheels with Michelin Pilot Sport 4S | Carbon Fiber goodies
08-19-2020, 10:12 AM | #15 | |
Rep 14
08-19-2020, 12:05 PM | #16 |
Rep 27
This is not the same sound. What you hear in your video are the injectors ticking and possibly a bad pulley which is normal and not cause for concern. A lot of bmw owners complain about the loud ticking from injectors but this is normal and a product of direct injection. The clock ticking might be from a bad pulley, belt tensioner or old belt. I'd just buy a kit and replace the parts, its fairly easy to do. My noise came from the torque converter. Sounded like a helicopter but there wasn't any real issue, just noisy.
08-19-2020, 02:52 PM | #17 | |
Rep 14
08-19-2020, 03:18 PM | #18 |
Rep 7,606
08-19-2020, 05:52 PM | #19 |
Rep 14
11-13-2020, 12:13 AM | #20 | |
Rep 14
04-04-2024, 09:49 AM | #21 | |
Mr OEM
658
Rep 80
Drives: 2012 BMW 335i
I am having the exact same issue as you are on my 2012 335i F30. Did you ever find a fix? |
