09-03-2020, 07:59 AM | #3367 | |
Rep 643
M235i rwd 6mt
09-03-2020, 11:19 AM | #3368 | |
Rep 7,613
On the other hand if someone wants to extract every ounce of power they can from a OTS tune and doesnt mind datalogging to make sure they arent crashing HPFP, getting clutch slip, etc, then i would say they can go BM3 for that. |
thatBimmerBloke877.50 |
09-03-2020, 12:47 PM | #3370 | |
Rep 7,613
09-03-2020, 12:54 PM | #3371 | |
Moto Lover
187
Rep 591
Drives: '19 BMW S1000XR
09-03-2020, 12:55 PM | #3372 |
Rep 221
Thanks for the thoughtful responses!
That makes me reconsider things then. I don't mind getting my hands dirty with a DIY project here and there, but i don't have time to be chasing down and figuring out potential issues on a regular basis, especially not on a daily driver. |
Tpriest7893221.00 |
09-03-2020, 01:02 PM | #3373 | |
Moto Lover
187
Rep 591
09-03-2020, 01:50 PM | #3374 | |
Rep 7,613
My 335 is my daily and i run MHD stage 2+ E20 map which requires mixing fuel at every fillup, with a ever-growing list of mods. |
imperfectluck426.50 |
09-03-2020, 09:05 PM | #3375 | |
Rep 932
09-03-2020, 11:48 PM | #3376 |
Rep 7,613
Um, did you not read my posts lol? I explicitly said no matter which tune you choose you need to log lol, and followed up on why i recommended MHD for this particuarly person. I never said you dont need to log with one tune or the other. And if you would have clicked on my datalogging thread link you know I for one am a strong advocate for datalogging in general...
09-04-2020, 03:49 PM | #3377 | |
Rep 1,079
https://www.bootmod3.net/log?id=5f4e...729b12742251ad https://www.bootmod3.net/log?id=5f4e...0b435e569cae4f I'll log a few runs today and if it looks good then will go for E30 map. My pump tested 5% for 93 octane and exactly 85% for E85. |
09-04-2020, 04:27 PM | #3378 | |
Rep 7,613
As far as the logs go, the timing does look pretty good overall. Some corrections but they recover. Both of them have the weird overboost and boost oscillation in the beginning... BM3 basically always overboosts at the beginning of the pull, but the thing that is different about yours is (1) the throttle actually closes briefly because of the overboost, and (2) the oscillation happens 2-3 times. Usually its a overboost with no throttle closure and its a "smooth" overboost as the boost goes from slightly above to slightly below target as RPM increases. It will be interesting to see if that also happens on the E30 map. You can see it happens 3 times in a row in the second log. Are you at altitude? Your ambient pressure is -0.5 and that could be a factor. Also, i have no idea that PTF is talking about that the stock map has worse behavior lol... Stock map does not overboost intentionally. That doesn't even make sense. I also haven't seen the oscillating throttle closure and boost in a stock map, although i havent looked at TOO many stock logs. I assume he meant 1psi over target not 1k... |
09-04-2020, 04:37 PM | #3379 | |
Rep 1,079
I was targetting around E20-E25 for the 93 octane map. I should give it more time to adapt, I just can't stop logging, haha. I'll just do couple more tonight and send them to PTF also. Also, I don't think I'm at altitude(617 ft elevation), pretty close to sea level, -0.5 ambient pressure could be some issue? I just noticed my first few logs with stage 1 also had about minus 0.3-0.4 ambient pressure, probably car adapting to the tune? |
09-04-2020, 04:55 PM | #3380 | |
Rep 7,613
I suppose i can see what he means with throttle closure on BM3 vs. stock tune (and MHD for that matter). Bm3 is very lax with throttle closure in the sense that it allows the 'overboost' without closing the throttle, and it targets 100% throttle ASAP. On the other hand stock tune gradually opens the throttle throughout the pull, and it closes the throttle with any amount of MAP overboost. MHD is sort of between the two in that it also targets 100% throttle asap (quick/strong power delivery) but it retains the stock tune sensitivity to overboost (closes throttle with even 0.1 psi overboost, although only closes throttle the minimum amount to get boost under control). These are the way the tunes behave, im not going to say which one is "better" (although i personally prefer the MHD approach). AFIAK the ambient pressure is based on barometric pressure - so in other words, its density altitude and not necessarily elevation above sea level, meaning other atmospheric conditions could be factored in. I dont think its an issue. High temps could be a factor as well. But lower ambient pressure (higher density altitude) will make it more difficult to build boost, and potentially more difficult to control it as well. I totally get the "can't stop logging" - i was there for a long time chasing boost leaks, installing parts, etc. Just dont get so focused on getting perfect logs you forget to enjoy the car! |
09-04-2020, 05:02 PM | #3381 | |
Rep 1,079
Car sounds great after going catless, paired with my MPE. Just the right amount of burbles, might have to tone it down a bit for Sport+. Will be interesting to see the improvement with Dragy. Also, the bumpy shifts in lower gears that I experienced for the first few days after going stage 1 is not present with stage 2. Is xHP worth it or should I give bm3 trans flash a try? |
09-04-2020, 06:10 PM | #3382 | |
Rep 7,613
XHP in itself is well worth the money IMO. When you get the itch for the next mod and need to scratch it, XHP should fit the bill. |
09-07-2020, 07:22 AM | #3383 |
Rep 932
BM3 flash for the N55 lifts up torque limiters for cars where 3rd and 6th gear are limited from the factory. I don’t have a clue why BMW did that torque limiting in 3rd and 6th gears, very odd, but that’s what it fixes and it raises line pressure so shifts feel much better. Its a great option and freely included and tons of people run it.
09-07-2020, 09:09 AM | #3384 | ||
Rep 831
Drives: Bmw 335i f30 N55 ( sold)
2012 bmw 335i sedan
VRSF catless DP VRSF 5? HD IC Stock intake(had open before and was sick of noise) BMS CP 550i 351m rims with 275/245 set up. No tune as of yet. |
09-07-2020, 10:52 AM | #3385 | |
Rep 966
Drives: 2016 F36 435x MSport
2010 Mazda RX8 - Sold (11/17)
2016 BMW 435xi GC - Current |
09-07-2020, 03:33 PM | #3386 | |
Rep 7,613
There's an older post that says it only removes the torque limits, nothing else. Just curious what information is out there, if any... https://www.2addicts.com/forums/show....php?t=1668774 |
09-08-2020, 06:53 AM | #3387 |
Rep 479
2014 335i Xdrive BM3 Stage 1 91oct 58k miles
VRSF 5inch HD intercooler VRSF Charge Pipe OEM Plugs/Coils gapped to .030 with 3k miles on them AFE Pro dry drop in air filter Running Wawa 93oct gas Refueled at a different gas station (WAWA). Was going to try Costco but did not have the opportunity to due to timing. With the new gas, I have noticed now that only 1 out of 4 logs shows a knock and its only one time instead of multiple. Even though the timing isn't the cleanest, the logs no longer go into negative timing which is good. Overall I am pretty satisfied with how these logs look compared to my previous ones. I am going to try octane booster next tank and see if they improve even more. https://www.bootmod3.net/log?id=5f56...729b53eb61772e Log 2: Knock at 2547 RPM's https://www.bootmod3.net/log?id=5f56...729b53eb617731 https://www.bootmod3.net/log?id=5f56...0b4351832ddc06 https://www.bootmod3.net/log?id=5f56...0b4351832ddc07 |
09-08-2020, 10:39 AM | #3388 | |
Rep 7,613
TK335iMSPT299.00 |
