10-29-2018, 10:13 AM | #111 | ||
Rep 884
10-29-2018, 11:49 AM | #112 | |
Rep 3,211
meanwhile we buy new cars just because the clutchpack is gone no adverse effects from having the proper clean oil.. and yes I've changed mine at 2k (this is overkill as I've posted in other threads) and every 30k thereafter (since I do a drain instead of flush) now each dealer service cost ~$800 to replace tranny fluid/pan so I can understand why most people are not willing to do it |
10-30-2018, 05:04 AM | #113 | ||
Rep 3,947
Perhaps someone who is more knowledgeable than me can provide an opinion on whether it's safer to be slightly over the correct quantity than slightly under the correct quantity. |
10-30-2018, 12:03 PM | #114 | |||
Rep 884
Polo.....what do you believe was the cause of the 8HP45 failure on your vehicle? If hindsight was 20/20; would you perform the fluid change again? |
10-30-2018, 12:39 PM | #115 | |
Rep 3,947
At this point, I'm not sure I would do the fluid change again because if I can get another 80k out of the transmission for a total of 180k on the odometer, what's the point? To get another 20-40k miles? The life expectancy of the car is pretty much over at that point. |
10-30-2018, 01:38 PM | #116 | ||
Rep 884
10-31-2018, 09:17 PM | #117 |
Rep 212
And how, exactly, would one fill the ATF above the fill hole unless it was done in outer space in the absence of gravity?
sspade2464.50 TK335iMSPT299.00 |
11-01-2018, 05:02 AM | #118 |
Rep 3,947
So the fill hole is on one side of the car, I can't remember which at the moment. You can adjust the contact pads of your 2 post lift in such a way that the side with the fill hole sits higher than it normally would on a complete level surface. Then I used a Motive Power Fill device (pressure fed) and inserted it into the fill hole. I followed the BMW procedure until the level reached the fill hole (still not enough). I placed a paper towel around the fill hole and just filled it with about 0.5L more than it should take. Then you just have to be quick about installing the drain plug. You'll probably lose 0.5-1.0L in that process.
11-01-2018, 10:01 AM | #119 | |
Rep 525
11-01-2018, 10:32 AM | #120 |
Rep 3,947
After 3 separate attempts on 2 different cars, I am not able to put back the amount of ATF I drained even having the car hooked up to ISTA and following it step by step.
11-01-2018, 10:48 AM | #121 |
Rep 525
11-01-2018, 11:20 AM | #122 |
Rep 5,457
Drives: F30
I have an interesting take on this procedure from my dealer that I will share with the group in another thread...
11-01-2018, 11:22 AM | #123 |
Rep 525
sspade2464.50 n00bkiller944125.50 |
11-01-2018, 11:28 AM | #124 |
Rep 5,457
Drives: F30
11-01-2018, 11:31 AM | #125 | |
Rep 937
Hi
11-01-2018, 01:22 PM | #126 |
Rep 3,947
11-01-2018, 01:28 PM | #127 |
Rep 3,211
11-01-2018, 02:54 PM | #128 | |
Rep 716
Yes, the transmission takes a lot more ATF when engine running and going thru all the gears (10 second each). I rigged a funnel with a long plastic tube (from Home-Depot). I was able to fill the transmission by gravity, with the funnel secured on top of engine. I had a catch pan under the transmission to catch the overflow. This made it much easier than pumping the ATF up from under the car. When I put the new pan, I tightened the bolt in the right sequence. I took my time and the whole thing was done in about 2 hours. |
insanecoder1412.00 |
11-01-2018, 02:54 PM | #129 | |
Rep 212
My thinking is this:
11-01-2018, 03:46 PM | #130 | |
Rep 716
11-01-2018, 04:18 PM | #131 |
Rep 3,947
11-01-2018, 05:16 PM | #132 |
Rep 5,457
Drives: F30
