09-01-2019, 03:40 PM | #1 |
Rep 1,282
Oil filter housing gasket
I noticed oil on my garage floor. I saw oil on my oil filter housing so cleaned it. Turned the car on and I heard an air sound. The oil was back and the bottom of my engine was full of it.
SOLD! X5 35i sdrive- JB4 SOLD! 435i- Cary Jordan E30 Tune~ Dinan Turbo~ BM3 trans tune~ XDI-35~ 3.5 T-map sensor~ VRSF HD FMIC~ VRSF Chargepipe~ VRSF Catless Downpipe~ CTS Intake~ FTP boost pipe~ FTP intake inlet~ FTP oil catch can~ Turbosmart dual bov~ |
09-01-2019, 04:31 PM | #2 |
Rep 474
Try tightening the oil filter down to 18.4 lbs of tq. That seems like a lot of oil for it to be the gasket. Especially if you cleaned it up and that happened instantly. If that doesn't work. Then replace the ofhg and oil cooler gasket at the same time. Good luck
J. D. Cordier
09-02-2019, 09:29 AM | #3 |
Rep 10,351
Wow!
Looks like catastrophic failure of the gasket to the oil cooler.
"Drive more, worry less. "
09-02-2019, 09:45 AM | #4 |
Rep 1,282
I know the gasket is like $30-$40. How much do you guys think for labor?
09-02-2019, 10:20 AM | #5 |
Rep 3,947
09-02-2019, 01:28 PM | #7 |
Rep 1,827
From a dealer, I'd expect it to be in the range of $1000-1200 (based on my recollection of the quote I got a while back). How many miles on the car?
Also, if the oil cooler gasket has also failed, you might need a coolant flush as well. Check your coolant expansion tank to see if there's any oil/sludge floating in there.
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
09-03-2019, 07:13 AM | #9 |
Rep 3,947
09-03-2019, 07:35 AM | #10 | |
Rep 83
- between oil filter housing and engine - between oil filter housing and oil cooler You'll have the oil filter housing out anyway, so will be quick and easy to do the oil cooler gasket while you're there. |
Polo088161610.00 |
09-03-2019, 08:31 AM | #11 |
Rep 254
Curious to see if this ends up being the oil cooler gasket or just the oil filter cap not tightened down/installed correctly...seems like too much oil for a leaky gasket.
That oil buildup is definitely NOT just your OFHG leaking though, although it probably needs replacing too, ya know, bc BMW. |
09-03-2019, 08:44 AM | #12 |
Rep 1,282
Dropped car off this morning. Hopefully will know something soon. If it's the oil filter housing gasket they told me they would change the oil cooler gasket as well for $300. Plus they would do an oil change for $70. Total $370.
09-03-2019, 09:37 AM | #13 | |
Rep 129
by the way, How many miles/km does your car have ,oma3710? |
09-03-2019, 09:44 AM | #14 |
Rep 2,653
Did this job in about 3 hours. OEM gaskets were like $50. Easy peasey job and learned a lot.
09-03-2019, 09:45 AM | #15 | ||
Rep 1,282
09-03-2019, 10:23 AM | #16 |
Rep 129
= 85,XXXKm. (-> thanks Ali820)
wow , mine failed at 29-30Km (aprox) , very similar if the issue is OFHG/cooler like yours. Here in Monterrey-Mexico, dealership has these items aprox in USD : 11428637821 and 11428637820 - $798 pesos - 39.88 USD each one = 79.76 USD (both - tax included) and labor (not in dealership ) aprox 100USD. Last edited by Kefka; 09-03-2019 at 01:52 PM.. |
09-03-2019, 12:46 PM | #17 | |
Rep 290
09-03-2019, 09:12 PM | #18 |
Rep 1,827
Those are dealer rates?? Very reasonable.
09-04-2019, 03:17 PM | #19 |
Rep 1,282
No, they are not dealer rates. I am friends with a master mechanic at the bmw perfomance center. He does side work for me. He replaced the oil cooler gasket and oil filter housing gasket. We ended up having to replace the belt and pulley as well because oil was all over it. The pulley was making a hissing sound. He charged me $500 for parts and labor.
09-05-2019, 12:49 PM | #20 | |
Rep 16
09-05-2019, 05:34 PM | #21 |
Rep 5,369
That picture sure seems to make it appear that the leak was coming from the filter cap. It wouldn't make sense for the oil to fill those voids if the OFHG was leaking. If the OFHG was leaking that badly, oil would be everywhere and creating pools under the car.
There are two OFHGs. The OFHG between the housing and engine block is the one that tends to leak the worst and there's NO WAY it would pool oil there. It's physically impossible. The other OFHG is between the main oil filter housing and the front oil filter housing plate. In order for that gasket to leak into that area would require a pretty obvious leak and at the top of the gasket, not the bottom. For that amount oil depicted, it seems very very unlikely. When you saw this oil accumulation, how long had it been since your last own change? It sure looks to me like the oil filter cap was leaking and dumping oil into the depicted areas, especially since you were hearing a vacuum leak.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
09-06-2019, 02:20 PM | #22 | |
Rep 1,282
The oil was all over the place.
