03-16-2023, 03:33 AM | #157 | |
Rep 9
07-16-2023, 09:32 AM | #159 | |
Rep 415
I think it’s HU, KOMBI, SZL and FEM that need VO coding once you’ve added 248 to the FA.
2017 440i F36 - Drexler LSD - B58TU HPFP - MHD Stage 2 - xHP - 200 Cell DP - MPE
07-24-2023, 03:35 AM | #161 |
Rep 83
Don't know if you've coded it yet, but from what I understand from this thread you have to code FEMBODY, ICM and KOMBI https://f30.bimmerpost.com/forums/sh....php?t=1146335 (post #11).
07-31-2023, 01:40 AM | #162 |
Rep 83
I installed the heated steering wheel as my first ever retrofit and I'm very happy with the result. Works like a charm, thanks to this thread.
There's a bit of a learning curve to using E-sys, but thanks to all the available documentation and videos online it's totally doable if you just put some time and effort into it. Hardest part was removing the bottom part of the steering wheel column cover. In the end I managed to pull it of by hooking two trim tools behind the rear section of the cover and just pulling it really hard (I did it without removing my steering wheel). Assembling the covers again took 5 minutes. Thanks again! |
moppity106.50 |
07-31-2023, 03:00 AM | #163 | |
Rep 415
Which ECUs did you need to code with esys?
07-31-2023, 07:44 AM | #164 | |
Rep 83
I coded FEM_BODY, ICM and KOMBI. Somebody mentioned those in another thread and someone else had already confirmed that it worked, so I just did the same. In hindsight, maybe coding KOMBI wasn't even necessary because it already showed 'steering wheel heating activated' when I pressed the button before I even did any coding (the wheel didn't actually heat, but at least the kombi showed the right message). Good luck! |
M140_BCS237.50 |
08-05-2023, 11:21 PM | #165 |
Coding ECU's remotely
448
Rep 1,179
Only Kombi and FEM need to be coded.
Author of Car Connector - remote ICOM & ENET tool - Built in VPN for easy coding and remote diagnostics
Car Connector on YouTube |
M140_BCS237.50 |
