09-30-2020, 02:38 PM | #45 | |
Rep 320
09-30-2020, 04:12 PM | #46 |
Rep 3,540
The fenders are the same between RWD and xDrive.
10-03-2020, 03:34 PM | #47 | |
Rep 3,540
I finally got around to making a video on these camber bushings.
exE36M3487.50 |
10-05-2020, 11:59 AM | #48 | |
Rep 320
I've run a few autox events with them now and I think i added about -1.3 deg...plus what the plates give me. front end really sticks. I would never need that much for lapping though. |
10-05-2020, 12:47 PM | #49 |
Moto Lover
187
Rep 591
Drives: '19 BMW S1000XR
For the guys that run this, did you guys run this setup in conjunction with camber plates?
My goal is to get -2 degree camber up front and bought camber plates. However, I feel like I am going to regret the camber plates because of the NVH it's going to create. I should say I am ok with some NVH but not a tremendous amount. |
10-05-2020, 02:18 PM | #50 |
Rep 3,540
I ran this in conjunction with Millway street camber plates. There isn't an issue "doubling up."
10-05-2020, 03:03 PM | #51 | |
Moto Lover
187
Rep 591
Considering this route versus the camber plate route as I am worried I am going to want to remove the camber plates down the road. Edit: Nevermind, found it! |
10-16-2020, 03:48 PM | #53 |
Rep 77
I ran the KMAC camber bushings for ~9k mi with OE top hats. I never needed an alignment check in that time, but didn't notice any drift in alignment based on how the car drove or tire wear.
I thought the increase in NVH was very small other than there was eventually some squeaking over speed bumps. Typical for poly bushings from what I've read, and it could have been either the KMAC LCA bushings or the Powerflex TS bushings. Just switched to VAC control arm bushings and Millway street camber plates. There's certainly more audible transmission of road imperfections with this setup, but it's also a step up in steering responsiveness. (If anyone wants the used KMAC bushings PM me.)
F31 328i xDrive, EBII
11-03-2020, 10:33 AM | #54 | |
Moto Lover
187
Rep 591
I bought my KMAC adjustable bushings from FaRKle! not too long ago and finally got them dialed in. I own a RWD F30 335i and got up to -3 degrees of camber (while being lowered on Bilstein PSS10 that I bought from KTW). I have the front and rears at -2 degrees and am pretty happy about that.
So far, NVH is very little, or if any at all. I will say, my caster is on the positive side (I need to check my alignment sheet) and causes my tires to rub right where the fender and bumper meets. I need to find a way to adjust this... (Almost seems like I should of gone camber plates). Quote:
11-03-2020, 10:44 AM | #55 | |
Rep 3,540
11-03-2020, 10:52 AM | #56 |
Rep 77
Yep, VAC puts their monoball in both pairs of front control arms, and they sell them as the monoball pre-installed in a new arm.
11-05-2020, 10:41 PM | #57 | |
Rep 95
11-06-2020, 12:12 AM | #58 |
Rep 77
11-11-2020, 11:11 AM | #59 |
Moto Lover
187
Rep 591
If anyone is itnerested, I will have this kmac setup for sale pretty soon (It will come with either RWD or xdrive LCA). These were bought from FaRKle!
11-14-2020, 01:22 PM | #60 |
Rep 79
I wonder if you could use these to correct the roll center a bit on a lowered car to help preserve the OE roll gradient. I think some of the weirder feeling lowered cars I've driven may be coming from the mismatched change in roll rates front to rear.
I don't have any data to back this up, but it's something I've been curious about. Most suspensions drop the roll center faster than they drop the CG, but the phenomenon tends to be more prevalent on strut cars. If the roll moment gets "more bigger" in the front than it does in the rear, the front is going to try to roll at a higher rate than the rear, which then introduces the chassis as an undamped torsion spring between the two. Again, these are all generalizations and not based on modeling of the F30's specific kinematics. I've been really looking at the Swift Spec-R springs lately and it looks like they stiffen the front relative to the rear much more than, say, the Eibach Pro-kit and I wonder if they're trying to compensate for the increased roll moment in the front to keep the roll gradient consistent on the assumption that sway bars won't be changed. There isn't much data for them on the F30 (especially on an xDrive), but they seem to be really popular in the F8x camps where they also increase the front rate a lot relative to the rear rate. Thoughts? |
11-15-2020, 10:02 AM | #61 | |
Rep 320
However, if you need camber I would start with camber plates first and if you need more, get the KMACs. Most decent plates will get you close to -3 degrees and i doubt you would need more than that. Plus plates are easier to adjust and do not affect the toe alignment as much as the KMACs. |
11-15-2020, 07:48 PM | #62 |
Car Hypochondriac
335
Rep 903
11-16-2020, 12:18 PM | #63 | |
Rep 3,540
The VAC monoballs don't alter camber at all from the stock rubber bushings. Both have the bolt hole right in the middle of the assembly.
11-22-2020, 08:16 PM | #64 | |
Car Hypochondriac
335
Rep 903
I'm assuming they are not the M arms, but you can probably just install the VAC bushings into M arms, yes?
Power mods: VRSF IC/Catted DP - FTP CP/BP - AFE Cat-back - BM3/XHP - Dorch S2
Handling mods: Koni yellow - Eibach prokit - Millway street - M Performance LSD - M3 brakes - EBC bluestuff Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327 |
11-22-2020, 08:28 PM | #65 |
Rep 272
11-24-2020, 04:46 PM | #66 |
Rep 128
Just wanting to reiterate how rubbish any eccentric camber PU bush is in the lower control arm joint.
Don't bother. I have personally seen too many cars fail. KMAC are a local manufacturer. Kevin (owner) has arsed-around too many of my friends with ill-fitting parts. He no longer gets my support. |
