BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > PSA for high mileage 335's, check your coolant hoses...
      10-22-2018, 02:29 PM   #1
Niart906
Drives: 2017 M3, 2003 M3
It should come as no surprise to anyone familiar with old BMWs, but their cooling systems were often less than reliable. I had hoped that with BMW's newest generation of cars that this was no longer the case. However, I recently had a small coolant hose break and send coolant all over my engine bay, this would have left me stranded had I not been parking the car in the garage after a wash.
The hose that failed was #2 in the diagram below. The plastic male barb snapped at the connection to the larger plastic quick connect.
The exposed plastic was very brittle so no surprise it broke when it did. My 2013 335i has just over 70k miles on it. I would strongly suggest anyone near my car's age/mileage to preventatively replace this hose. In general the N55 has been amazingly reliable when compared to BMW's prior efforts. So I'm hoping this is an isolated issue. It looks like BMW updated the part number for this hose, so maybe they've already created a fix. I'll compare the two when my new hose arrives tomorrow.
TLDR- Replace this $40 coolant hose on your high mileage 335 before it fails and leaves you stranded.
2017 F80 M3 - Mineral White/Amaro Brown
2003 E46 M3 - Jet Black/Cinnamon
Appreciate 18
_tlink98.00
perryo91372.50
kern4174445.00
Zanity731.00
Fuller1216.50
perezr10140.50
Stanio67.00
EDWYER1669.50
thug10820.50
Rebound152.50
BWbimmer276.50
      10-22-2018, 02:33 PM   #2
Zanity
Zanity's Avatar
Drives: 428i
Thanks for the heads up man.
      10-22-2018, 05:52 PM   #3
Framamind
Mr. Discombobulator
Framamind's Avatar
Drives: 335i
Yep, mine gave out on the way to work last week. 62k miles
Those smaller hoses are usually the first to go.
'14 MSport 335i | Melbourne Red | MPE | MPBBK | MPS | MPLSD | xHP Stage 3 | MHD Stage 2
      10-22-2018, 06:46 PM   #4
SteelBlue46
Drives: Alpine White '13 335i XDrive
Had this hose break the exact same spot about a month ago! luckily very cheap from dealer and easy fix! I noticed my new hose was alot more flexible than the old one which was so brittle I grabbed it and it crumbled.
      10-22-2018, 06:54 PM   #5
perryo91
perryo91's Avatar
Uganda
373
Drives: 335
Great PSA man, mine broke at around 40k, i stopped the second I saw steam then had to wait 3 hours for a tow but definitely recommend replacing it.
Hi
      10-22-2018, 07:30 PM   #6
Niart906
Interesting that the new hose was more flexible. Hopefully this part was revised so this won't be a repetitive issue in another 40-70k miles.
      10-22-2018, 07:35 PM   #7
chiefneil
Drives: 2014 335i M-Sport
Thanks for the tip, and wow that is a clean engine bay for a 5-6 year old car!
_Tony_12.50
      10-22-2018, 07:49 PM   #8
Eddien123
Drives: F30 335 6MT
already broke mine. The day I got it delivered to me actually. Have no fear though. Even from the dealer it was less than $40 and took me not even a minute to install.
      10-22-2018, 08:02 PM   #9
Polo08816
Drives: 2014 335i M Sport
This part broken on me when I was attempting to replace the accessory belt and belt tensioner. It broke at exactly the same place it did for you. It left my car stranded at APG for about a week. It was really easy to reinstall - took about 5 mins. And another 15 minutes to bleed the cooling system.
      10-22-2018, 08:40 PM   #10
Niart906
Fortunately I caught it quickly and lost very little coolant, so I'm hoping I don't have to bleed the system.
For those wondering, this is how you bleed the cooling system on our cars. Stolen from another thread...
Originally Posted by humbertob View Post
17. Remove the bleeding screw (black screw) from the overflow tank
18. Using 50/50 BMW Blue Coolant/Distilled Water fill the overflow tank slowly until the coolant starts to escape from the bleeding hole at the overflow tank
19. Re-attach the bleeding screw
20. Replace the overflow tank cap
21. start the ignition on the car, without starting the engine
22. select the hottest temp on the a/c unit
23. select the lowest fan speed on the a/c unit
24. push the accelerator down to the floor for 10 seconds
25. you'll start hearing that the water pump starts working, it's bleeding the coolant system for you
26. Wait for 12-13 minutes until the water pump completes the bleeding cycle
thug10820.50
      10-23-2018, 02:37 PM   #11
Niart906
UPDATE: Swapped in the new hose this morning and topped off the coolant. Didn't need to bleed the system luckily.
The new hose is a bit more flexible than the old one, but otherwise identical. Fingers crossed this one lasts a bit longer.
      10-23-2018, 04:16 PM   #12
Zanity
Zanity's Avatar
Drives: 428i
How can you tell if you need to bleed or not without driving it though ???
      10-23-2018, 06:00 PM   #13
Sea-Tac
Sea-Tac's Avatar
Drives: 2108 X3 xDrive30i
Good advice...thx
      10-23-2018, 06:14 PM   #14
Niart906
It all depends on how much coolant you've lost, my reservoir was only slightly low prior to my top off. Had it been empty I would have done the bleed procedure before trying to drive anywhere.
After replacement just watch your temp gauge as the car warms up. It should get to it's normal temp range then stay there, any hotter and you need to bleed/top off coolant.
      11-03-2018, 10:31 PM   #15
atlguy
atlguy's Avatar
26
Drives: 2014 335I MPPK
Whats the updated part number?
      11-04-2018, 09:36 AM   #16
Niart906
Use realoem.com or call your dealer. You can’t order the old part through the dealer anyways. It’s NLA.
      11-04-2018, 01:20 PM   #17
Mobster1983
Drives: 2014 BMW 335i
Glad to see this thread here. Had my car in for service a couple days ago and the dealer said this hose was brittle and needed to be replaced. They wanted over $300... Looks like I will just order the part and replace it myself.
Rebound152.50
      11-05-2018, 02:53 PM   #18
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
That's horrible. Should be no more than $40 plus 1 hrs labor and a splash of coolant.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      11-05-2018, 03:04 PM   #19
Pray for Mojo
Drives: 2014 M235i & 2018 X3 M40i
My coolant overflow elbow broke when doing the pure inlet. Those plastic elbows are garbage, the washer fluid elbow on the underside of the hood also broke when closing the hood normally.
      11-05-2018, 03:45 PM   #20
samsont
Drives: 2012 BMW 335i
Mine broke back in May at the same exact spot. This is the part number I ordered:
17 12 8 570 061
      11-05-2018, 04:00 PM   #21
sickF30
Drives: F30 335i
Another victim here a few months ago at 65k miles. Happened while I was in a McDonalds drive thru. hahaha
      11-06-2018, 11:06 AM   #22
_bdiddyb_
Drives: 2013 335i
Yup - mine broke last year at the reservoir end. The constant heat/cool caused the plastic to curled up touching the hood and actually prevented it from fully closing. POS snapped in 2 when I slightly pressed it down out of the way. The new part# has a wider curve preventing rubbing against car's frame.
