07-11-2021, 02:11 AM | #1 |
Rep 161
Eibach Springs for F33 435d xdrive
We recently got an F33 435d xdrive and I was planning on installing Eibach springs. Sadly I see from their website they don’t seem to do a kit for a 435d xdrive convertible. I have found 1 case where someone on here fitted springs from a GC, but I was just wondering if anyone else has done this? I wouldn’t be massively keen on messing with axles loads and non compatible kits unless I was 100% it would work with no side effects.
There’s a few references to Eibach making ACS springs too, which is strange in that ACS do do a kit for the F33 435d xdrive?! Any help appreciated! |
07-11-2021, 04:38 PM | #4 | |
Rep 100
08-11-2021, 04:54 PM | #6 |
Rep 161
No further on. I was going to get the e10-20-031-06-22 kit from the F36, but not sure if I’d be safer building up a kit myself from individual pairs (rear springs from an F33 430d and fronts from a 435d)?
What is different about an xdrive that causes Eibach not to list RWD models as compatible? Are the shock/spring assemblies physically different? if not, surely if the weight rating is right that should be all that matters? I’m probably over analysing it but I want to be sure I’m doing it right. Last edited by Lyons; 08-11-2021 at 04:59 PM.. |
03-06-2023, 06:01 PM | #8 | |
Rep 100
springs arent worth it considering you NEED bumpstops in order to maintain ride quality and maintain the quality of your car. they also cost almost as much as just installing a coilover kit. so just do the coilovers if you really want. coilovers are also much easier to install and uninstall (especially the nonadjustable ones). |
