07-12-2021, 02:58 PM | #1 |
Rep 100
F32 Strut Stuck in knuckle
Hi, re-installing my stock springs. Front right strut is stuck in the knuckle spindle. Have used the spindle spreader, wd40, penetrating fluid. I measured the amount of shock below the spindle and it hasn't moved at all.
What do I do? |
07-12-2021, 04:28 PM | #2 |
Rep 1,523
Give PB Blaster a try and let it soak. then use a big fucking sledge hammer with a block of wood.
07-12-2021, 07:29 PM | #3 |
Rep 1,369
Hate to say it but you may be forced to do it the bmw way. Collar bolt out, push in the half shaft, tip out the strut, pull it out from the collar. Remember, one time use of those collars bolts
07-12-2021, 08:39 PM | #4 |
Rep 1,572
07-12-2021, 08:47 PM | #5 | |
Rep 1,572
Is this on the drivers side? Have you tried the passengers side and have the same issue? Did you remove the drivers side Headlight Leveling Regulator rod from the control arm? |
07-12-2021, 08:52 PM | #6 | ||
Rep 100
