BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Alignment specs for coilover suspension
      07-14-2021, 09:11 AM   #1
markoz28
Drives: BMW 2017 340i, BMW 2020 M340i,
Need some advise and alignment setting that have worked for some?
I have a 2017 340i with KW V2 coilovers. Car is lowered to 25.5" in the front and 26" in the rear measured from fender to floor. Wheels are 19x9 with +30 offset and 19x10 with +42 offset. Tires are 245/35/19 front and 285/30/19 rear. There is a 1/2" gap between the front fender and tire, and 3/4" gap between the rear fender and tire.
Im leaning towards a -1.5 camber to all four corners but I really dont know anything more about this.
Any help is appreciated.
      07-15-2021, 10:37 AM   #2
MacklinUSOB
Drives: f30 328i 6MT Sport
If you did not also add camber plates with the V2s camber will not be adjustable up front. The rear has a lot of adjustment but I would not suggest increasing it over the stock numbers since it will only diminish the benefits of the camber you gained up front from the ride height change. If the car is street driven stock toe is also fine.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines |
Past: E36 328is & E38 740i
      07-15-2021, 03:57 PM   #3
markoz28
First of all, thank you so much for replying. This is the first car forum that I have been in that has so little participation. I'm in another forum for my 2018 camaro ZL1 and there is plenty of feed back and individuals sharing knowledge.
That's disappointing to not be able to adjust camber without plates. I was hoping for 1-1.5 of negative camber up front to give a bit more clearance.
Camber plates are not plentiful for this car and from what I have read cause lots of noise.
      07-15-2021, 04:11 PM   #4
MacklinUSOB
No problem. Yeah, the static camber up front has been a common theme on BMWs for quite some time. I will tell you I got about -1.7 camber up front changing to the M3 control arms while on V2s, however, as far as camber plates go, check out Millway's Street offering, they are a great option if you are trying to limit noise. I swapped to those after the normal monoball assembly expired and it is a huge improvement in the noise department.
      08-15-2021, 11:35 PM   #5
Onizukachan
Great Teacher
Onizukachan's Avatar
1086
Drives: 06 e91 325ix
2006 E91 325ix  [10.00]
2006 Mini r53 JCW  [0.00]
2005 Mini r53  [0.00]
If you are running staggered rears, going square will reduce oversteer significantly, negating the need to run more front camber and thus camber plates.
over Terra (one of 1), Nav, Sport, L7
A few OEM+ mods:
MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come…
