09-10-2020, 01:32 PM | #1 |
Rep 423
+ET30
Anyone successfully ran 19s with +30 offset on stock m suspension f36, f30? stick out much, rubs?
thanks
//'17 F36 440i Mineral Grey
//MPPSK w/carbon tips //Apex ARC8 255/40/18 //MST intake //AutoTechnik brace |
09-10-2020, 02:38 PM | #2 | |
Rep 6,683
Here is an example of a stock F31 on 19x9" ET30 SM-10 wheels wrapped in 245/35-19 Michelin PS4S tires: With stock X-drive ride height, as you can see, this setup does poke slightly. However, there was no rubbing under suspension compression with these wheels and tires on a stock F3X. With lowering springs or a slight drop in ride height, typically most of the "poke" with this setup goes away. If you have any other questions, please let me know! -Geirsen
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
obzen183.50 |
09-10-2020, 03:17 PM | #4 |
Rep 423
What are you running for front tires? are you xdrive ?
09-10-2020, 03:19 PM | #5 | ||
Rep 423
Thanks for the feedback greatly helped!!
09-10-2020, 04:57 PM | #6 |
Rep 113
Im running 255/35/19 et +35 on 9.5 wide square no rub. 9.5 wide +35 is the max you can run up front stock anything bigger it contacts the strut. So at 8.5 wide you should be good.
09-10-2020, 05:08 PM | #7 |
Rep 58
245/35 tires and I'm RWD. It's a square set though so should be fine with xdrive.
09-11-2020, 02:04 PM | #8 | |
Rep 148
09-11-2020, 04:37 PM | #9 | ||
Rep 58
Stlblues67.00 |
09-14-2020, 09:26 AM | #10 |
Rep 423
Do you think running an aggressive fitment such as ET30 will have long term negative impacts on suspension and the rest of the car?
09-14-2020, 09:38 AM | #11 | |
Rep 58
09-14-2020, 09:42 AM | #12 | ||
Rep 423
09-14-2020, 09:59 AM | #13 | |||
Rep 58
09-14-2020, 10:43 AM | #14 | ||||
Rep 423
Bt130915.00 |
09-14-2020, 05:11 PM | #15 |
Rep 11
Where did you find the info that this is the max you can run up front on stock suspension?
09-14-2020, 06:46 PM | #16 |
Rep 113
I know from personal experience picture below of the inside of my front wheel and strut distance on stock m sport suspension. The only way to run higher offsets beyond +35 on a 9.5 wide rim is to run spacers.
09-14-2020, 07:01 PM | #17 |
Rep 11
Do you know the maximum tire width on a +35 for rear? Im looking to do a 245/35/19 front and 275/30/19 rear on Aodhan AFF7 staggered (8.5 and 9.5) both +35.
09-15-2020, 04:24 PM | #18 |
Rep 113
Ive seen guys run 19 x 10 ET 40 w/ 275/35 in the rear successfully but they are on coilovers. you may want to wander over to this thread https://f30.bimmerpost.com/forums/sh...1166496&page=9 give you some better options. Also you want to keep the rolling diameter less than 1% on your tires right now you are at 1.2 % with those two tire suggestions so that could potentially lead to transfer case issues if nobody has told you about this yet.
09-15-2020, 05:45 PM | #19 |
Rep 72
et30ish... ;)
Here's mine - 19x8.5 et35 with 255/35/19 square. However, i'm running 5mm spacers in the front and 12.5mm spacers in the rear. So effective offsets are Front 19x8.5 et 30 | Rear 19x8.5 et 22.5. Lowered on Eibach Pro Kit
2015 - F30 328i RWD Sportline - Mineral Grey - Alcantara/Nappa Steering Wheel with Paddle Shifter retrofit - 437m - Eibach Pro kit with Koni Sports, m3 bump stops.
Bt130915.00 |
09-23-2020, 11:06 AM | #20 | |
Rep 423
