BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Coding error. CAFD not found
      09-09-2020, 10:06 AM   #199
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
Originally Posted by kd8 View Post
Hello Shawn and anybody else, who can help.
I'm trying to retrofit heated steering wheel, according to this post:
https://f30.bimmerpost.com/forums/sh....php?t=1231186
I think I did hardwiring ok, with coding I have problems. I am total beginner at coding.
First I added option 248 to Salapa elements and tried to VO code FEM_BODY, KOMBI and HU_ENTRYNAV.
It did not work, I got errors: file for"cafd.."not found.
When I read coding data, I get this error also on other modules, not just three I tried to VO code.
So I am assuming that this year, when car was at the dealer, they changed firmware. Before that I have successfully coded auto start-stop, but dealer reseted it.
So I downloaded latest psdzdata data I found 4.21.32, tried to read coding data FEM_BODY, same issue, same error CAFD_00000794_018_070_004 Fehler: File for "cafd_00000794_018_070_004" not found![C012]
Then I tried to "Detect CAF for SWE" for FEM_BODY, I get error: failed to get caf for swe...kiss error
According to Esys I-step of my car is F020-17-11-530
What should I do? Try with differrent version of psdzdata? With older version I had It did not work either.
And am I doing everything correcly or should I try different way? Is it necessary to VO code all three modules I mentioned or is it enough to code just FEM_BODY?
I have basic KOMBI so warning for "heated steering wheeel turned on" probably won't work anyway. For HU I don't know if it has anything to do with heated steering wheel option.
I would really appreciate more detailed answer, as I am new at coding.
My car is 2014 F31, I use Esys 3.27.1, Enet cable. I connect via VIN, F020 (not direct).
Thank you!
I replied to your same PM.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
      09-10-2020, 01:11 AM   #200
kd8
Slovenia
Drives: F31 318d
Yesterday I could not beleive when I saw message on my kombi: Steering wheel heating activated
It is in Slovenian language
Big thanks to ShawnSheridan
      09-10-2020, 08:00 AM   #201
shawnsheridan
      09-13-2020, 09:26 AM   #202
darkblade17
Drives: 2015 BMW 320i
Hello, I need some help here!
I recently got my firmware car updated at the dealer and lost all my updates.
I tried to do set the FDL again and I got an error
File for "cafd_ffffffff-255_255_255" not found!
Tried to reset Fem_body injecting new cafd, following this steps
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on desired ECU => Click on "Detect CAF for SWE" => Select the replacement CAFD from above => Select OK => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE.
but after clicking CODE I get the same error
I am using esys 3.30 and v.4.25.12_PSdZData_Full.
My I-Step is F020-20-07-530
I-Step (Current) F020-20-07-540
Could anyone help me please?
      09-13-2020, 09:31 AM   #203
shawnsheridan
You do it wrong. If you did as written above, it would be looking for the CAFD you are injecting, not for "cafd_ffffffff-255_255_255".
      09-13-2020, 09:50 AM   #204
darkblade17
My bad! I just noticed that I have to pick one version of the list when injecting!
Thanks!!
      09-13-2020, 09:56 AM   #205
shawnsheridan
Thanks!!
      09-16-2020, 12:38 AM   #206
mih222001
Romania
Drives: Bmw F30 328xi
Cafd not found
Hi all,
While trying to code REM and TRSVC after a reverse camera retrofit on a 2012 F30 328i, I get in E-Sys the error cafd not found on REM module. I am trying to achieve installation via coding 3AG option.
The HU_NBT module gets coded correctly, and when I put the car in reverse I can see the rear camera menu, but unfortunately no image.
iSTA says that the TRSVC module is not coded on the car.
I am using Esys 3.27.1.
On February this year the dealer updated the software on the car. The I-Level of the car is F-020-19-07-530. I cannot find in the cafd list of the TRSVC module a matching version cafd.
As I am complete newbie to coding, I hope that this makes sense. Can you let me know what can be done? Thanks a lot!
      09-16-2020, 10:26 AM   #207
shawnsheridan
Originally Posted by mih222001 View Post
Hi all,
Update your PSZData. PM sent.
