BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Tire pressure coding question
proTUNING Freaks
      09-15-2020, 07:14 AM   #1
TommyG-inFlaNow
TommyG-inFlaNow's Avatar
153
Drives: 2015 435 Vert Alpine White
2015-435 convertible....is it possible for our tire monitors to read out the actual pressure?
It drives me nuts wondering if it is actually 1 pound under the threshold or I actually have a low tire. It seems its always my passenger side too, so not like I can stick my head out at a light and check.....and god forbid my wife would know if a low profile tire is low or normal
      09-15-2020, 07:28 AM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
If you have a 2015 US version your iDrive does read out the actual pressure.
      09-15-2020, 10:20 AM   #3
TommyG-inFlaNow
153
I am slightly retarded but I checked the manual online. Mine will only come up similar to my E93 and say the tire is low, not measure the actual pounds. UNLESS, there is a setting that I need to change.
If I reset the TPMS and then drive above the 19mph limit then it will go green or stay illuminated as before.
It is an 8/14 production date, maybe it is a later production?
      09-15-2020, 10:59 AM   #4
Siki78
Drives: F30
https://f30.bimmerpost.com/forums/sh....php?t=1104376
Read here i think you will need just coding and new sensore
      09-15-2020, 12:21 PM   #5
TommyG-inFlaNow
153
Thanks!
      09-15-2020, 03:17 PM   #6
Billfitz
Billfitz's Avatar
You should have it, unless your car was originally sold in Canada or Mexico. Do a VIN search, if you have tire pressure display it will say so, option S2VB.
      09-15-2020, 03:36 PM   #7
TommyG-inFlaNow
153
Wheels And Drive
S258 Tyres With Runflat Properties
S2TB Sport Automatic Gearbox
S2PE BMW LA Wheel, M Star Spoke 400
S2VB Tyre Pressure Display
Sure as shit...Ill have to mess with it more. I tried after lunch but still couldnt get a numeric readout.
Thanks for the guidance though. I hope they didnt sell me the wrong year monitors for my A/M wheels
      09-15-2020, 04:03 PM   #8
atzebmw
Drives: BMW 335XD F30 LCI
Maybe the previous owner or someone decoded the 2VB because he didn't want to buy new sensors or so.
      09-15-2020, 04:31 PM   #9
Billfitz
Billfitz's Avatar
It takes all of maybe ten seconds to get the pressure read out. Go to vehicle information> vehicle status> tire pressure monitor. You have to do it while the car is moving.
      09-16-2020, 06:47 AM   #10
TommyG-inFlaNow
153
This is def a possibility b/c the run flats were also changed out. I really have to see if my BMW dealer sold me the correct sensors b/c as Billfitz mentions below, I do believe I have done that exact procedure before
Yeah, I think I have an issue b/c as you mention its pretty darn straight forward
      09-16-2020, 07:23 AM   #11
Billfitz
Billfitz's Avatar
I doubt it's the sensors. The two TPM options use different sensors in the wheels and different receivers as well, so if you had the wrong sensors the system shouldn't work at all. If you have Bimmercode connect to the car and open the head unit menu. There's a section for tire pressure/temperature display. The choices are pressure and temperature, pressure only and none. If it shows none as the current checked option that's the problem.
      09-16-2020, 09:49 AM   #12
TommyG-inFlaNow
153
I do have it, and I will try that!
Thanks
