BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > airbag deploy. need help
      09-16-2020, 07:07 AM   #1
anders0nf320
Drives: bmw 420i
hi therr... i just purchased a 2018 f36 bmw with airbags all deployed.
I have replace everything, belt tensioners and airbags. airbag light is still on despite using e-sys transmitter... I have purchased a set of ACSM and ICM module but it still didnt work.. It shows on the idrive that system srs restraint, and pedestrian protectin system failure... How do i go about rectifying this issue? Can i use back my own ACSM and ICM and to somehow delete the crash data? Pls help!
      09-16-2020, 04:59 PM   #2
sdbmwcoding
Drives: BMW M3
What codes were present with the original ACSM module installed after replacing all the airbags and failed hardware and clearing codes?
      09-16-2020, 07:49 PM   #3
anders0nf320
Drives: bmw 420i
ICM sporadica fault
ICM X-Y Sensor
And pedestrian protection system error on I-drive
      09-26-2020, 07:57 PM   #4
Bangher
If all airbags went off, then most likely a seat belt is locked up as well.
