BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > BMW 430i Sport Line has much better handling
      08-11-2017, 07:24 AM   #45
RoundelM3
RoundelM3's Avatar
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
In the 3 and 4-series, you have "base" suspension, M-Sport suspension, and the Dynamic Handling/M-Adaptive suspension. All are available in both model lines. My 2013 335i M-Sport sedan has the DHP/Adaptive M suspension, and when in Sport or Sport+ modes, it's much stiffer than it is in Comfort mode. The stiffer suspension option for the 3-series may come standard in the non-base 4-series, but they all have the same basic components. It all depends on what options you have in the car and what mode you're driving in.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey
      08-11-2017, 08:06 AM   #46
AudiA4
AudiA4's Avatar
648
Drives: 2022 G01 X3 M40i (Black/Black)
Agreed on the variations on the 3, but as I understand it, the 4-series has different hardware/geometry in the suspension setup (it's its own unique setup). BMW's own documents allude to this, but I've never seen any definitive list of the differences.
2022 G01 X3 M40i (Black Sapphire/Black), HK, DAP, PAP, Shadow Line
2014 F30 335i (EB) 6MT, M Sport, Premium, Tech, DHP, HK, CW, M Brakes, M Exhaust
2006 E90 330i (Silver) 6MT, Sport
      08-11-2017, 01:03 PM   #47
upsidedownfunnel
Drives: 2014 335i
2014 BMW 335i  [0.00]
I can say definitively that the equivalent suspension trim for the 4 series is always stiffer. So a base 3 series is definitely softer than a base 4 series, an M sport 3 is softer than an M sport 4, and the same goes for the adaptive.
      08-11-2017, 06:24 PM   #48
oonowindoo
Drives: 2021 M340i RWD
When you compare apple to apple. you will notice the difference. If you start comparing between M sport with M adaptive suspension vs. base 428, then things will get confusing.
yes i agree they do have the same basic component but for some reason, there is a very noticeable difference. I think no one would really know why, except BMW themselves.
      08-11-2017, 06:30 PM   #49
oonowindoo
It is not just only stiffer, i feel it is just better calibrated.
I think this is not exclusive to 4 series. I know C class coupe drives somewhat differently than sedan as well... and G37/Q60 Coupe vs Q50/G37 sedan.
I thought 4 series suspension was too stiff after having it for a while....it turned out that runflat really messed up the ride.
Now 4 series with proper summer tires = stiff without being too stiff because of the runflat.
When i had my F30 and change from RFT to summer, the car handled much better but it also felt even softer than with RFT at the same time because of the sidewall.
      08-12-2017, 08:15 AM   #50
RoundelM3
RoundelM3's Avatar
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
With more than 50 years of driving under my belt, including competition and high-speed driving schools, I can clearly tell the difference between different models of the same chassis. How about somebody check out the suspension part numbers between simiar models of 3- and 4-series (340i vs. 440i or 335i vs. 435i) cars with the same options? Springs, shocks, sway bars, bushings, control arms, etc. If they're different, then that's a whole 'nother story. But 2 body styles sitting on the same chassis with the same suspension options, tires, and driving-mode settings with one feeling "stiffer" than another just doesn't add up.
      08-15-2017, 11:39 AM   #51
Dmitry83
Russian Federation
54
Drives: F30 320i (328i ECU) M-Sport
OK, let's go with 428i vs 328i (Pre-LCI accordingly).
4 and 3 have different
- shocks
- front & rear subframes
- rear knuckles (or hub- don't know that part exact name on English)
Last two make the track (axle) 14mm wider.
Rear sway bars of both 4 and 3 are equal 12mm with standard suspension.
3 has 13mm with M-Technik, 4 has 14mm with 14mm M-Technik.
Front sway bars are equal- 24mm standard and 24,2mm M-Technik.
Also 4 has the reinforcement V-bar under the bottom.
All the control arms & bushings are equal.
That's all the differences- seems nothing dramatic, but as a bit experienced drivers know the different settings of springs and shocks can transform a car you cannot recognize it if driving blind.
For now having added the bits in the signature I've finally got a true BMW feel. (Will also risk to install M135i front and rear sway bars this week!)
430i vs 330i (LCI):
Shocks are new to Pre-LCI on both 4 and 3.
Rear subframes- unchanged.
4 rear sway bars are now same 12mm for standard, 14mm (former M-Technik) for Adaptive, 15mm for M-Technik
3 rear sway bars options are unchanged.
4 front sway bar M-Technik is 25mm, while 3 has 24,6mm M-Technik. Standard ones are equal for 4 and 3- no data on thickness, but seems 24mm as on Pre-LCI.
Again- all control arms & bushings are equal on 4 and 3- only the front axle is wider by 14mm and rear axle- by 22mm on 4 Pre-LCI.
LCI 4 and 3 have equal front axle, rear is just 6mm wider on 4.
That's all, folks!)
'13 F30 320i (328i ECU) RWD M-Sport
Michelin PSS, M-Sport brakes, 320i LCI muffler
F32 bottom V-bar
F80 bottom reinforcement plate
Koni Sport, M-Performance springs, M135i Anti-roll bars
otay826.00
      08-16-2017, 07:23 PM   #52
ska///235i
***** noob
ska///235i's Avatar
Drives: 325xi>M235i>428GCx Mspor
2006 325xi  [0.00]
Wait, the 4 series have the side vents....thats why it has better handling
2006 325xi (Sold)
2014 M235I (Current)
2015 428xi Gran Coupe (STB)
      08-17-2017, 12:46 AM   #53
440xiGCMsport
Drives: Estoril Blue
The 4 series has a wider track and a stiffer body. BMW reinforced the 4 series body to be more sports car like so even if you mount the same suspension on a 4 series it would handle better since the suspension is only as good as the body it is mounted on. That said BMW most likely take the suspension in addition to the chassis of the car.
      08-17-2017, 01:11 PM   #54
bimmer_335
Drives: 540 mSport
Originally Posted by JamesNoBrakes View Post
The handling on my 428GC drive was poor IMO. Granted, I didn't expect it to match my previous camaro SS that had a few mods, but the 428 definitely didn't live up to BMW hype. I did test drive it first, but i can't imagine how bad the pre-LCI is given all of this. With the mods I've done to the suspension on the 428, it lives up to what I'd expect it to come with or be available with. The x-drives are especially bad, having a raised ride height and no sport suspension as compared to the non-x models. Now in sport+ I forget it's an AWD car and I get some nice neutral handling on the snow/pavement without too much oversteer.
I'd never buy a BMW without a sport suspension... regardless of which car in the line up you look at, without sport suspension they ride like grandma's car.
      08-17-2017, 05:31 PM   #55
Dmitry83
Russian Federation
54
Body stiffness on its own does not guarantee better handling- the difference in body flexibility between 2 door and 4 door is not that significant as if compared to GT or Converible. Rear clued-in glass and the reinforcement shelf and thick sqare bar under it provide the most of the rigidity to the body of both sedan and coupe, where GT has a huge hole covered with boot lid.
Just the good shocks and springs transform the 3 you will not recognize it is the same car blindfolded.
Also 4 has the V-bar under the bottom, 2mm thicker rear sway bar, and stiffer settings of shocks and springs. These little cheats make it much better handling with no surprise due to extreme chassis sensibility.
So I think the 3 is made this grandma's handling feel on purpose- to make people want a F80 soon after F30.
At the same time the chassis balance and potential is brilliant- again just try one nice tuned F30- you'll be amazed.
The even better opinions on M3 handling compared to M4 also give some things to consider on.
F32 bottom V-bar
      08-17-2017, 05:35 PM   #56
Dmitry83
Russian Federation
54
Totally agree.
For many years I try to buy only sport-adjusted BMW models. This time with F30 I had to take the very-very fresh example with M-Sport package for a good price, which had a standard suspension, that I had to replace completely with M-Technik + few additions. Now it is a true BMW as I used to feel these cars.
F32 bottom V-bar
      08-17-2017, 06:22 PM   #57
misterjim
Drives: 2008 e93 335i
- shocks
430i vs 330i (LCI):
That's all, folks!)
You list shocks being different in your list but not springs. Are the springs different as well?
      08-18-2017, 01:41 AM   #58
upsidedownfunnel
Drives: 2014 335i
Springs are definitely different. They're different part numbers, sit slightly lower, and have higher spring rates.
      08-18-2017, 05:00 AM   #59
Dmitry83
Russian Federation
54
Exactly.
F32 bottom V-bar
      08-18-2017, 04:18 PM   #60
misterjim
Exactly.
How about for an x-drive 435 - is it firmer than an x-drive 335, with different part numbers, etc?
      08-21-2017, 05:08 AM   #61
Dmitry83
Russian Federation
54
Never driven an X-Drive 335 or 435ii, so can't tell- sorry.
F32 bottom V-bar
      08-22-2017, 07:16 PM   #62
misterjim
Further confirmation of the differences in suspension. If you look at the 4-series sticky above under the suspension section:
Chassis / Suspension / Brakes / Wheels
Springs and dampening, axle kinematics and elastokinematics tailored for 4 Series (although chassis construction based on F30 3 Series)
Modifications to camber angle, the track and the roll center (0.7 inch lower than 3 Series Sedan)
Particular attention paid to strengthening front section of the car
Additional strut between front axle subframe and body sill
Lightweight aluminum torque struts, wishbones, swivel bearings
      08-23-2017, 06:06 AM   #63
Dmitry83
Russian Federation
54
Yes, there are two longitudinal struts between the subframe & the body. If someone could only tell are there the mounting places on the F30 subframe for it- would be interesting to add it (same as the rear V-strut).
Swivel bearings are different to increase the track by 14mm (rears are also different for the same reason).
But what is meant by "Lightweight aluminum torque struts, wishbones"? All suspension elements (besides front subframe, shocks and springs) are totally equal for F30 and F32.
F32 bottom V-bar
      08-23-2017, 12:48 PM   #64
geyas
Drives: x5
Have not tried series 4 yet, but it looks like this thread is very interesting
      08-23-2017, 05:56 PM   #65
sr5959
Drives: 428GC M-Sport
My 2015 4GC has much better handling than my pre-LCI 3. It also has 5 bolt mountings for the front shocks as opposed to 3-bolt on my 3. Even if all components were similar a wider, lower car with better weight distribution is bound to handle better.
CalCarNut1060.50
      08-23-2017, 07:05 PM   #66
CalCarNut
CalCarNut's Avatar
Drives: 2015 F36 Jet Black Sport Line
4 series FTW
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint|
