11-15-2021, 03:50 PM | #23 | |
Rep 21
11-15-2021, 04:05 PM | #24 |
Rep 7,597
The problem with getting a N55 now is that you won't be able to find a CPO one, so you will be looking at other trade-ins or private party. That raises lots of other questions, like service history, mods/tune in its past life, etc. I personally would not buy a used BMW that is not CPO, but that's just me. Yes, CPO is not fool proof but at least you get a fairly rigorous inspection process, replacement of anything that is worn (tires, brakes, etc), and a full serviced vehicle. I would definitely go N55 over N20, but whether or not you go N55 or a newer B48 really depends on your goals and planned use case for the car.
11-15-2021, 04:09 PM | #25 | |
Rep 5,457
Drives: F30
FWIW... the 12.6 vehicle Im referring to above is on stock turbo, internals etc. Thats what I meant by light mods... basically downpipe, intercooler and tune. |
11-15-2021, 04:27 PM | #26 | |
Rep 5,457
Drives: F30
When I say different... I mean the maps are clearly labeled differently and when the software reads your DME, it selects the proper one (no risk of flashing wrong map). If I remember correctly the 28i tune has a -L in the name (low compression) and the 20i has a -P in the name (no idea why its a P). |
11-15-2021, 05:15 PM | #27 | ||
Rep 7,597
sspade2464.50 |
11-15-2021, 06:08 PM | #28 |
Rep 1,058
Stage 2 320i with bm3/jb4 puts down ~260 at the wheels. With the larger exhaust, a 328i stage 2 bm3/jb4 will put down around 280 with same mods same everything. It's close, but not quite equal.
I could take stock n55 cars with a stage 1 328i from a dig and roll. I think those f3x cars are PWG however. Stage 2 328i OTS map id keep up or be equal to a stage 1 135/335 it seemed. Anything more and I was left behind no questions asked. Thus I went big turbo. I'm pretty sure if a 320i got a b58tu HPFP and custom tune, they could crack 300
MY13: TTE400 Stage 2 turbo, Spec Single Mass flywheel + Stage 3+ Clutch, FTP V2 Turbo Inlet, Evolution Racewerks Charge pipe + Boost pipe + Intercooler, Turbosmart Recirculating Diverter Valve, aFE grill scoop + aFE Magnum Force Cold Air Intake, B58 coil retrofit, eBay Downpipe, Active Autowerke muffler, DW400 LPFP, B58TU HPFP, M5 s63TU injectors, Bimmermilvs, e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block
11-15-2021, 06:11 PM | #29 |
I can haz cheezburger?
6799
Rep 3,677
Drives: 14 Sahara/08 335xi/22 Maverick
Budget would be too low for a CPO UNLESS you would be able to find a 2017/2018 320i but even then, prices would be at least mid 20’s. Private party would be your best bet for service records and getting a PPI done. Would you consider traveling far for the right one?
11-15-2021, 09:47 PM | #30 | |
Rep 6,227
Drives: 2018 340i M Sport
Garage List 2018 BMW 340i M Sport [9.38]
2020 BMW M340i xDrive [10.00] 2018 BMW 340i M Sport [8.00] 2006 BMW 330i Sport [4.50] 2004 BMW 330i ZHP [7.25] 2000 BMW 328i [6.00] |
www.bmwcca.org member #388003 - Use me as a referral & you could win a one day ///M Driving School!! ___________________________________________ |
11-15-2021, 10:34 PM | #31 | ||
Rep 150
sspade2464.50 |
11-15-2021, 10:54 PM | #32 | |
Rep 2,639
Its very rare for someone to leave their straight six stock. I have a friend who goes 12.9@105mph with his 2014 435i xDrive.
11-15-2021, 11:17 PM | #33 |
Rep 1,058
N55 all day. You'll spend the price difference and then some in an n20 to catch the n55 and your stuck trying to surpass it when the n55 is FBO these days.
Things are changing, but the n20 stock turbo size is stuck at 22-23 psi or 310/320whp on a full e85 tune. Upgrade the turbo and you are around 350-360whp on 93, maybe 25-35 more with e85 to break 400whp. Maybe meth might help break that 400 whp barrier. Custom manifold + custom turbo "upgrade" is needed to go more as there isn't anything off the shelf. TLDR: go n55. Save yourself the headache later.
11-16-2021, 04:23 AM | #35 | |
6799
Rep 3,677
11-16-2021, 06:14 AM | #36 |
Rep 2,639
11-16-2021, 08:31 AM | #38 | |
Rep 245
Drives: 1989 325i & 2014 335i
11-16-2021, 08:31 AM | #39 | ||
Rep 5,392
Below is the link to Bootmod3 N20 performance gain listings.. https://bootmod3.com/collections/boo...428i-520i-528i |
11-16-2021, 08:35 AM | #40 |
Rep 3,679
I can speak from experience, as I've actually owned both. I had a 2013 328i xDrive with the N20, and in about 5 years of ownership, I literally did nothing other than preventative maintenance. It was absolutely rock solid with zero problems. In one year of owning the 335i, the chargepipe blew (not really an issue, this is a very well known, preventable, issue), had the OFHG replaced due to leaking, and I had one coolant line pop and got that replaced. So, obviously for me, the N20 was more reliable. Whether or not other people will or have had the same experience is up to you to research. That said, even though my N20 was technically more reliable than my N55 (so far), I really think they're about equal reliability wise. The timing chain can be issue, but IMO it's overblown and doesn't happen as often as you might think. Get a later build date for peace of mind, and I wouldn't worry about it much. If you're at all interested in power/sound, the N55 is miles better than the N20, and for that reason, I'd get the N55. But if reliability is your ONLY concern, it's a coin toss between the two IMO.
All of that said, any B series engine is probably going to be more reliable, if nothing else because it will be newer, but also because they're heavily updated and improved compared to their N series predecessors.
11-16-2021, 02:59 PM | #41 | |
Rep 21
Cheers, |
sspade2464.50 |
11-16-2021, 03:01 PM | #42 |
Rep 21
11-16-2021, 03:43 PM | #43 |
1296
Rep 3,532
love the hilarious power comparisons..
bottom line, ewg n55 over any other option. and if anyone who was stage 1 beating stock n55 cars, it was not an ewg car lol.
11-17-2021, 02:57 AM | #44 | |
Rep 2,639
My N55 has 172k miles There's no coin toss at all, the N55 is more reliable. I race my car every summer doing lapping and I drive it in the winter. Your lack of maintenance does not mean it's not reliable, chargepipe is a known issue since the platform existed, it's a 200$ fix. OFHG and coolant lines are other known issues as well, heat cycles will wear out gaskets and the plastic as per any car, so you'll also have valve cover gasket to swap as well.
