04-23-2019, 07:02 AM | #463 |
Rep 4
Just bought Bimmercode and thought I'd be clever by changing multiple data options and saving them all in one go.
Hmm not good. ECU had a complete meltdown with more lights than the Enterprise flashing and bonging. The only thing missing was shields up RED ALERT!! Thankfully restore mode and a clean pair of boxers was all that was required to rectify my exuberance. I took this opportunity to reset the ECU and then make and save the changes one by one. Each has gone on successfully and for the small investment I'm delighted. As an aside I've had a gearbox issue that has been in under warranty no less than 4x and still not solved. However, since my ECU reset, the gear change is now silky smooth and all problems have disappeared. Could be just coincidence but either way I'm chuffed to bits. The car is now exactly how I like it. |
04-23-2019, 07:43 AM | #464 |
Rep 1,237
Drives: M2 Competition
Added BimmerLink, BimmerCode, NETFLIX, PLEX etc. to CarPlay
How-To: https://www.2addicts.com/forums/show....php?t=1607008
Rathian155.00 |
05-09-2019, 06:51 AM | #465 |
Rep 14
vertical aim issue
can this be coded out using this app
i read that these 2 below needed to be coded LWR_AHL_TYP = ohne (removes adaptive feature) FLC_AKTIV - to nicht aktiv (fixes cornering fault) I know it can be done with E-Sys but my windows update has messed it up. |
05-24-2019, 03:08 AM | #466 |
Rep 45
Yes, it can be found in the FEM module via the expertview of BimmerCode!
05-24-2019, 11:26 PM | #467 |
Rep 26
anyone have issues with the start up screen animation? coded the m performance start up while it worked fine.. it doesnt always come on, on every start up like the stock one did.. only shows up every once in a while, sometimes only plays half way.. the m performance on the cluster works every time
05-25-2019, 07:56 AM | #468 | |
Rep 1,237
05-26-2019, 03:03 PM | #469 |
Rep 26
05-26-2019, 03:08 PM | #470 |
Rep 26
dude! high five! you were right.. thanks for the info! anyone know if on the F32 cluster if the digital spot under the speedo is it just a dead spot or can anything be coded to pop up there?
06-03-2019, 12:51 AM | #471 |
Rep 386
I haven't searched yet. But is there a code to turn off or at least turn the volume lower for the warning sounds such as when im in reverse
06-03-2019, 09:03 AM | #472 |
Rep 268
If i'm not mistaken, that's in the general volume settings under "tone". There's another volume menu at the bottom under your stereo settings where you can adjust PDC volume and the gong sound.
06-03-2019, 10:35 AM | #473 |
Rep 386
You're right but it's still to loud for my liking. But I searched and people were saying you cant code it lower than what is available under settings.
06-04-2019, 11:28 AM | #474 |
Rep 7
Hello guys . Im new to coding , all i want to do is to activate the Start and Stop memory on my F31
I have a cheap ebay OBD2 bluetooth dongle that i never used before , so im afraid to buy the bimmercode app and the dongle does not work with the App. Is there any way that i can test the conection before i buy the app ? Or there is another App that can do this coding for a smaller price ? Only need 1 function. thank you very much |
06-04-2019, 12:15 PM | #475 | |
Rep 25
Drives: 2014 328i xdrive
I also want to get sport+ going on my F30 with launch control, but I'm not clear on all the stuff I read how to do that. Can all of that be done with bimmercode? Is using bimmercode and just selecting sport automatic transmission in the Transmission Control Unit all I need to do to enable sport+? I was able ot code the windows roll up and down with the fob, shut off the idrive when door opened, and unlock the car when shut off. So I am making out pretty well on getting some things tweaked. |
06-04-2019, 03:05 PM | #476 |
BMW Convert
108
Rep 201
Wow , bimmercode has endless coding options in Expert Mode. I just coded my seat to move back when i open my door, and the roll front again when i start the car. Didnt even know i had this option.
3000 SM Global > Einausstuegshilfe. Once here just change from nicht aktiv to Modus_FA_SLV. And thats it. |
06-04-2019, 04:29 PM | #477 | |
Rep 121
06-04-2019, 05:21 PM | #478 |
Rep 5,395
BimmerCode works great. Got the adapter in the photo which is one of the handful that are approved for BC. It has its own OBDLink app which is awesome since it lets you run real time gauges like a boost gauge on your phone. And it does 0-60 and 1/4 mile times for you. Very cool!
06-04-2019, 05:23 PM | #479 | |
Rep 5,395
06-04-2019, 05:27 PM | #480 |
BMW Convert
108
Rep 201
Did the price go up ? I remember purchasing it for $26.99.
06-04-2019, 05:41 PM | #481 |
Rep 121
06-04-2019, 06:15 PM | #482 | |
Rep 1,237
06-06-2019, 11:05 AM | #483 |
Rep 386
I haven't messed with bimmer code since December. Did they finally get the 340i logo to show on the cluster while driving? I remember all I got was a placeholder in German.
What else is new we can do? Felt like just change setting once and forget you even had it ahah |
06-22-2019, 10:19 AM | #484 | |
Rep 2,959
