BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > wheel/rim width impact?
      11-30-2021, 11:41 AM   #1
Santi
Santi's Avatar
Drives: 2014 BMW 328i xDrive F30 N20
waddup peeps.
stock wheel specs on f30s are given as:
7.5x17 et37
8x18 et34
8.5x18 et47
8x19 et36
8.5x19 et47
how do you know how wide of a tire you could fit on a given wheel/rim width? for example, stock is 225/45/r18 -- could you fit the same tire on the 7.5 - 8.5 wide rims (assuming correct diameter)? i'm thinking there's a tire width range that you could fit on a 7.5 or an 8 rim, etc.
besides contacting the shops, anyone have any links to any reference site?
thanks.
      11-30-2021, 12:19 PM   #2
alohasurftoad
Drives: 428i gran coupe
tirerack lists rim width range for a given size tire in "specs"
it also lists the tire dimensions on a given width(measured rim width) which is typically the optimum wheel width for that tire size
      12-01-2021, 11:35 AM   #3
Santi
Santi's Avatar
were you referring to when you enter your car model and choose a tire? or one of their blogs? sorry new to this and tire rack.
thanks.
      12-01-2021, 11:51 AM   #4
alohasurftoad
Originally Posted by Santi View Post
were you referring to when you enter your car model and choose a tire? or one of their blogs? sorry new to this and tire rack. thanks.
find tires by size(you need to enter any USA zip code), narrow choices down by using with various sub menus under "Filter", choose a brand model from the choices, then look at "specs" for that particular tire.
here is an example... Michelin Pilot Sport 4S in 225/45/18, "specs" will give you rim width range along with numerous other info such as weight, overall diameter, section width, tread width on a given rim width(measured rim width)
https://www.tirerack.com/tires/tires...omCompare1=yes
Santi4.50
      12-01-2021, 11:58 AM   #5
Santi
Santi's Avatar
Originally Posted by alohasurftoad View Post
find tires by size(you'll need to enter a USA zip code to do this), narrow choices down by using with various sub menus under "Filter", choose a brand model from the choices, then look at "specs" for that particular tire.
aahhhhhhhh. awesome. nice. thanks.
      12-01-2021, 02:55 PM   #6
Desertnate
Drives: BMW 435i
2016 BMW 435i  [0.00]
There are a few calculators out there like this site. I've noticed some of them vary a bit, but the differences are minor.
https://www.tyresizecalculator.com/c...rim-size-chart
Santi4.50
      12-01-2021, 03:13 PM   #7
Santi
Santi's Avatar
nice. thanks.
Copyright ©2000 - 2022, vBulletin Solutions Inc.
