07-10-2021, 05:09 PM | #1 |
Rep 41
Water injection
Any one running water injection ? Looking to control IAT temps so have ordered a Cobb development charge pipe and looking at options but drawn towards the aquamist HFS4 kit what’s your thoughts ? Or anyone have a current set up they would like to share information
Regards |
07-13-2021, 07:22 PM | #2 |
Rep 4,877
It's what the M4 competition (I think that's it) comes with right from the factory. Has a reservoir in the trunk to allow for higher HP by lowering IAT.
Interested in finding out as well from an aftermarket perspective. |
07-14-2021, 03:13 PM | #3 | |
Rep 41
Cant seem to find much information tbh everything b58 or n55 related is guys running WMI but at 100% methanol. Only really looking at the cooling advantages of running a injection system. I don’t really want to upset the fuel trims and deff not interested in running a meth dependent calibration. I’m currently collecting parts so plan to have everything sourced and start installation over the winter. |
07-14-2021, 04:31 PM | #4 | |
Rep 1,454
2022 CT4-V Blackwing 6-speed
07-14-2021, 05:36 PM | #6 |
Rep 884
You can run water with a smaller nozzle for sure and get the car dialed in, but it's best to drop in some meth also at least a 50/50 mix for that additional octane boost. I ran 100% on my B58 in the past, but that shit is scary with a boiling point of around 150F IIRC lol so it can become an invisible flame. I have meth on my 335is and I run a 60/40 mix and feel much better about that than 100% meth.
2013 335is - sold
2011 335d |
07-15-2021, 03:20 AM | #7 | |
Rep 41
I’m drawn between a few progressive controllers that are on the market also I already have a cobb development charge pipe on order and this seems to be the best on the market as the npt port is as far away from the throttle body as possible. |
07-21-2021, 07:24 AM | #8 | |
Cheapskate
4450
Rep 4,993
My opinion - If you're running CPI then spray water. Use a small nozzle. The water will evaporate in the intake charge and cool it off so the intercooler doesn't work as hard. It's not as ideal as it would be in an engine with an air-to-air intercooler, but it still will work great. Just keep in mind that if it's hot outside, it'll always be hot. You can't cool IATs below ambient due to our intercooler setup. |
Wires1645.50 |
07-21-2021, 12:45 PM | #9 | |
Rep 41
I stay in Scotland so I think I may need to run a small meth dilution as ambient temps hear are very unpredictable but I do only run my car in mainly summer. |
07-22-2021, 10:11 AM | #10 | |
Rep 884
2013 335is - sold
2011 335d |
01-22-2022, 11:42 AM | #11 |
Tom2TerrE
Rep 108
I'm about to have wmi kit in my car.
Not ready yet to custom tune for better octane/fueling, hp gain. Could i use my kit for water injection as cooling purpose? Distilled water works? Any product can be use to prevent clogging tubes? |
01-22-2022, 02:22 PM | #13 |
Rep 1,454
Would not recommend trying to tune charge pipe injection. For cooling purposes and a bit of octane help, sure it works great. But the cylinder distribution from the throttle body isn't the best. You could do PI if you're gonna tune for meth.
01-23-2022, 10:24 AM | #14 |
Rep 180
I have personally been running CPI for over a year now with a single 1,000cc AEM nozzle tuned by F80 Paul and I have had no issues. I log once in a while to check everything and my engine seems to be happy still. At the moment I am in the process of adding a second methanol bung to my charge pipe for a dual nozzle setup. Doing this mostly to test and compare the difference between two small nozzles vs a single large one.
AFE Filter | BMS Intake Pipe
CTS DP | CTS CP | CTS Heat Exchanger PTP Turbo Blanket | AEM WMI Kit | Custom Exhaust PJ ACN91 + Meth tune| XHP Stage 3 Last edited by Mr. 340; 01-23-2022 at 10:51 AM.. |
01-23-2022, 10:42 AM | #15 | |
Rep 180
https://www.nitrousexpress.com/pc_co...5AFE1310F18083
CTS DP | CTS CP | CTS Heat Exchanger PTP Turbo Blanket | AEM WMI Kit | Custom Exhaust PJ ACN91 + Meth tune| XHP Stage 3 Last edited by Mr. 340; 01-23-2022 at 12:02 PM.. |
01-23-2022, 11:38 AM | #16 |
Tom2TerrE
Rep 108
Port injection or Meth Port Injection?
Port Injection was my first plan but most of the video i have seen didn't encourage me doing so. Grinding a part of intake manifold to make it fit, not for me. Meth Port Injection, i love that idea but not in my budget for now. Complex wiring + controller could cause lot of problems. Williams isn't affordable for me currently. |
01-23-2022, 11:49 AM | #18 |
Tom2TerrE
Rep 108
[QUOTE=Mr. 340;28502029]
Ordered Snow Performance stage 2.5, "the kit comes with 2 nozzles (4 gal/hr and a 6 gal/hr)" I plan on using/testing the system as it is at first. Then maybe dual stage, i will work this out with my mechanic, he has way more experience than i could ever have. |
01-23-2022, 11:53 AM | #19 |
Rep 487
01-23-2022, 12:01 PM | #20 |
Rep 180
[QUOTE=Aitom7;28502275]Great choice!
CTS DP | CTS CP | CTS Heat Exchanger PTP Turbo Blanket | AEM WMI Kit | Custom Exhaust PJ ACN91 + Meth tune| XHP Stage 3 |
