07-13-2019, 12:15 PM | #1 |
Rep 254
Drives: 2019 Black 330i xDrive
I recently found out that the shaking at high speeds isn't the alignment or the balancing, but instead all of my rims are bent. I wasn't planning on replacing wheels for a few years but it is just as expensive to get them straightened as it is to just buy new wheels. I'm going to go for a more aggressive style now for the car.
I have been searching for a week now and it is not very easy to find decent staggered wheels on a budget, but I finally found some and want some input on what I'm going to run on the car. Do you think this setup looks good and works? Let me know. I followed this chart I found and verified with discount tire to make sure the difference doesn't exceed 1%. Vehicle: 2014 BMW 328D xDrive Wheels: Verde V21 18 x 8.5 - 35mm offset - F Verde V21 18 x 9.5 - 48mm offset - R Tires: Michelin Pilot Sport A/S 3 Plus 245/40/ZR18 97Y - F Michelin Pilot Sport A/S 3 Plus 275/35/ZR18 95Y - R
2019 G20 Black 330i xDrive
07-15-2019, 08:01 AM | #3 |
Rep 254
Bump
07-15-2019, 12:49 PM | #4 |
Rep 4,329
if you are not lowered, consider 235/45/18F, 265/40/18R, both 26.3" diameter perfect for x-drive. it's a slightly "beefier" so it fills the x-drive gap and provides better ride and impact protection.
continental extremecontact dws06 is available in this size combo, is comparable the michelin pilot sport as3+ but a bit cheaper. |
wdeerfield2746.50 |
07-15-2019, 01:26 PM | #5 | |
A family of bimmers
2747
Rep 7,742
07-17-2019, 08:07 PM | #6 | ||
Rep 254
07-17-2019, 09:26 PM | #7 |
Rep 4,329
245/40/18, 275/35/18 on the offsets youre planning will not have clearance problems however since the tires are shorter it will look better if you're car is lowered
