BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > 340i full exhaust on 328i
Studio RSR
      07-16-2019, 04:56 PM   #1
328iking
Drives: 328i
Was planning on chopping the rear box off my 328i and mating the 340i rear dual box. I know the 340i pipes is slightly bigger and easily fix by a sleeve. But my question is, I have bought the whole 340i, used (only done 5k miles) system from the cat back, can I fix the whole system instead of cutting it all up?
      07-17-2019, 08:50 AM   #2
CandyRedRC46
CandyRedRC46's Avatar
242
Drives: 2013 328i
It is not going to bolt on, if thats what you are asking, but it should fit with minimal modifications. You will probably have to cut and weld a few sections of your down pipe and the 340i exhaust, but it will be a nice upgrade and complement to an upgraded down pipe if done right. I would just buy a high flow downpipe, remove your entire factory exhaust/downpipe, install the upgraded down pipe, then take your car and the 340i exhaust to a competent exhaust shop and have them make it work. While they are merging everything together, they can cut off the 2.25" outlet of the downpipe, so you can have a full, true 3" exhaust.
      07-17-2019, 11:56 AM   #3
328iking
Drives: 328i
Cheers mate.
Am thinking maybe to cut off the part to the cat from the 328i then replace that part to 340i system
I will be adding a dp in future but for my 328i as the 340i upgraded dp won't fit? Or am I wrong in assuming that?
      07-17-2019, 01:06 PM   #4
CandyRedRC46
242
Drives: 2013 328i
340i downpipe will not fit a 328i.
I wouldn't cut any of your factory exhaust, just remove your entire exhaust in one piece and set it aside.
