11-30-2020, 10:59 AM | #1 |
Rep 2,047
Which battery charger?
in preparation for the xhp flash and BM3, I'm considering getting a battery charger. particularly as I'm getting a low battery warning after just 2 days of non-use (it does have a dashcam running).
I know you usually get what you pay for, but is this up to the task of keeping the battery topped up while flashing? Only 8amp: https://www.amazon.co.uk/BUDDYGO-Int...M&sr=1-16&th=1
440i GC with MPPSK, AP intake, 20" 624 M wheels, Wagner downpipe, Xhp stg 3, BM3 stg 2
instagram: f36_garage |
11-30-2020, 11:11 AM | #3 |
Rep 2,047
Thanks - then this seems like a bit of a steal at £16
Just to be sure, is the connection in the front or back on the F36?
11-30-2020, 11:17 AM | #4 |
Rep 2,068
Under the bonnet. You have a negative earth post & a positive terminal with a red plastic cap on it.
/// BM3 + M-Power ///
11-30-2020, 11:25 AM | #5 |
Rep 944
For charging, use the points under the bonnet.
8 amps is plenty to charge the battery, but remember what is in the Xhp manual. They say that up to 30 amps may be taken during flashing (even with all accessories, air con, seat heating, light, radio etc turned off), so I would recommend using your charger overnight to get your battery up to 100% charge before flashing. |
12-01-2020, 03:54 AM | #7 |
Rep 2,047
I'm doing a 1 hour motorway drive on Monday mornings which I understand is enough to charge the battery 100%. When I get home I will plug in the charger and do the flash
12-01-2020, 07:21 AM | #8 |
Rep 15,858
Normal driving, even over time/distance doesn't charge the battery to 100%. Energy management leaves battery capacity for over-run energy 'harvesting'. Anything above ~80% SoC, is gained by lots of over-run charging, not by conventional or even 'intelligent' charging.
12-01-2020, 07:34 AM | #9 |
Rep 1,158
Is a charger worth getting then? I've ordered the above one as it was a deal and I got the battery low warning light this week. Car gets driven 30 mins a week to try to keep the mechanics in order.
Thanks Armaan |
12-01-2020, 07:45 AM | #10 |
Rep 8,636
CTEK MXS5.0
ukbeemerboy462.00 |
12-01-2020, 08:00 AM | #11 |
Rep 2,047
I was about to buy that one but for went for the other option as it was 8amp vs 5 on the CTEK
12-01-2020, 11:26 AM | #12 |
sunjas
Rep 97
I bought the CTEK MXS5.0 during the first lockdown as I got battery discharge warning. Brilliant bit of kit that conditions the battery and re-charges. Highly recommend. CTEK do other versions of this charger too.
S. |
12-01-2020, 11:35 AM | #13 |
Rep 2,810
Drives: Jaguar XE P250 HSE
I got a Noco Genius 5 for my wife's Fiesta. Even with a new battery, it goes flat after a week or so. After fully charging it, it went for weeks without needing it again so it is quite good. BUT, it's only 5 amps and it is sooo slow - 0ver 12 hours and with Scottish weather outside, that's tricky to do. It has too small an amperage, I feel.
I got a Rohr DFX-150 after the last debacle but, paradoxically, I haven't needed it, yet. But it outputs 15 amps and appears to have all the facilities of the Genius so I have high hopes. |
12-01-2020, 11:41 AM | #14 |
Rep 944
Yes, completely worth getting. You have to realise that it takes many hours to properly recharge a large battery. Overnight or a similar length is about right, unless the battery is deeply discharged. If the charger is small enough it can be tucked away in the engine bay along with the socket of the mains extension lead, out of the elements.
Armaan714.50 |
12-01-2020, 01:12 PM | #16 | |
Rep 1,158
Thanks for the reply Armaan |
12-01-2020, 01:31 PM | #17 |
Rep 2,047
Yes, received it today
12-03-2020, 02:15 AM | #18 |
Rep 584
Let us know how you get on with the chargers, still waiting for the 07/2020 update to install, guess the battery isn't charged enough with short journeys at the moment.
12-05-2020, 07:51 AM | #19 |
Beemer Heaven
462
Rep 2,941
Drives: BMW M4 Competition
Garage List 2018 BMW F82 M4 Comp [0.00]
2017 BMW F30 330d M ... [0.00] 2014 BMW F30 330d M ... [0.00] 2009 BMW E90 330d M ... [0.00] 2006 BMW E90 330d M ... [0.00] 2002 BMW E46 325i S ... [0.00] |
Scott
2018 BMW M4 Competition 2019 Mini Countryman Cooper S : 2008 Mini Cooper |
12-09-2020, 06:47 AM | #20 |
Rep 525
sooooo i just charged my car overnight with a 4amp smart charger i had lieing around. It now reads full.
When i measure the voltage at the battery in the boot it reads 12.25V. anyone else have similar reading/result? still not sure if its safe enough for me to begin xhp flashing....i assume it is. this is what i used - worked well on other things, £30 on ebay http://www.absaar.com/v2/en/products...absaar-pro-4-3 |
12-09-2020, 06:56 AM | #21 | |
Rep 15,858
I know my car reads about 0.3 Volts lower when fully awake, (without ignition being on). Don't you need a power supply to flash? There's a current topic on this subject, where it possibly all went wrong without a power supply. |
12-09-2020, 08:45 AM | #22 | |
Rep 525
aaah ok. well that's what i'm trying to figure out, according to my charger it's now full, and so running on trickle charge. And i just don't know whether with only 4Amps that is good enough to sustain the battery above 12V for 15 mins whilst xhp is flashing and drawing current.. or i just spend the £50 to get a 30A+ charger just to flash xhp. or try and borrow one from my local indy. EDIT: well i've just bought the cheapest 30A charger i could find with a UK plug, £40 https://www.ebay.co.uk/itm/12V-24V-B...-/303486804821 i might as well be safe than sorry. Last edited by gippy; 12-09-2020 at 10:00 AM.. |
