01-05-2018, 05:38 PM | #47 |
Rep 156
(This needs to be read with Doug DeMuro's voice.)
"Now here's the wierdest quirk of them all. Being a BMW, even this lowly 3-series it's still a BMW, so, it doesn't use a key to lock and unlock your doors. That's so plebian. So instead you TOUCH the door handle to unlock it!!! How cool is that??!!" "So what happens if your battery runs down, you'd be locked out of the car, right? BMW thought of that so it actually (presses button and pulls out a key, and shows key in front of camera) has a KEY INSIDE the fob??!! Now you take that key, and insert it into this hidden keyhole and... there you are, you're in your car." Last edited by ToniCipriani; 01-06-2018 at 06:01 PM.. |
Beek707.00 |
01-05-2018, 06:35 PM | #48 |
Rep 1,170
(This need's to be read with Pee Wee Herman's voice)
LOL ... I knew all about the key in the fob, I even knew where to put it in the steering column to make the car go Vroom. Never dawned on me there might be a place in the door to use it also ... I went and looked ... there is. You all just give me a bit more time and I'll find another way to make an ass out of myself, we all got to do what we're best at right?
'16 340xi Mineral Grey/Black Leather, MPSS on 18" 398 Orbit Grey wheels, ZF 8HP50, MPPSK+CF Tips, ZTR, ZMP, ZTP, ZCW, ZDA, ZDB, Black Kidney Grilles.
'09 Outback for a beater and grocery getter. |
paul e420.00 |
01-05-2018, 09:08 PM | #49 |
Rep 16,075
SportySpice204.00 |
01-06-2018, 01:21 AM | #50 |
Rep 1,055
Drives: 2016 340i M Sport 6MT+RWD
A little while ago, I read a really informative BMW document on how BMW programs battery charging logic in our cars - can't seem to find that document now but the main message was, the alternator doesn't consistently charge the battery like traditional vehicles to help with fuel consumption. You're not going to get much charging in short trips, even though it's super cold out. You won't get much charging even on a long highway drive, mainly because the battery receives full charging only when it's heavily discharged or while engine braking. Cold temperatures don't help on the former case because even if the alternator is engaged most of the time, it will take a while to charge the battery in such cold temperatures. Engine braking is a very good way to charge the battery - but how many people really drive like that with auto? I do it quite often between red lights given I have a manual.
I got this same message for the first time a couple weeks ago when it started getting frigid. I haven't been driving the 340i much lately due to holidays and getting a second car for the longer commutes not too long ago. Even though I drove ~85 hwy kms each day for a couple days and a couple runs around town, I kept getting the message. It wasn't until I idled the car for 10-15 mins when the message finally went away - although it may have been a cumulation of all the driving I was doing. I thought maybe it had something to do with my hardwired 2 channel dash camera but it's definitely how the vehicle, itself, is managing the charge... it just doesn't give the full charge the battery needs during such cold temperatures. It would rather disable electronics which is a bit annoying. After reading complaints/feedback from multiple posts in this forum, other articles and that document, a battery tender/charger is a must for BMWs now a days to keep the battery in good shape; especially for cold weather and if you don't drive it everyday like I used to.
2016 Estoril Blue II 340i M Sport | ///MPPSK | 6MT | RWD | Fully Loaded
BM3 Stage 2+ 93 | B58TU HPFP | VRSF v2 Catted Downpipe | 550i Clutch |
01-06-2018, 02:34 AM | #51 | |
Rep 715
My battery has been low all winter, gonna get a trickle charger and if that doesn't help replace the battery |
01-06-2018, 04:36 AM | #53 | |
Rep 15,858
The more 'time' we can over-run (zero throttle) with the least amount of braking, the more the battery is boosted. We really need the habit of lifting off completely, rather than just lifting off gradually, even tapping down a gear to increase the engine revs (a bit of engine braking) for extra boost. Also try and avoid early and/or heavy braking. |
01-06-2018, 04:48 AM | #54 | |
Rep 15,858
Unless we are in favourable driving conditions, where we harvest extra alternator boost, most of us will only be running our battery at ~80% SOC. Any unfavourable circumstances and SOC can easily drop off over time. Winter time that can be quite fast. |
01-06-2018, 05:41 AM | #55 | |
Rep 1,055
My dealer has their newer rebranded CTEK 4.3 trickle charger on sale... not sure if I should get it if I already have a smart charger.
01-06-2018, 08:22 AM | #56 |
Rep 16,075
+1. We're not driving electric cars with regenerative motors. What happens is that when we're not using the engine for propulsion it's still turning over, so rather than waste the energy that it's still creating it engages the alternator to charge the battery. When it charges the least is under heavy acceleration. Figuring that you want to accelerate as fast as possible it doesn't divert energy from that task to charge the battery. It's very different from old systems that had the alternator running, and adding to fuel consumption, all the time. It's a very efficient system, but has its quirks, especially in cold weather.
01-06-2018, 08:35 AM | #57 | |
Rep 5,992
01-06-2018, 08:41 AM | #58 |
Rep 241
With the subzero night time temps we're having here, I've been using a Battery Tender from Costco all week. I don't think it has a desulfation mode like the CTEK maintainers. Does the desulfation mode add considerably more benefit to protecting / extending battery life than a more basic float charger? Which device are you folks using?
TIA. This is a great thread, btw. |
01-06-2018, 11:20 AM | #59 | ||
Rep 15,858
Braking itself does not have anything to do with assisting energy recuperation, or with the Intelligent Alternator Control. Engine over-run above 1,000rpm does, as the alternator can run a greater output on command. BMW don't mention braking in the technical data for energy recuperation. The specific phase.... Quote:
Braking would potentially reduce the amount of energy recovered to the battery, as the deceleration time would be a shorter, due to the added braking function. |
01-06-2018, 11:33 AM | #60 | ||
Rep 15,858
Reconditioning is an interesting one, as something like the CTEK uses 15.8 volts for the function. BMW battery charging data specifically says not to exceed 14.8 volts. Quote:
SportySpice204.00 |
01-06-2018, 12:21 PM | #61 |
Rep 1,953
Drives: 2013 328i xDrive
I don't have room to park my car in my garage and typically leave my car outside overnight. I'm looking to leave it plugged in and charging during the day. Given this what's the best charger to get?
01-06-2018, 12:27 PM | #62 |
Rep 7,484
...because 15.8v is excellent for sulphur removal but over time the sulphur has no where to go and the plates cannot perform properly being flooded in the not so helpful solution.
15.8v works but regular use is counterproductive and can decrease the battery lifespan - trade off. If you have an AGM that is not sealed then it is a good idea to check levels and add battery water if required. 15.8v can also cause excess gassing so make sure your vent pipe is connected and not kinked OR at least charge it outside the vehicle if you have switched to a battery that is sealed (no vent pipe). It is normal for the battery to become a little warm but if you hear hissing or the battery is too hot then stop immediately as it is a sign of over heating. If your AGM is not sealed then check the cells one at a time when charging. The fluid should be placid and if you see any bubbling to the surface then stop. |
01-06-2018, 01:32 PM | #63 |
Rep 16,075
I have a NOCO. The 1.5A is sufficient as a maintainer. I permanently wired the lugs to the charging posts under the hood, adding enough wire to have the connector come through the grille down by the fog light, so I don't need to open the hood to connect it.
01-06-2018, 01:42 PM | #64 |
Rep 1,953
Got links to the charger and pics of your permanent solution? I've never had to charge my car battery in my life..
01-06-2018, 01:43 PM | #65 | |
Rep 7,484
Another option. Fantastic range of accessories as well. |
01-06-2018, 03:29 PM | #66 | |
Rep 16,075
It's the 1.1 amp version, there's no 1.5. The 3.5 amp is more than you need for maintaining a battery, though not more than you can use. No pics. The only special tool required is a large torx bit, I forget the size, to loosen the charging posts so you can slide 'C' clips on the wire ends under them. This isn't a job for a newbie, but any decent mechanic with auto wiring experience can do it in about an hour. |
ls3c6fartsucker, ls3c6sucksfarts |
